Can OctoWS2811 and Audio Adaptor Board work together?
FAlameda
Greetings,
I am planning a project that requires a crude sampling of audio and manage a modest group of LED strips. Although I do not need a lot of power: audio sampling 8 bits at 10kHz and 100..200 RGB LEDs at 25 frames per second, I have been impressed by the great power of Audio Adaptor Board for Teensy 3.0 & 3.1 and OctoWS2811 LED Library.
At first glance these two parts are incompatible as various physical pins (6, 7, 12, 14,15) collide and I suspect that code reassign or physically rewire these pins is far beyond the capacity of a newcomer.
Has anyone managed to make work together these two powerful pieces?
(sorry for my English)
This hasn't been tried, but it's on my list of stuff to investigate.
I believe it should be possible to use the audio in/out together with octows2811, but you definitely will not be able to also use the SD card.
