compilation failures in ILI9341 libraries
Fenichel
I am trying to connect an ILI9341 display unit to a Teensy 4.1, running the Teenyduino IDE (2.3.6) under Windows 10.. The IDE is running normally with other sketches. When I try to run the graphicstext example from the ILI9341_t3 library, the compiler says
In file included from C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved202549-5368-dw4pcp.wghb7\graphicstest\graphicstest.ino:18:
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoNotFull()':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:178:30: error: 'KINETISK_SPI0' was not declared in this scope
  178 |                         sr = KINETISK_SPI0.SR;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoEmpty()':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:187:30: error: 'KINETISK_SPI0' was not declared in this scope
  187 |                         sr = KINETISK_SPI0.SR;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitTransmitComplete()':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:193:26: error: 'KINETISK_SPI0' was not declared in this scope
  193 |                 while (!(KINETISK_SPI0.SR & SPI_SR_TCF)) ; // wait until final output done
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:193:45: error: 'SPI_SR_TCF' was not declared in this scope; did you mean 'LPSPI_SR_TCF'?
      |                                             LPSPI_SR_TCF
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:194:23: error: 'KINETISK_SPI0' was not declared in this scope
  194 |                 tmp = KINETISK_SPI0.POPR;                  // drain the final RX FIFO word
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writecommand_cont(uint8_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:197:17: error: 'KINETISK_SPI0' was not declared in this scope
  197 |                 KINETISK_SPI0.PUSHR = c | (pcs_command << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_CONT;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:197:65: error: 'SPI_PUSHR_CTAS' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:197:85: error: 'SPI_PUSHR_CONT' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata8_cont(uint8_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:201:17: error: 'KINETISK_SPI0' was not declared in this scope
  201 |                 KINETISK_SPI0.PUSHR = c | (pcs_data << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_CONT;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:201:62: error: 'SPI_PUSHR_CTAS' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:201:82: error: 'SPI_PUSHR_CONT' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata16_cont(uint16_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:205:17: error: 'KINETISK_SPI0' was not declared in this scope
  205 |                 KINETISK_SPI0.PUSHR = d | (pcs_data << 16) | SPI_PUSHR_CTAS(1) | SPI_PUSHR_CONT;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:205:62: error: 'SPI_PUSHR_CTAS' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:205:82: error: 'SPI_PUSHR_CONT' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writecommand_last(uint8_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:210:17: error: 'KINETISK_SPI0' was not declared in this scope
  210 |                 KINETISK_SPI0.SR = SPI_SR_TCF;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:210:36: error: 'SPI_SR_TCF' was not declared in this scope; did you mean 'LPSPI_SR_TCF'?
      |                                    LPSPI_SR_TCF
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:211:65: error: 'SPI_PUSHR_CTAS' was not declared in this scope
  211 |                 KINETISK_SPI0.PUSHR = c | (pcs_command << 16) | SPI_PUSHR_CTAS(0);
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata8_last(uint8_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:216:17: error: 'KINETISK_SPI0' was not declared in this scope
  216 |                 KINETISK_SPI0.SR = SPI_SR_TCF;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:216:36: error: 'SPI_SR_TCF' was not declared in this scope; did you mean 'LPSPI_SR_TCF'?
      |                                    LPSPI_SR_TCF
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:217:62: error: 'SPI_PUSHR_CTAS' was not declared in this scope
  217 |                 KINETISK_SPI0.PUSHR = c | (pcs_data << 16) | SPI_PUSHR_CTAS(0);
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata16_last(uint16_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:222:17: error: 'KINETISK_SPI0' was not declared in this scope
  222 |                 KINETISK_SPI0.SR = SPI_SR_TCF;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:222:36: error: 'SPI_SR_TCF' was not declared in this scope; did you mean 'LPSPI_SR_TCF'?
