Can't compile most Audio library examples
nicolas_soundforce
He guys,
I got my teensy 3.1 and audio adapter running.
I can upload my usual non-audio code. But anything audio (examples) won't compile.
The SPI library seems to be the problem. Any clue on how to fix it ?
Any audio example gets my this kind of error :
HTML:
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
Arduino: 1.0.6 + Td: 1.20 (Mac OS X), Board: "Teensy 3.1"
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_init()':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:100:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_read_id(unsigned char*)':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:142:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'unsigned char flash_read_status()':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:156:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_hard_reset()':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:177:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_chip_erase(boolean)':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:199:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_erase_pages_sector(int)':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:222:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_erase_pages_block32k(int)':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:246:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_erase_pages_block64k(int)':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:270:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_page_program(unsigned char*, int)':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:294:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_read_pages(unsigned char*, int, int)':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:322:3: error: 'SPI' was not declared in this scope
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp: In function 'void flash_fast_read_pages(unsigned char*, int, int)':
/Users/SoundForce/Documents/Arduino/libraries/Audio/flash_spi.cpp:347:3: error: 'SPI' was not declared in this scope
Thanks in advance,
Nicolas.
Make sure #include <SPI.h> is at the top of your code, old examples in the library have not been updated to include this.
Delete your old, obsolete copy from /Users/SoundForce/Documents/Arduino/libraries/Audio
Teensyduino 1.20 installed the latest copy of the library. Arduino is trying to use the very old copy you installed previously, because libraries in /Users/SoundForce/Documents/Arduino/libraries override the ones installed inside Arduino.
thank you paul, that fixed the problem.
