Hello,
I am building a trigger generator to test some old school CDI ignition box. Old, yes, but 45kV for 11'000 rpm racing V8.
I will use a standard plug and check visualy the spark. But this will not tell me the quality of the spark.
The main defect on these old boxes are in the 450V capacitors in the primary circuit. The capacitance is lower after years, and temperature abuse. The energy/voltage is still present to generate a spark in air, but much lower. And when running, the engine will stutter.
Is there any well known circuit connected directly to the secondary coil, in order to measure the spark quality ?
Clearly a voltage divider to lower the value from 45kv to some volts.
A series resistor to measure the current ?
I have found close to nothing. There are some automotive voltmeters, but they only give an aproximate value.
Any guidance welcome
Angelo
Angelo
