CAN communication using Teensy 4.1 for Cubemars Motor AK70-10(HELP NEEDED)
iplaycsgo4evr
i have been trying to do can communication with the motor but am not getting any responses im particularly new to this and would appreciate some help in understanding whats wrong with my code
i am Using pins 30 and 31 which are CRX3 and CTRX3 resp which are connected to the CRX and CTX pins of the MCP 2551 and the CANH and CANL pins of the MCP 2551 are connected to the Motor
if anyone has worked with these motors any help would be appreciated
THANK YOU
#include <FlexCAN_T4.h>
// ====== Define CubeMars CAN Packet IDs ======
enum CAN_PACKET_ID {
CAN_PACKET_SET_DUTY = 0,
CAN_PACKET_SET_CURRENT = 1,
CAN_PACKET_SET_CURRENT_BRAKE = 2,
CAN_PACKET_SET_RPM = 3,
CAN_PACKET_SET_POS = 4,
CAN_PACKET_SET_ORIGIN_HERE = 5,
CAN_PACKET_SET_POS_SPD = 6
// ====== Motor Data Structure ======
struct Axis {
uint8_t packet[8];
float serial_pos;
float motor_vel;
int motor_dir;
uint16_t controller_id;
int16_t motor_pos;
int16_t motor_spd;
int16_t motor_cur;
int8_t motor_temp;
int8_t motor_error;
// ====== Initialize FlexCAN Bus Object ======
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> canBus; // Teensy's built-in CAN1
Axis motor;
Serial.println("Starting...");
canBus.begin();
canBus.setBaudRate(1000000); // Set CAN baud rate to 1Mbps
// Setup motor with CubeMars motor ID
setup_motor(&motor,0x00, 1); // Controller ID = 0, Direction = 1
// Enter motor control mode
uint8_t enter_control_mode[8] = {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC};
send_can_packet(motor.controller_id, enter_control_mode, sizeof(enter_control_mode));
Serial.println("Sent: Enter Motor Control Mode");
// Handle CAN events
comm_can_set_rpm(motor, 1000.0); // Example: Set motor RPM to 1000
// Listen for incoming messages
CAN_message_t rxMsg;
if (canBus.read(rxMsg)) {
process_can_message(&motor, rxMsg);
debug_motor(&motor);
delay(100); // Delay to prevent spamming the CAN bus
// ====== Motor Initialization ======
void setup_motor(Axis *axis, uint8_t id, int dir) {
axis->controller_id = id;
axis->motor_dir = dir;
// ====== Send a CAN Packet ======
void send_can_packet(uint32_t id, uint8_t *data, uint8_t len) {
CAN_message_t txMsg;
txMsg.id = id;
txMsg.len = len;
txMsg.flags.extended = 1; // Use Extended ID (needed for CubeMars motors)
memcpy(txMsg.buf, data, len);
canBus.write(txMsg);
// ====== Set Motor RPM ======
void comm_can_set_rpm(Axis &axis, float rpm) {
uint32_t id = axis.controller_id | (CAN_PACKET_SET_RPM << 8);
uint8_t buffer[4];
int32_t index = 0;
buffer_append_int32(buffer, (int32_t)(rpm * axis.motor_dir), &index);
send_can_packet(id, buffer, sizeof(buffer));
// ====== Process Incoming CAN Messages ======
void process_can_message(Axis *axis, const CAN_message_t &rxMsg) {
if ((rxMsg.id & 0xFF) == axis->controller_id) {
axis->motor_pos = (rxMsg.buf[0] << 8) | rxMsg.buf[1];
axis->motor_spd = (rxMsg.buf[2] << 8) | rxMsg.buf[3];
axis->motor_cur = (rxMsg.buf[4] << 8) | rxMsg.buf[5];
axis->motor_temp = rxMsg.buf[6];
axis->motor_error = rxMsg.buf[7];
// ====== Debug Function to Print Motor Data ======
void debug_motor(Axis *axis) {
Serial.print("Motor ID: "); Serial.println(axis->controller_id);
Serial.print("Position: "); Serial.println(axis->motor_pos);
Serial.print("Speed: "); Serial.println(axis->motor_spd);
Serial.print("Current: "); Serial.println(axis->motor_cur);
Serial.print("Temperature: "); Serial.println(axis->motor_temp);
Serial.print("Error: "); Serial.println(axis->motor_error);
// ====== Append int32 to Buffer ======
void buffer_append_int32(uint8_t *buffer, int32_t data, int32_t *index) {
buffer[(*index)++] = (data >> 24) & 0xFF;
buffer[(*index)++] = (data >> 16) & 0xFF;
buffer[(*index)++] = (data >> 8) & 0xFF;
buffer[(*index)++] = data & 0xFF;
When posting your code, please post it using the </> button. This maintains the code formatting and makes it easier for others to understand your code and be able to help.
Unfortunately I have not used the CAN bus so I am unable to help you.
Below is what the code looks like when pasted correctly formatted.
struct Axis {
    uint8_t packet[8];
    float serial_pos;
    float motor_vel;
    int motor_dir;
    int16_t motor_pos;
    int16_t motor_spd;
    int16_t motor_cur;
    int8_t motor_temp;
    int8_t motor_error;
Axis motor;
    canBus.begin();
    setup_motor(&motor, 0x00, 1); // Controller ID = 0, Direction = 1
    uint8_t enter_control_mode[8] = { 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC };
void setup_motor(Axis* axis, uint8_t id, int dir) {
void send_can_packet(uint32_t id, uint8_t* data, uint8_t len) {
    txMsg.id = id;
    txMsg.len = len;
void comm_can_set_rpm(Axis& axis, float rpm) {
    uint8_t buffer[4];
    int32_t index = 0;
void process_can_message(Axis* axis, const CAN_message_t& rxMsg) {
void debug_motor(Axis* axis) {
void buffer_append_int32(uint8_t* buffer, int32_t data, int32_t* index) {
If you're using CAN3 you should initialize the FlexCAN Bus object like so:
C++:
FlexCAN_T4<CAN3, RX_SIZE_256, TX_SIZE_16> canBus; // Teensy's built-in CAN3
Paul
The MCP2551 is a 5v device with a 5v on the logic pin. The Teensy 4.1 is not tolerant on its input, you will damage the Teensy if it receives 5v.
Try and use the MCP2562 instead. It has a separate VIO pin for the logic.
what if i use a logic level shifter ?
Yes, you can use a level shifter but your Teensy 4.1 might have already been damaged if you applied 5v to its input.
Try to use CAN1 or CAN2 instead of CAN3.
In addition to what everyone else said, make sure you terminate the CAN bus. It will NOT work if there is no termination at all. The proper resistance of the bus is 60 ohms - 120 on each end. The motor should be terminated and your board also should be terminated.
