We should absolutely get the 1XK to work as well. I'm all for that. Will let you know the second the 1DX's and 1YN's ship from factorym should be in a few days.In addition to Arduino Giga, I ordered a couple of this eval board with the 1XK module. Will make a M.2 adaptor PCB soon...
1XK is more expensive, but it's dual band. Most routers have 5 GHz Wifi and many upstream internet connections are usually fast enough to support it, so perhaps the more expensive 1XK will be worth its extra cost?
M.2 Signal Teensy 1XK Notes
1 GND
2 3.3V
3 nc
4 3.3V
5 nc
6 nc
7 GND
8 BT_PCM_CLK 4 8 g6
9 SDIO_CLK 23 4
10 BT_PCM_SYNC 3 9 g7
11 SDIO_CMD 22 6 pullup resistor required
12 BT_PCM_OUT 2 or 5 14 g5 resistors to route to Teensy pins 2 or 5
13 SDIO_D0 40 5 pullup resistor required
14 BT_PCM_IN 5 or 2 11 g4 resistors to route to Teensy pins 2 or 5
15 SDIO_D1 41 56 pullup resistor required
16 nc
17 SDIO_D2 17 3 pullup resistor required
18 GND
19 SDIO_D3 16 55 pullup resistor required
20 BT_HOST_WAKE_L 17 g14 drives with OD buffer, pullup resistor required
21 WL_HOST_WAKE_L 12 g1 drives with OD buffer, pullup resistor required
22 BT_UART_TXD 34 54 g10
23 nc
32 BT_UART_RXD 35 7 g9
33 GND
34 BT_UART_RTS inv->36 51 g11 use 74LV1T04 inverter between 1XK-Teensy pin 36
35 nc
36 BT_UART_CTS 37 15 g8
37 nc
38 JTAG_TDO not used
39 GND
40 WL_DEV_WAKE_L ?? ??? does this matter
41 nc
42 BT_DEV_WAKE_L ?? ??? does this matter
43 nc
44 JTAG_TDI not used
45 GND
46 JTAG_TCK not used
47 nc
48 JTAG_TMS not used
49 nc
50 32kHz clock ??? do we need this for sleep modes
51 GND
52 nc
53 nc
54 nc
55 nc
56 PMIC_EN 32-maybe 3 reset circuit CAT811T, or Teensy pin 32 + pullup
57 GND
58 nc
59 nc
60 nc
61 nc
62 nc
63 GND
64 3.3V I/O turns all 1.8V I/O into 3.3V signals
65 nc
66 nc
67 nc
68 nc
69 GND
70 nc
71 nc
72 3.3V
73 nc
74 3.3V
75 GND
Definitely curious. If works let me know I will order a eval boardI drafted a quick PCB layout to connect the 1XK eval board to Teensy 4.1.
Hopefully both will arrive by next week.
This is looking promising, good work!I drafted a quick PCB layout to connect the 1XK eval board to Teensy 4.1.
If anyone's curious, here's my notes about the connections.
