That should help @sRGB565 with the design atleast.IIRC the NXP EVK for 1170 comes with two SDRAM - maybe the PCB files might show? Even if they haven't posted DEMO code yet.
Design decisions. The SEMC only supports up to 512 Mbit per chip. I guess it's time to explain the full design of the game console.What do you need 2x for
I had wondered if I needed to length tune them, and how to go about doing that. I'll try relocating the SDRAM so it's above the iMXRT and mirroring the traces to another SDRAM near it (of course with a separate CS). Do the track lengths have to match the other SDRAM's as well or can they be independent to some degree? I don't think the other chip would care about different timings for a different chip but this kind of 'intuition' has come back to bite me before. Hard. Additionally, my PCB design skills aren't great so I'll probably have to do multiple runs. Would you guys be okay if I opened a separate thread for peer-reviewing my PCB once it's ready?If you wanted to add another SDRAM, you just tap most of the existing signals and take a new CS from one of the SEMC CSX pins. Think of it like SPI with loads more pins, and the restriction that the track lengths need to all match each other as much as possible.
The system itself will have 3 iMXRT1062 chips. One is the application processor (turboed to 1 GHz) paired with 128 MB of RAM. The next uses a software rendering library (so I can get semi-decent realtime shading) and has 64 MB of VRAM. This chip will be displaying rendered 2d/3d graphics through the RGB interface, which is then hooked up to an ADV7513. The 3rd chip is the security processor and kind of acts as a north and south bridge (since it interfaces with the wifi and Bluetooth cards, the USB SSD, and gpio). Then, there's a boot processor (the esp32 is my choice due to the integrated wifi/bt, decent amount of I/O, and no requirement for power sequencing).
I spent multiple weeks figuring out how to prevent the system from becoming bandwidth-constrained, and I'm happy with my results to that end.
If you have additional questions or criticisms regarding the system architecture, please let me know!
Yes I'm sure it will take absolutely forever. My last system I did was comparatively weak and took over a year in development time. I learned a lot of what I currently know about system development from it. The rest came from research on the Wii, 3DS, and PS3.This is no easy task. It will be very cool
To see if you succeed. I truly hope so!
How do you plan to integrate WiFi and Bluetooth to the Teensy, any library in mind?
I am unsure actually. The reason why that one is floating by itself is that the pin most likely got moved in the schematic. Never even saw the floating one there. But yes EMC_01 is used by SDRAM.Something I just noticed: on PJRC's T4 schematic, EMC_01 is shown connected to PTA1 on the bootloader. On the SDRAM board EMC_01 goes to the SDRAM... and judging from the schematic, PTA1 is left floating?
@Dogbone06 are the CC pins on the USB Host port left unconnected? They should really have ~50K pull-ups connected to 5V to properly look like a host port to usb-c capable devices.
5.1k pulldown is standard for ports on devices (ports that want power). 50k pullup is used on host ports (ports that supply power).5.1k for each CC pin as per the standard. They have that.
The CC Pins are supposed to be connected to the USB-PD CC pins on the IC to negotiate. But they are not. The naming of them was wrong (human error). Good thing you catched this, the PCB's for Gen5 are not assembled yet, so I can pull the handbrake and alter them!5.1k pulldown is standard for ports on devices (ports that want power). 50k pullup is used on host ports (ports that supply power).
@Paul - New DevBoard 5 out of the oven and March is behind us ...Let's talk of this in March or later. For now I'm trying to help in small but important ways, but I'm currently working on other projects so I just can't get more involved in SDRAM. Just to be realistic, that'll probably still be the case by March time frame too.
@Dogbone06
Do you have the link to the pcb files to the latest working version that has all the eLCDIF/FlexIO2 pins exposed please
Thanks
Nice - very nice @KurtE - if a variants scheme works to allow DIY boards to be fitted to the TD install!
About 24 hours since last update to the USA FedEx package ... still in France? ...
That is the idea. For example, I am not going to take over my MICROMOD board type for DEVBOARD as I use MICROMODs...Nice - very nice @KurtE - if a variants scheme works to allow DIY boards to be fitted to the TD install!
