I am trying to use the FPB unit on teensy4.1, and I *thought* I had it working but when an
address that is loaded into FP_COMPN is hit the board locks up. Then I read that FPB
apparently (note I am not an ARM expert by any means) looks like a BKPT to the ARM.
For teensy4, bkpt 251 is used to enter HalfKay, so does that mean that any BKPT
(to include FPB-invoked) will cause the running firmware to transition to HalfKay?
Fundamental question: can the FPB be used for breakpoints on teensy4?
Tx
Ed
Sorry if there's answers out there on this.
I did a quick search for BKPT, FPB and Teensy4 but didn't find any relevant posts.
UPDATE:
After posting this question it occurred to me that I can run the following test...
Establish the breakpoint using FPB, then run the code that will cause the address
to be hit (causing the lockup). Then attempt to run teensy_loader. If that is
successful (which it was), that means that FPB/BKPT can't be used with Teensy4
for debugging. If this is true, is there any other way to insert a breakpoint?
Tx
Ed
UPDATE:
