Communicated with ADC122S101 chip using SPI
Ori1
Trying using ADC122S101 chip with ADC08XS.h library, Issue is that no address sending from Teensy4.1, MOSI, to the chip.
There is 2 channel on it and all time getting the data just from first channel.
With sketch that I use just spi.h library with Teensy4.1 it seems that data sending out.
Arduino library for ADC08XS ADC (SPI).
What should be changed to get it to work with the library.
const int SS_PIN = 10; // Replace with your SS pin
const int SPI_MOSI = 11;
const int SPI_MISO = 12;
const int SPI_SCK = 13;
const int RST_PIN = 22;
pinMode(SS_PIN, OUTPUT);
digitalWrite(SS_PIN, HIGH);
SPI.begin();
pinMode(RST_PIN, OUTPUT); //OUTPUT_OPENDRAIN
digitalWrite(RST_PIN, LOW);
digitalWrite(RST_PIN, HIGH);
delay(2);
delay(2);
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE3));
digitalWrite(SS_PIN, LOW); // Select device
SPI.transfer(0x08); // Send address
uint16_t data = SPI.transfer(0x08) << 8; // Read data
digitalWrite(SS_PIN, HIGH); // Deselect device
// Do something with the received data
Serial.println(data, DEC); // Print data in hexadecimal format
delay(100); // Optional delay for testing
You may want to open an issue at https://github.com/RobTillaart/ADC08XS/issues.
Rob Tillaart is very responsive and actually this current issue might be relevant to you.
Paul
I opened an issue already and he try to help me , but it still not working.
Library that work with arduino uno not working with Teensy4.1, what could be the gap between them?
What I show above that other sketch working, with spi communication between teensy and the chip then It's not seems that is hardware issue