      |                                    LPSPI_SR_TCF
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:223:62: error: 'SPI_PUSHR_CTAS' was not declared in this scope
  223 |                 KINETISK_SPI0.PUSHR = d | (pcs_data << 16) | SPI_PUSHR_CTAS(1);
exit status 1
If I instead try demosauce from the ILI9341_t3n library, the compiler says
In file included from C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved202549-5368-9rdn0m.icc58\demosauce\demosauce.ino:34:
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved202549-5368-9rdn0m.icc58\demosauce\PlasmaCloud.h: In member function 'virtual void PlasmaCloud::perFrame(ILI9341Wrapper&, FrameParams)':
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved202549-5368-9rdn0m.icc58\demosauce\PlasmaCloud.h:97:50: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
   97 |                         PointU8 d0 = PointU8{ abs(p0.x - x), abs(p0.y - y) };
In file included from c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\cstdlib:75,
                 from c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\stdlib.h:36,
                 from C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4/WProgram.h:34,
                 from C:\Users\rrf\AppData\Local\arduino\sketches\AAFA72CAB5FA3D864B778564C327D915\pch\Arduino.h:6:
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\stdlib.h:70:9: note: candidate: 'int abs(int)'
   70 | int     abs (int);
In file included from c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\cstdlib:77,
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:79:3: note: candidate: 'constexpr long double std::abs(long double)'
   79 |   abs(long double __x)
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:75:3: note: candidate: 'constexpr float std::abs(float)'
   75 |   abs(float __x)
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:71:3: note: candidate: 'constexpr double std::abs(double)'
   71 |   abs(double __x)
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:61:3: note: candidate: 'long long int std::abs(long long int)'
   61 |   abs(long long __x) { return __builtin_llabs (__x); }
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:56:3: note: candidate: 'long int std::abs(long int)'
   56 |   abs(long __i) { return __builtin_labs(__i); }
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved202549-5368-9rdn0m.icc58\demosauce\PlasmaCloud.h:97:65: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
   70 | int     abs (int);
   75 |   abs(float __x)
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved202549-5368-9rdn0m.icc58\demosauce\PlasmaCloud.h:98:50: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
   98 |                         PointU8 d1 = PointU8{ abs(p1.x - x), abs(p1.y - y) };
   70 | int     abs (int);
   75 |   abs(float __x)
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved202549-5368-9rdn0m.icc58\demosauce\PlasmaCloud.h:98:65: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
   70 | int     abs (int);
   75 |   abs(float __x)
exit status 1
Compilation error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
For what it's worth, the graphicstest sketch in the AdaFruit_ILI9341 package works fine, except for having a default screen size smaller than that of my device.
Maybe the library is corrupted. The system knew that KINETISK_SPI0 is not valid, so probably not building for Teensy 3.x...
What version of Teensy board are you running? I don't believe anything has changed in the main code for that library nor that example
in something like 5 years now.
Note: It looks like your code is building using a version of the ILI9341_t3 library that is in your <sketch book>\libraries directory and not
the version that gets installed with Teensyduino. Maybe remove that one and see if it helps. And/Or update it to the current sources
up at: https://github.com/PaulStoffregen/ILI9341_t3
Looks like you may have a very old (before Teensy 4.0 existed) copy of ILI9341_t3 in your {Documents}/Arduino/libraries folder.
If you put a library into {Documents}/Arduino/libraries, it overrides any other copy. That's a nice feature if you want to do something special or custom. But it becomes a sort of a liability if you put a copy there and forget about it. Then many years later when you want to use that library, you're working with the very old copy rather than the new version that came with installing the latest version of Teensyduino using Arduino IDE's Boards Manager.
Solution is to just delete that old copy, or move it out of {Documents}/Arduino/libraries to some other location on your PC where Arduino IDE doesn't see it.
  1. I searched my C: drive and removed all non-Adafruit files named ILI9341*.*, and I then reloaded the ILI9341_t3, ILI9341_t3n, and ILI9341_T4 libraries by using the library manager in the Teensyduino IDE. The resulting folders were all in Documents/Arduino/libraries.
  2. ILI9341.graphicstest still fails to compile; the first diagnostic is "In file included from C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-8676-jx0ln8.b0pg\graphicstest\graphicstest.ino:18:
    178 | sr = KINETISK_SPI0.SR;"
  3. ILI9341_t3n.demosauce fails to compile, but at first only because the compiler can't find font_Arial.h. If I comment out all of the lines dealing with the Arial fonts, the sketch again fails to compile; the first diagnostic is "In file included from C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-8676-kd2cw9.hdhz\DemoSauce\DemoSauce.ino:30:
    C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-8676-kd2cw9.hdhz\DemoSauce\PlasmaCloud.h: In member function 'virtual void PlasmaCloud::perFrame(ILI9341_t3n, FrameParams)':
    C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-8676-kd2cw9.hdhz\DemoSauce\PlasmaCloud.h:96:52: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
    96 | PointU8 d0 = (PointU8){ abs(p0.x - x), abs(p0.y - y) }
  4. ILI9341_T4.colormelting compiles, and the IDE thinks it is successfully uploaded, but the display is unaffected. The same thing happens with ILI9341_T4.99luftballons.
