using System.Diagnostics;
namespace TeensyFlashDetectionCLI
internal class Program
// Program Constants
const string ports_path = @""; // Paste your teensy_ports path here
const string ports_args = "-L";
const string bootloader_ident = "Bootloader";
const string not_ready_ident = "[no_device]";
// List of unique CLI returns
public static List<string> returnHistory = new List<string>();
static void Main(string[] args)
SetConsoleColorAndClear(ColorSet.IDLE);
// Monitor Ports
while(true)
// Check ports
Loop();
// Wait
Task.Delay(200).Wait();
static void Loop()
// Enumerate with basic teensy_ports output
string ret = ExecuteCommand(ports_path, ports_args);
// If unique, add to history
if (!returnHistory.Contains(ret))
returnHistory.Add(ret);
// Change terminal color and indicate between No Teensy Connected/Connected in Bootloader/Connected normal
if(String.IsNullOrWhiteSpace(ret) || ret.Contains(not_ready_ident))
// Not connected
Console.WriteLine("Not Connected");
else if(ret.Contains(bootloader_ident))
// Connected, bootloader
SetConsoleColorAndClear(ColorSet.RED);
Console.WriteLine("Bootloader");
// Connected
SetConsoleColorAndClear(ColorSet.GREEN);
Console.WriteLine("Connected");
Console.WriteLine();
// Print historical results
Console.WriteLine("[History]");
foreach (string line in returnHistory)
Console.Write(" -> ");
if (String.IsNullOrWhiteSpace(line)) { Console.WriteLine("{empty}"); }
else { Console.WriteLine(line.Replace(Environment.NewLine, String.Empty)); }
// Print current output
Console.WriteLine("[Current]");
Console.WriteLine($"{ret}");
public enum ColorSet { IDLE, GREEN, RED};
static void SetConsoleColorAndClear(ColorSet color)
switch(color)
case ColorSet.GREEN:
Console.BackgroundColor = ConsoleColor.Green;
Console.ForegroundColor = ConsoleColor.Black;
case ColorSet.RED:
Console.BackgroundColor = ConsoleColor.Red;
default:
Console.BackgroundColor = ConsoleColor.Black;
Console.ForegroundColor = ConsoleColor.White;
Console.Clear();
public static string ExecuteCommand(string command, string arguments = "")
ProcessStartInfo processStartInfo = new ProcessStartInfo(command)
Arguments = arguments,
RedirectStandardOutput = true,
RedirectStandardError = true,
UseShellExecute = false,
CreateNoWindow = true
using (Process process = new Process())
process.StartInfo = processStartInfo;
process.Start();
// Read the output of the command
string output = process.StandardOutput.ReadToEnd();
// Wait for the process to finish
process.WaitForExit();
return output;
