MSC USB Drive basic directory list example
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 08 Apr 2023
by Warren Watson
#include <USBHost_t36.h>
// Setup USBHost_t36 and as many HUB ports as needed.
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
// Setup MSC for the number of USB Drives you are using. (one for this
// example). Mutiple USB drives can be used. Hot plugging is supported.
USBDrive myDrive(myusb);
USBFilesystem firstPartition(myusb);
// Volume name buffer
char volumeName[32];
elapsedMillis mscTimeOut;
uint8_t errCode = MS_CBW_PASS;
// Wait for port to open:
while (!Serial) {
yield(); // wait for serial port to connect.
// Start USBHost_t36, HUB(s) and USB devices.
myusb.begin();
// There is a slight delay after a USB MSC device is plugged in which
// varys with the device being used. The device is internally
// initializing.
Serial.print("\nInitializing USB MSC drive...\n");
mscTimeOut = 0;
while(!myDrive) {
if((mscTimeOut > MSC_CONNECT_TIMEOUT) && (myDrive.errorCode() == MS_NO_MEDIA_ERR)) {
Serial.println("No drive connected yet!!!!");
Serial.println("Connect a drive to continue...\n");
while(!myDrive);
delay(1);
mscTimeOut = 0;
// Wait for claim proccess to finish.
// But not forever.
while(!firstPartition) {
myusb.Task();
if(mscTimeOut > MSC_CONNECT_TIMEOUT) {
Serial.print("Timeout --> error code: ");
Serial.println(myDrive.errorCode(), DEC);
Serial.println("Halting...");
while(1);
delay(1);
Serial.println("initialization done.");
// Get the volume name if it exists.
firstPartition.mscfs.getVolumeLabel(volumeName, sizeof(volumeName));
Serial.println("\nDirectory Listing:");
Serial.print("Volume Name: ");
Serial.println(volumeName);
File root = firstPartition.open("/");
printDirectory(root, 0);
Serial.println("done!");
// nothing happens after setup finishes.
void printDirectory(File dir, int numSpaces) {
while(true) {
File entry = dir.openNextFile();
if (! entry) {
//Serial.println("** no more files **");
printSpaces(numSpaces);
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numSpaces+2);
// files have sizes, directories do not
printSpaces(48 - numSpaces - strlen(entry.name()));
Serial.print(" ");
Serial.printf(F("%10ld"),entry.size()); // Formatted filesize.
DateTimeFields datetime;
if (entry.getModifyTime(datetime)) {
printSpaces(4);
printTime(datetime);
entry.close();
void printSpaces(int num) {
for (int i=0; i < num; i++) {
Serial.print(" ");
void printTime(const DateTimeFields tm) {
const char *months[12] = {
"January","February","March","April","May","June",
"July","August","September","October","November","December"
for(uint8_t i = 0; i <= 1; i++) Serial.printf(F(" "));
Serial.printf(F("%9s %02d %02d %02d:%02d:%02d"), // Show date/time.
months[tm.mon],tm.mday,tm.year + 1900,
tm.hour,tm.min,tm.sec);