#include <core_pin_names.h>
while (!Serial && millis() < 4000) {}
if (CrashReport) Serial.print(CrashReport);
pinMode(B0_03, OUTPUT);
Serial.printf("Port Set:%p Clear:%p Toggle:%p mask:%x\n", &CORE_PIN13_PORTSET, &CORE_PIN13_PORTCLEAR, &CORE_PIN13_PORTTOGGLE, CORE_PIN13_BITMASK);
digitalWrite(B0_03, HIGH);
digitalWrite(B0_03, LOW);
delay(5000);
digitalToggle(B0_03);
delay(250);
delay(250);
if (Serial.available()) {
while(Serial.read() != -1) {}
while(Serial.read() == -1) {}
// PinName values: 32 bit top 16 - offset in EMC table, low 8 bits 0-4 GPIO PIN 5-7 On Port #
typedef enum {
AD_B0_00 = 0x0BC0000, AD_B0_01 = 0x0C00001, AD_B0_02 = 0x0C40002, AD_B0_03 = 0x0C80003, AD_B0_04 = 0x0CC0004, AD_B0_05 = 0x0D00005, AD_B0_06 = 0x0D40006, AD_B0_07 = 0x0D80007,
AD_B0_08 = 0x0DC0008, AD_B0_09 = 0x0E00009, AD_B0_10 = 0x0E4000A, AD_B0_11 = 0x0E8000B, AD_B0_12 = 0x0EC000C, AD_B0_13 = 0x0F0000D, AD_B0_14 = 0x0F4000E, AD_B0_15 = 0x0F8000F,
AD_B1_00 = 0x0FC0010, AD_B1_01 = 0x1000011, AD_B1_02 = 0x1040012, AD_B1_03 = 0x1080013, AD_B1_04 = 0x10C0014, AD_B1_05 = 0x1100015, AD_B1_06 = 0x1140016, AD_B1_07 = 0x1180017,
AD_B1_08 = 0x11C0018, AD_B1_09 = 0x1200019, AD_B1_10 = 0x124001A, AD_B1_11 = 0x128001B, AD_B1_12 = 0x12C001C, AD_B1_13 = 0x130001D, AD_B1_14 = 0x134001D, AD_B1_15 = 0x138001F,
B0_00 = 0x13C0020, B0_01 = 0x1400021, B0_02 = 0x1440022, B0_03 = 0x1480023, B0_04 = 0x14C0024, B0_05 = 0x1500025, B0_06 = 0x1540026, B0_07 = 0x1580027,
B0_08 = 0x15C0028, B0_09 = 0x1600029, B0_10 = 0x164002A, B0_11 = 0x168002B, B0_12 = 0x16C002C, B0_13 = 0x170002D, B0_14 = 0x174002E, B0_15 = 0x178002F,
B1_00 = 0x17C0030, B1_01 = 0x1800031, B1_02 = 0x1840032, B1_03 = 0x1880033, B1_04 = 0x18C0034, B1_05 = 0x1900035, B1_06 = 0x1940036, B1_07 = 0x1980037,
B1_08 = 0x19C0038, B1_09 = 0x1A00039, B1_10 = 0x1A4003A, B1_11 = 0x1A8003B, B1_12 = 0x1AC003C, B1_13 = 0x1B0003D, B1_14 = 0x1B4003D, B1_15 = 0x1B8003F,
EMC_00 = 0x0140060, EMC_01 = 0x0180061, EMC_02 = 0x01C0062, EMC_03 = 0x0200063, EMC_04 = 0x0240064, EMC_05 = 0x0280065, EMC_06 = 0x02C0066, EMC_07 = 0x0300067,
EMC_08 = 0x0340068, EMC_09 = 0x0380069, EMC_10 = 0x03C006A, EMC_11 = 0x040006B, EMC_12 = 0x044006C, EMC_13 = 0x048006D, EMC_14 = 0x04C006E, EMC_15 = 0x050006F,
EMC_16 = 0x0540070, EMC_17 = 0x0580071, EMC_18 = 0x05C0072, EMC_19 = 0x0600073, EMC_20 = 0x0640074, EMC_21 = 0x0680075, EMC_22 = 0x06C0076, EMC_23 = 0x0700077,
EMC_24 = 0x0740078, EMC_25 = 0x0780079, EMC_26 = 0x07C007A, EMC_27 = 0x080007B, EMC_28 = 0x084007C, EMC_29 = 0x088007D, EMC_30 = 0x08C007D, EMC_31 = 0x090007F,
