was thinking about considering all the wiring involved with the camera and display - think
@KurtE pointed all that out. Figured I would wait until the gen5 design came out
I am sort of torn on a lot of this stuff. That is I like what you are trying to do. But I would be far more interested if for example Paul was building a Teensy 4.x with these features. Then I would be all in.
For example should the camera be easily setup for FlexIO or CSI pins. Maybe both. But I am more interested currently with doing it with FlexIO,
as then those who purchase MicroMod boards can make use of the features.
I have been sort of hacking on an updated design of MicroMod breakout board that I may or may not have fabricated and a few partially built.
Currently looks like:
Things I wanted (sort of again along the line of the MMOD breakout Paul did during that Beta.
All of the IO pins have .1" breakout pins that I can connect to. Has connectors for both ILI934x and Adafruit ST.. displays. It has the 20 pin connector that is used on OV7670 boards and now with the GIGA board they have several different cameras with same pin breakout.
Also connection setup for something like an Audio board can be plugged in. And all of the other goodies, USB Host, SDIO, QWIIC.
One of the Hard parts is to find a pinout that one feature does not block another. Like the Audio board uses 20, 21, 23... which several were used earlier on camera... Which currently believe I have in this version:
Pin | MM Pin | OV767X Shield | MM Func | Name | GPIO | Serial | I2C | SPI | PWM | CAN | Audio | XBAR | FlexIO | Analog | SD/CSI/LCD |
0 | 19 | | * | AD_B0_03 | 1.3 | Serial1(6) RX | | SPI1(3) CS0 | PWM1_X1 | 2_RX | | IO-17 | | | |
1 | 17 | | * | AD_B0_02 | 1.2 | Serial1(6) TX | | SPI1(3) MISO | PWM1_X0 | 2_TX | | IO-16 | | | |
2 | 47 | TFT_RST | * | EMC_04 | 4.4 | | | | PWM4_A2 | | 2:TX_DATA | IO-06 | 1:4 | | |
3 | 32 | TFT_BACKLIGHT | * | EMC_05 | 4.5 | | | | PWM4_B2 | | 2:TX_SYNC | IO-07 | 1:5 | | |
4 | 10 | TFT_DC | * | EMC_06 | 4.6 | | | | PWM2_A0 | | 2:TX_BCLK | IO-08 | 1:6 | | |
5 | 18 | TFT_CS | * | EMC_08 | 4.8 | | | | PWM2_A1 | | 2:RX_DATA | IO-17 | 1:8 | | |
6 | 71 | CAMERA_D6 | * | B0_10 | 2.10 | | | | PWM2_A2, QT4_1 | 1:TX3_RX1 | 2:10 | | LCD_DATA6 | | |
7 | 56 | AUDIO | | B1_01 | 2.17 | Serial4(4) RX | | | PWM1_B3 | | 1:TX_DATA | IO-15 | 2:17, 3:17 | | |
8 | 54 | AUDIO | | B1_00 | 2.16 | Serial4(4) TX | | | PWM1_A3 | | 1:RX_DATA | IO-14 | 2:16, 3:16 | | |
9 | 69 | CAMERA_D7 | * | B0_11 | 2.11 | | | | PWM2_B2,QT4_2 | 1:TX2_RX2 | 2:11 | | LCD_DATA7 | | |
10 | 55 | CAMERA_PCLK | FNCS0 | B0_00 | 2.0 | | | SPI(4) CS0 | QT1_0 | | MQS_RIGHT | | 2:0 | | LCD_CLK |
11 | 59 | SPI_MOSI | * | B0_02 | 2.2 | | | SPI(4) MOSI | QT1_2 | 1_TX | | | 2:2 | | LCD_HSYNC |
12 | 61 | SPI_MISO | * | B0_01 | 2.1 | | | SPI(4) MISO | QT1_1 | | MQS_LEFT | | 2:1 | | LCD_ENABLE |
13 | 57 | SPI_CLK | * | B0_03 | 2.3 | | | SPI(4) SCK | QT2_0 | 1_RX | | | 2:3 | | LCD_VSYNC |
14/A0 | 34 | | * | AD_B1_02 | 1.18 | Serial3(2) TX | | | QT3_2 | | SPDIF_OUT | | 3:2 | A1:7, A2:7 | |
15/A1 | 38 | | * | AD_B1_03 | 1.19 | Serial3(2) RX | | | QT3_3 | | SPDIF_IN | | 3:3 | A1:8, A2:8 | |
16/A2 | 20 | | * | AD_B1_07 | 1.23 | Serial2(3) RX | Wire2(3) SCL | | | | SPDIF_EXTCLK | | 3:7 | A1:12, A2:12 | USDHC2_DATA3 |
17/A3 | 22 | | * | AD_B1_06 | 1.22 | Serial2(3) TX | Wire2(3) SDA | | | | SPDIF_LOCK | | 3:6 | A1:11, A2:11 | USDHC2_DATA2 |
18/A4 | 12 | WIRE(CAM/AUD) | * | AD_B1_01 | 1.17 | Serial3(2) RTS | Wire(1) SDA | | QT3_1 | | | | 3:1 | A1:6, A2:6 | |
19/A5 | 14 | WIRE(CAM/AUD) | * | AD_B1_00 | 1.16 | Serial3(2) CTS | Wire(1) SCL | | QT3_0 | | | | 3:0 | A1:5, A2:5 | |
