iontodirel
I was able to successfully use C++ 20, by modifying the teensy\hardware\avr\1.59.0\boards.txt.
However, I noticed I am getting some linker errors about definitions not found for few C functions.
I fixed this using the following:
#include <sys/stat.h>
#include <stdlib.h>
#include <unistd.h>
void _exit(int status) { while (1) {} }
int _close(int file) { return -1; }
int _fstat(int file, struct stat *st) { st->st_mode = S_IFCHR; return 0; }
int _isatty(int file) { return 1; }
int _lseek(int file, int ptr, int dir) { return 0; }
int _read(int file, char *ptr, int len) { return 0; }
int _write(int file, char *ptr, int len) { return len; }
int _kill(int pid, int sig) { return -1; }
int _getpid(void) { return 1; }
int _sbrk(int incr) { return -1; }
Not sure why these functions are needed, or what are they referenced by, but this was the biggest issue for me when targeting C++20.
One last minor thing, sees like the toolset does not support UTF-8 source files with a BOM.
#include <stdlib.h>
#include <unistd.h>