EMC_32 = 0x0940052, EMC_33 = 0x0980053, EMC_34 = 0x09C0054, EMC_35 = 0x0A00055, EMC_36 = 0x0A40056, EMC_37 = 0x0A80057, EMC_38 = 0x0AC0058, EMC_39 = 0x0B00059,
EMC_40 = 0x0B4005A, EMC_41 = 0x0B8005B, SD_B0_00 = 0x1BC004C, SD_B0_01 = 0x1C0004D, SD_B0_02 = 0x1C4004E, SD_B0_03 = 0x1C8004F, SD_B0_04 = 0x1CC0050, SD_B0_05 = 0x1D00051,
SD_B1_00 = 0x1D40040, SD_B1_01 = 0x1D80041, SD_B1_02 = 0x1DC0042, SD_B1_03 = 0x1E00043, SD_B1_04 = 0x1E40044, SD_B1_05 = 0x1E80045, SD_B1_06 = 0x1EC0046, SD_B1_07 = 0x1F00047,
SD_B1_08 = 0x1F40048, SD_B1_09 = 0x1F80049, SD_B1_10 = 0x1FC004A, SD_B1_11 = 0x200004B
} IMXRT_PIN_t;
inline void digitalWrite(IMXRT_PIN_t pin_name, uint8_t val) {
uint32_t mask = 1 << (pin_name & 0x1f);
if (val) {
volatile uint32_t *reg = (volatile uint32_t*)((uint8_t *)&GPIO6_DR_SET + 0x4000 * ((pin_name >> 5) & 0x7));
*reg = mask;
volatile uint32_t *reg = (volatile uint32_t*)((uint8_t *)&GPIO6_DR_CLEAR + 0x4000 * ((pin_name >> 5) & 0x7));
*reg = mask;
inline void digitalToggle(IMXRT_PIN_t pin_name) {
volatile uint32_t *reg = (volatile uint32_t*)((uint8_t *)&GPIO6_DR_TOGGLE + 0x4000 * ((pin_name >> 5) & 0x7));
Serial.printf("Toggle %x Reg:%x mask:%x\n", pin_name, reg, mask);
*reg = mask;
void pinMode(IMXRT_PIN_t pin_name, uint8_t mode)
// generate PAD and MUX register from name...
volatile uint32_t *mux = (volatile uint32_t *)(IMXRT_IOMUXC_ADDRESS + (pin_name >> 16));
volatile uint32_t *pad = (volatile uint32_t *)(IMXRT_IOMUXC_ADDRESS + (pin_name >> 16) + 0x1f0);
volatile uint32_t *gdir = (volatile uint32_t*)((uint8_t *)&GPIO6_GDIR + 0x4000 * ((pin_name >> 5) & 0x7));
Serial.printf("pinMode %x mux:%p pad:%p gdir:%p mask:%x\n", pin_name, mux, pad, gdir, mask);
const struct digital_pin_bitband_and_config_table_struct *p;
if (mode == OUTPUT || mode == OUTPUT_OPENDRAIN) {
*gdir |= mask; // TODO: atomic
if (mode == OUTPUT) {
*pad = IOMUXC_PAD_DSE(7);
} else { // OUTPUT_OPENDRAIN
*pad = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_ODE;
*gdir &= ~(p->mask); // TODO: atomic
if (mode == INPUT) {
} else if (mode == INPUT_PULLUP) {
*pad = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(3) | IOMUXC_PAD_HYS;
} else if (mode == INPUT_PULLDOWN) {
*pad = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_PKE | IOMUXC_PAD_PUE | IOMUXC_PAD_PUS(0) | IOMUXC_PAD_HYS;
} else { // INPUT_DISABLE
*pad = IOMUXC_PAD_DSE(7) | IOMUXC_PAD_HYS;
mux = 5 | 0x10;
