I hope this is the correct place to post this.
I found a strange situation with the OpenAudio F32, where a null sound stream still produces a low continuous buzz from the amplifier connected to the teensy (4.1+ teensy audio).
My setup:
I’ve (with an AI help) updated the fade filter to fit to the F32 audio.
I connect the Teensy to a big guitar amplifier using its high gain input.
I made a simple code to make sure that the fade in/out works.
I found that when the fade out input is >150 ms, the constant sin wave goes to 0 and there is no sound from the amplifier.
But for some strange reason, that I cannot understand, when the fade out is 30ms, there is a constant buzz from the amplifier! I’ve added a peak filter after the fade, and I see that the exit from the fade is 0, but still there is a low noise from the amplifier!
As I only have one Teensy I don’t know if it’s some issue with my hardware or some issue with the Teensy.
The process to duplicate this:
Could you duplicate this issue?
My setup:
- Run my code. A constant sin would be sound.
- Type “2” in the serial monitor input line. A 3000ms fade out would start. At the end no sound is heard.
- Type “1” to get a fade in and the sine sound back on.
- Type “w” for 30ms fade out. The sine sound get lower, but a small buzz continues until you shut the Teensy off.
the peak print out says that there is no input to the OutI2S1
