Currently there is a commented out piece of code at the start of release()
that I feel would be useful to uncomment:
Passing on the requirement to check for NULL to the clients of this call just makes for complicated boiler-plate
code in various update() functions throughout the audio library, and this is a route for obscure pattern-sensitive
bugs to creep in. Currently getting this wrong crashes the system too which is not so friendly to debug.
In many places NULL for an audio block is taken to be equivalent to a block of all zeros, so I think the basic
operations should be happy to handle a NULL audio_block_t pointer.
For example I'd like to be able to code like this:
And I'd make the same comment about the transmit() method, it shouldn't crash the system if you
happen to pass NULL to it, but simply retun gracefully.
// Release ownership of a data block. If no
// other streams have ownership, the block is
// returned to the free pool
void AudioStream::release(audio_block_t *block)
//if (block == NULL) return;
uint32_t mask = (0x80000000 >> (31 - (block->memory_pool_index & 0x1F)));
uint32_t index = block->memory_pool_index >> 5;
__disable_irq();
if (block->ref_count > 1) {
block->ref_count--;
//Serial.print("reles:");
//Serial.println((uint32_t)block, HEX);
memory_pool_available_mask[index] |= mask;
if (index < memory_pool_first_mask) memory_pool_first_mask = index;
memory_used--;
__enable_irq();
void AudioWhatever::update(void)
audio_block_t b0 = receiveReadonly (0) ;
audio_block_t b1 = receiveReadWrite (1) ;
audio_block_t b2 = receiveReadonly (2) ;
audio_block_t b3 = allocate() ;
if (b0 == NULL or b1 == NULL or b2 == NULL or b3 == NULL)
release (b0) ; release (b1) ; release (b2) ; release (b3) ;
return ;
