Call to arms | Teensy + SDRAM = true
Sorry, I have not had enough :coffee: yet and my eyes are still sort of glazed over...
But I keep wondering if your goal is 300MHz, are you not asking for trouble if you try to more or less run something at twice the speed they are rated for? Are there faster versions?
My goal is the highest speed possible. I don't think there are faster versions. But this SDRAM which is rated for 166MHz, runs smoothly on 221MHz with various capacitors. So I think a little more should work. But this is all just for fun.
Good luck... I thought I saw some up on Digikey that are rated for 200MHz, but maybe don't have the right memory configuration...
For me, I always wonder when you push components like this, if it maybe will only work on some percentage of the chips, which maybe
might change from batch to batch. Does it impact longevity?
But if you are again just doing it for fun :D
Also wondering if the same CAP will work the same on different boards? Or will it all need to be fine-tuned depending on
each actual board design and which memory chip and ...
Since it's being used to measure a delay between the clock signal and when data actually arrives from the SDRAM I think the "best" value would vary based on the board design / track lengths.
All your thoughts are valid. And for a real world product I would never overclock. But for fun, I'm willing to blow shit up lol
Looks like your test Paul should tell which Cap is probably the best. Or atleast give an idea. No?
This is the result I get with the 1.5pF
Clock set 240.00 MHz
 clock=241, Ok
 clock=242, Ok
 clock=243, Ok
 clock=244, Fail
 clock=245, Ok
 clock=246, Ok
Clock set 254.12 MHz
 clock=247, Fail
 clock=248, Fail
 clock=249, Fail
 clock=250, Fail
 clock=251, Fail
Again you're talking about pass vs fail. I'm afraid I'm out of energy to write yet again about capacitor testing method and rationale.
Let me explain what I mean.
Testing each cap takes an absolute ton of time. I fully understand what you've explained before!
If you look above on what I posted, it says:
 clock=241, Ok
 clock=242, Ok
 clock=243, Ok
 clock=244, Fail
 clock=245, Ok
 clock=246, Ok
We have a total of 5 OK's and 1 FAIL for 240MHz. This tells me that the cap is starting to fail at that speed. It gives a croud idea of what this (1.5pF) cap can do. Doing this for each cap should give a very rough estimate. After that, the caps that worked the best can go through the deeper testing that you've explained before.
That's what I meant. Perhaps it wont work like that?
That is why I suggested first testing only 2 or 3 of them, and test with no capacitor soldered. For a start, just test 0pF, 4.7pF, 10pF.
Let's talk only about number of read errors, not pass vs fail.
Please use the latest code from github, and Defragster just recently fixed an issue with the error count.
That is why I suggested first testing only 2 or 3 of them, and test with no capacitor soldered. For a start, just test 4.7pF, 10pF and 15pF.
Let's talk not about pass or fail, but the number of read errors. Please use the latest code from github, and Defragster just recently fixed an issue with the error count.
Number of errors is the interesting part yes. I am only doing these tests to help your curiosity. I have no use of finding the fastest (best) capacitor. So to save time, my idea above sure feels like a great idea to rule out the majority of the caps. From there I will test number of fails.
I will do as such and once I have results I'll post about it again.
Test performed with the following settings. 240MHz and 254MHz:
I started by testing the 4 values you said @PaulStoffregen. I noticed that 10pF seemed to be the golden child. So I added more values above and below. And the end result speaks for itself. 10pF is the best, 12pF is also okay but almost double the amount of read errors at 254MHz.
Results:
Cap ValueSpeedRead fails
No cap240MHz206471504
254.12MHz2206300668
4.7 pF240MHz231
254.12MHz185661801
9.1 pF240MHz45
254.12MHz1157186
10 pF240MHz0
254.12MHz466254
11 pF240MHz0
254.12MHz1543059
12 pF240MHz0
254.12MHz929907
15 pF240MHz0
254.12MHz1310599
18 pF240MHz0
254.12MHz2660450
@Dogbone06 - that isn't the latest sketch copy where Error Count was made correct. Those numbers are suggestive - but they are improperly compounded so even a LOW error rate could report artificially high.
10 pF looks like a good value - for that speed - if used for near fine tuning values.
It is telling where a lower value is seen - but it could read 100X high across any test showing errors - i.e. another 10X to 44X higher.
> i.e. the count of 466,254 is probably under 5,000 depending on where the errors were located in the process - maybe even under 1,000.
If the goal is seeing under ~1,000 Errors giving useful indication of 'almost works' as a value on the edge
> The long test could be aborted when the error count goes over 100,000 as that is not a valid candidate
NOTE: Given that the speed is specified in setup() - the code could use EEPROM storage and step through a range of values unattended.
Throw me the latest code so I don't pick the wrong one. And I'll run it on the 10pF to confirm.
Result at 254MHz with 10pF cap with the latest sketch: 514946 read errors
With the old sketch before you posted, I ran a series of the same test. Gives very very different results. The last one is very bad, because I added a little more solder to each side of the cap. Things like that seem to affect it quite allot.
10 pF240MHz0
254.12MHz466254
742950
689534
776843
968970
1576842
More tests with the 10pF cap and the latest sketch, the results are very different each restart.
10 pF240MHz0
254.12MHz449297
426547
395068
392256
417701
Odd the Error Counts are in the same range - not much lower? There was clearly an issue with a per loop count transferring to the global and it was not starting at 0 for each loop repeating the read. So seeing the same number is surprising?
It's way above my league. I can only test and give you guys the results haha.
TRUE! If that is building with the current INO from github then that is the case.
Bummer not getting to see all the code and feedback as it goes to KNOW the code is right.
It is the latest code and library from Git.
Tell me what to do next and I’ll do it.
Just placed Mouser order - got 5 from your list 10pF and a couple under and over. Upgraded $8 ship to 2 day for another $2 - more than 10 each of the caps. Smallest I ordered before were .1 uF and larger footprint. $2.56 for 50 caps ... should have ordered sooner :(
You can take a break for 3-4 days if you want and they may be here. Even if I only solder one 10 pF I can verify the results as you see them making sure there aren't other bugs.
Let me know if I should send all
The caps so have to you. Not sure if it helps. I have the complete list Paul wrote of the caps. 10pcs of each.