Code:M.2 Signal Teensy 1XK Notes --- ------ ------ --- ----- 1 GND 2 3.3V 3 nc 4 3.3V 5 nc 6 nc 7 GND 8 BT_PCM_CLK 4 8 g6 9 SDIO_CLK 23 4 10 BT_PCM_SYNC 3 9 g7 11 SDIO_CMD 22 6 pullup resistor required 12 BT_PCM_OUT 2 or 5 14 g5 resistors to route to Teensy pins 2 or 5 13 SDIO_D0 40 5 pullup resistor required 14 BT_PCM_IN 5 or 2 11 g4 resistors to route to Teensy pins 2 or 5 15 SDIO_D1 41 56 pullup resistor required 16 nc 17 SDIO_D2 17 3 pullup resistor required 18 GND 19 SDIO_D3 16 55 pullup resistor required 20 BT_HOST_WAKE_L 17 g14 drives with OD buffer, pullup resistor required 21 WL_HOST_WAKE_L 12 g1 drives with OD buffer, pullup resistor required 22 BT_UART_TXD 34 54 g10 23 nc 32 BT_UART_RXD 35 7 g9 33 GND 34 BT_UART_RTS inv->36 51 g11 use 74LV1T04 inverter between 1XK-Teensy pin 36 35 nc 36 BT_UART_CTS 37 15 g8 37 nc 38 JTAG_TDO not used 39 GND 40 WL_DEV_WAKE_L ?? ??? does this matter 41 nc 42 BT_DEV_WAKE_L ?? ??? does this matter 43 nc 44 JTAG_TDI not used 45 GND 46 JTAG_TCK not used 47 nc 48 JTAG_TMS not used 49 nc 50 32kHz clock ??? do we need this for sleep modes 51 GND 52 nc 53 nc 54 nc 55 nc 56 PMIC_EN 32-maybe 3 reset circuit CAT811T, or Teensy pin 32 + pullup 57 GND 58 nc 59 nc 60 nc 61 nc 62 nc 63 GND 64 3.3V I/O turns all 1.8V I/O into 3.3V signals 65 nc 66 nc 67 nc 68 nc 69 GND 70 nc 71 nc 72 3.3V 73 nc 74 3.3V 75 GND
I noticed the '32Khz' on the silkscreen,
Today I discovered ublox also makes a module with the same IW416 chip Murata 1XK, and they also sell it on a M.2 module. Digikey has them in stock. Looks like the same pinout, so likely to also work (assuming I can get the software going). Part number is M2-MAYA-W161-10C.
1.4 Software
A detailed description of the wireless interface drivers and configuration instructions for a Linux host
computer are included in the system integration manual for each module type. [7], [8], [9]
The documentation for NXP software releases includes Wi-Fi and Bluetooth release notes and a list
of supported software features. The driver source code is provided free of charge as open source
under NXP license terms. As an open-source resource, the drivers may be integrated or ported to other
non-NXP based host platforms. Yocto recipes for the driver and firmware, that can be used to develop
custom Linux-based systems, are part of the NXP i.MX Linux BSP in the meta-imx and meta-freescale
layers.
The latest version of the driver source code and Wi-Fi/Bluetooth firmware are available from the
following open-source repositories:
• Wi-Fi driver: https://github.com/nxp-imx/mwifiex
• Firmware: https://github.com/NXP/imx-firmware
☞ Use the repository branches matching to the latest Linux BSP release version. At the time of
publication, this is release 6.6.23_2.2.0.
The configuration guide for NXP-based Wireless Modules [15] provides a useful reference for
configuring and using the Wi-Fi and Bluetooth features for NXP-based wireless modules. The
supported Wi-Fi features described in the guide include scanning for nearby access points,
connecting to an access point, configuring the device as an access point, Wi-Fi security, Wi-Fi Direct,
and throughput testing using the iperf3 utility. The described Bluetooth features include scan, pair,
connect to a Bluetooth or Bluetooth Low Energy (LE) device, A2DP profile, handsfree profile and
Bluetooth LE device as a GATT server. Guidelines for enabling driver debug logging are also provided.
Good luck!!Now I have a lot of software experimenting to do.
Hopefully the only error!M.2 standoff misplaced a bit
Yes antenna is optional.Hopefully the only error!
Are Antennas optional ? - nice how they don't waste ink and add silkscreen for Bt .vs. WiFi.
Good to check as some radios with no antenna die on Tx. I assume the 'lower' is WiFi and it looks like a PCB antenna - and maybe removing that component by the plug activates the plugged antenna, but the upper plug doesn't seem to have that for Bt - unless it is underneath or the freq works otherwise without a big obvious topside PCB layer?Yes antenna is optional.
I have now gone 21 days without water. My Camel died days ago after I was forced to drink it's last water to stay alive. But I keep my hopes up. Paul shall arrive soon with a truck full of fresh water. He might even bring me a new Camel if I'm lucky.
