code size curiosity T3 vs T2
stevech
Not an issue at the moment, but as has been previously noted, there seems to be some unused code included in ARM builds and/or needed GCC optimizer mode choice improvements...
The RFM22B radio library and demo build:
Teensy 3.1:
Binary sketch size: 21,780 bytes (of a 262,144 byte maximum)
Estimated memory use: 3,544 bytes (of a 65,536 byte maximum)
Teensy 2:
Binary sketch size: 9,450 bytes (of a 32,256 byte maximum)
Estimated memory use: 577 bytes (of a 2,560 byte maximum)
One might expect the ARM to be 50% or so larger due to average instruction length differences.
This isn't a high priority issue now, but someday it may be.
Plenty of flash and RAM in the T3.1!
