code explanation on a: http: 3.5inch_SPI_Module_ILI9488
//could someone please explain this section of code: I
//http://www.lcdwiki.com/3.5inch_SPI_Module_ILI9488_SKU:MSP3520#top=============================================================================
// do i comment out one area for a teensy 4.1 and a different for 3.6?
// I will start coding on a 3.6 and move it over to a 4.1 when I have it working
//display ILI9488 9488_colortest=============================================================================
#include <ILI9488_t3.h>
#include <ILI9488_t3_font_Arial.h>
#include <ILI9488_t3_font_ArialBold.h>
//#define TEENSY64
#if defined(__MK66FX1M0__) && !defined(TEENSY64) // this line
#define TFT_RST 255
#define TFT_DC 20
#define TFT_CS 21
ILI9488_t3 tft = ILI9488_t3(&SPI, TFT_CS, TFT_DC, TFT_RST);
#elif defined(__IMXRT1052__) || defined(__IMXRT1062__) // this line
// On Teensy 4 beta with Paul's breakout out:
// Using pins (MOSI, MISO, SCK which are labeled on Audio board breakout location
// which are not in the Normal processor positions
// Also DC=10(CS), CS=9(BCLK) and RST 23(MCLK)
#define TFT_RST 23
#define TFT_DC 9
#define TFT_CS 10
#elif defined(TEENSY64) // this line
#define TFT_RST 255
#define TFT_DC 20
#define TFT_CS 21
#define TFT_SCK 14
#define TFT_MISO 39
#define TFT_MOSI 28
ILI9488_t3 tft = ILI9488_t3(&SPI, TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO);
#else
#error "This example App will only work with Teensy 3.6 or Teensy 4."
// Setup
TEENSY64 is a Commodore C64 emulation that runs on T3.6, by Frank Boesing. If you are running that emulation you would un-comment the #define TEENSY64. After that, the conditional logic means:
if (T3.6 and NOT running TEENSY64)
    use these T3.6 pins
else if (T4.x)
    use these normal T4.x pins
else if (TEENSY64)
    use these special pin assignments
    error
so this would be the correct setup?:
//#define TEENSY64
#define TFT_RST 255//*****************************is this a typo?
#define TFT_DC 20
#define TFT_CS 21
#define TFT_RST 23
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 255
#define TFT_DC 20
#define TFT_CS 21
#define TFT_SCK 14
#define TFT_MISO 39
#define TFT_MOSI 28
#else
// Setup
Reset of 255 means you are not using a reset pin. You should then wire any reset pin on the display to 3.3v
on the 3.6 it helps to have the DC/CS pins on hardware CS pins. Which 20 and 21 are.
On t4.x it might help a little if DC is on an hardware CS pin. Pin 10 is one, which the code looks like it is using for CS 9 it shows for DC is not
But again the gains are not as dramatic on the T4.x for this.