20/A6 | 52 | AUDIO | | AD_B1_10 | 1.26 | Serial5(8) TX | | | | | 1:RX_SYNC | | 3:10 | A1:15, A2:15 | |
21/A7 | 50 | AUDIO | | AD_B1_11 | 1.27 | Serial5(8) RX | | | | | 1:RX_BCLK | | 3:11 | A1:0, A2:0 | |
22/A8 | 49 | | * | AD_B1_08 | 1.24 | | | | PWM4_A0 | 1_TX | | | 3:8 | A1:13, A2:13 | USDHC2_CMD |
23/A9 | 58 | AUDIO | | AD_B1_09 | 1.25 | | | | PWM4_A1 | 1_RX | 1:MCLK | | 3:9 | A1:14, A2:14 | USDHC2_CLK |
24/A10 | 53 | | | AD_B0_12 | 1.12 | Serial6(1) TX | Wire1(4) SCL | | PWM1_X2 | | | | | A1:1 | |
25/A11 | 51 | | | AD_B0_13 | 1.13 | Serial6(1) RX | Wire1(4) SDA | | PWM1_X3 | GPT1_CLK | | | | A1:2 | |
26/A12 | 67 | TOUCH_CS | | AD_B1_14 | 1.30 | | | SPI1(3) MOSI | | | 1:TX_BCLK | | 3:14 | A2:3 | |
27/A13 | 8 | TOUCH_IRQ | | AD_B1_15 | 1.31 | | | SPI1(3) SCK | | | 1:TX_SYNC | | 3:15 | A2:4 | |
28 | 4 | TFT_SD_CS | | EMC_32 | 3.18 | Serial7(7) RX | | | PWM3_B1 | | | | | | |
29 | 16 | CAMERA_MCLK | * | EMC_31 | 4.31 | Serial7(7) TX | | SPI2(1) CS1 | PWM3_A1 | | | | | | |
30 | 41 | CAMERA_PDN | *0 | EMC_37 | 3.23 | | | | GPT1_3 | 3_RX | 3:MCLK | IO-23 | | | |
31 | 43 | CAMERA_PEN | *0 | EMC_36 | 3.22 | | | | GPT1_2 | 3_TX | 3:TX_DATA | IO-22 | | | |
32 | 65 | CAMERA_HSYNC | | B0_12 | 2.12 | | | | | | 1:TX1_RX3 | IO-10 | 2:12 | | LCD_DATA8 |
33 | 63 | CAMERA_VSYNC | | EMC_07 | 4.7 | | | | PWM2_B0 | | 2:MCLK | IO-09 | 1:7 | | |
SD Pins - Cable connector(T4 34-39) | | | | | | | | | | | | | | | |
34 | 66 | SDIO | FPE1 | SD_B0_03 | 3.15 | Serial5(8) RTS | SPI2(1) MISO | PWM1_B1 | | IO-07 | | | DATA1 | | |
35 | 64 | SDIO | | SD_B0_02 | 3.14 | Serial5(8) CTS | SPI2(1) MOSI | PWM1_A1 | | IO-06 | | | DATA0 | | |
36 | 60 | SDIO | * | SD_B0_01 | 3.13 | | Wire2(3) SDA | SPI2(1) CS0 | PWM1_B0 | | IO-05 | | | CLK | |
37 | 62 | SDIO | * | SD_B0_00 | 3.12 | | Wire2(3) SCL | SPI2(1) SCK | PWM1_A0 | | IO-04 | | | CMD | |
38 | 68 | SDIO | FPE0 | SD_B0_04 | 3.16 | Serial5(8) TX | FLEXSPI B_SSO_B | PWM1_A2 | | IO-08 | | | DATA2 | | |
39 | 70 | SDIO | FNCS1 | SD_B0_05 | 3.17 | Serial5(8) RX | FLEXSPI B_DQS | PWM1_B2 | | IO-09 | | | DATA3 | | |
Micromod new pins | | | | | | | | | | | | | | | |
40 | 40 | CAMERA_D0 | * | B0_04 | 2:04 | | Wire3(2) SCL | QT2_1 | | | | 2:4 | | LCD_DATA0 | |
41 | 42 | CAMERA_D1 | * | B0_05 | 2:05 | | Wire3(2) SDA | QT2_2 | | | | 2:5 | | LCD_DATA1 | |
42 | 44 | CAMERA_D2 | * | B0_06 | 2:06 | | | | QT3_0 | | | | 2:6 | | LCD_DATA2 |
43 | 46 | CAMERA_D3 | * | B0_07 | 2:07 | | | | QT3_1 | | | | 2:7 | | LCD_DATA3 |
44 | 48 | CAMERA_D4 | * | B0_08 | 2:08 | | | | QT3_2 | | | | 2:8 | | LCD_DATA4 |
45 | 73 | CAMERA_D5 | * | B0_09 | 2:09 | | | | QT4_0 | | | | 2:9 | | LCD_DATA5 |
Hopefully if you do another rev that has CSI pins broken out we can have the camera as well
then it would be a Teensy Giga that actually works
Yes and No... That is with all of it's warts it is still a product you can go out and purchase...
And assuming many of these warts are fixed over time. It is a Dual core processor, with SDIO memory, about 75 IO pins that are on
connectors, that are easy for hobbyist to access, versus their Portenta boards (or MicroMod board for that matter), where most of us hobbyists find harder to build your own shields...
Side note: As I asked on the Arduino Forum, I wish I knew what connectors that Arduino is using for their Camera connections, that allow you to
for example connect from either the top or bottom of the board:
As if I knew what they were, would be tempted to use on the design above...
Likewise, if they have single row version for the displays as sometimes nice for ILI9341 boards to be on the back
and sometime nice to be on the front...
