h4yn0nnym0u5e
I don't see why you can't provide an example. Even if you don't currently have the Arduino IDE installed, it's simple enough to do, and probably more productive than "[playing] a lot with buffer values". It is also the canonical method for this forum of providing a worked example for a code maintainer to start from - otherwise they're just thrashing about in the dark. If you can produce a demonstration sketch, then the fault lies either in that (which should be apparent for a simple sketch), or in the library, in which case it can be fixed for the benefit of all users. If you can't then as you say the problem lies in your code, which only you can fix.As much as i would like to do that i don't think i will be able to provide it and probably is an issue coming from other parts of the code.
I was hoping it is kind of a known issue because of some changed code in variablePlayback.
Please ignore my issue as long as it is not reported by others with a more manageable code base.
To be fair, sometimes a bunch of words can at least trigger a "try this" response, as in post #119 above. But if "this" doesn't work, the next request will always be "show me a small example". If that's not forthcoming, chances are high that even if there is a bug, it will not be addressed until someone can be bothered to make the effort to create the example.
