Can the Teensy 4.1 handle 5V TTL serial on the UART?
I am porting an application from an Arduino Mega to a Teensy 4.1. This application communicates to a 5 volt TTL serial port. Can the Teensy 4.1 handle this or do I need a level shifter?
Don
According to 1060 electrical manual, GPIO max input voltage is limited to whatever voltage is presented on NVCC_xxxx supply rails. In the case of Teensy 4.x, this is 3.3V.
So, don't present a voltage >3.3V to ANY of Teensy pins.
@aleglakov is correct if Teensy was powered from 3.6V, but it's not.
@Dsolberg8132, if you provide details of the serial device you are connecting to Teensy, we can most likely confirm it's serial input/output voltage levels.