@Fenichel
I just compiled ILI9341_t3 (the one in Teensyduino) and it compiles not issues for me:
Memory Usage on Teensy 4.0:
  FLASH: code:37592, data:19400, headers:8540   free for files:1966084
   RAM1: variables:19936, code:35808, padding:29728   free for local variables:438816
   RAM2: variables:12416  free for malloc/new:511872
I am using a Teensy 4.0 and beta 4 which was just released and graphics test.
If you want to use the ILI9341_t3n library you will need to also install: https://github.com/mjs513/ILI9341_fonts
@Fenichel
Thanks for your effort. Inasmuch as I just installed the ILI9341_t3 package fresh via the IDE, I don't understand why your results are different from mine, unless my copy of the compiler is corrupted. If no one else has any useful suggestions, I'll try reinstalling the IDE.
Thanks for the link, but (as I noted in post #9) the fonts were only a small part of my problem with ILI9341_t3n.
It is hard to diagnose any of this stuff, with just a few tidbits of information. For example you mention does not compile.
And only show a few lines of information. it might help to see more of the build output
In the case with DemoSauce, you are right it does not currently compile, due to some conflicts with the abs function of floats.
Probably something changed in the compiler or compiler settings in the last few releases.
I have not tried this one out for a long time... Actually they are using stuff, I never heard of or used before.
That is: the are using the types: uint_fast16_t and uint_fast8_t, which I had to look up.
That uint_fast16_t is the fastest unsigned integer that is at least 16 bits wide.
My guess is later compilers don't know what to do with:
abs(x-y);
where x and y and resulst is one of these data types...
But not sure if this is really holding you up? I will probably just add some casting to something like int and be done with it.
Now with others examples that you said built but did not do anything, they are not all setup to use the same IO pins or the like. Sometimes it is whatever the last pins we were testing with.
So you may want to check that the pins and the SPI port matches what you have on your board.
Thanks for your continuing help.
I gave the full diagnostic output for ILI9341_t3.graphicstest in post #1. I hadn't thought of putting the compiler into verbose mode. When I do that with ILI9341_t3.graphicstest, I get
loading library from c:\Users\rrf\Documents\Arduino\libraries\bb_scd41: invalid library: no header files found
FQBN: teensy:avr:teensy41
Using board 'teensy41' from platform in folder: C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0
Using core 'teensy4' from platform in folder: C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0
Detecting libraries used...
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 C:\Users\rrf\AppData\Local\arduino\sketches\4739DF835A871025A8B047954D80B250\sketch\graphicstest.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI C:\Users\rrf\AppData\Local\arduino\sketches\4739DF835A871025A8B047954D80B250\sketch\graphicstest.ino.cpp -o nul
Alternatives for ILI9341_t3.h: [ILI9341_t3@1.0]
ResolveLibrary(ILI9341_t3.h)
  -> candidates: [ILI9341_t3@1.0]
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\arduino\sketches\4739DF835A871025A8B047954D80B250\sketch\graphicstest.ino.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI\SPI.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\ILI9341_t3.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_Arial.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_ArialBlack.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_ArialBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_ArialBoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_ArialItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_AwesomeF000.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_AwesomeF080.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_AwesomeF100.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_AwesomeF180.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_AwesomeF200.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_ChanceryItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_ComicSansMS.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_ComicSansMSBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_CourierNew.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_CourierNewBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_CourierNewBoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_CourierNewItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_Crystal.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_DroidSans.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_DroidSansMono.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_DroidSans_Bold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_DroidSerif_Bold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_DroidSerif_BoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_DroidSerif_Italic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_DroidSerif_Regular.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_Georgia.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_GeorgiaBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_GeorgiaBoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_GeorgiaItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_Impact.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationMono.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationMonoBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationMonoBoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationMonoItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSans.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSansBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSansBoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSansItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSansNarrow.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSansNarrowBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSansNarrowBoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSansNarrowItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSerif.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSerifBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSerifBoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_LiberationSerifItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_Logisoso.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_Michroma.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_Nunito.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_NunitoBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_NunitoLight.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_OpenSans.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_TimesNewRoman.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_TimesNewRomanBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_TimesNewRomanBoldItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\font_TimesNewRomanItalic.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3\glcdfont.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\arduino\sketches\4739DF835A871025A8B047954D80B250\sketch\graphicstest.ino.cpp -o C:\Users\rrf\AppData\Local\Temp\1808388578\sketch_merged.cpp
C:\Users\rrf\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\rrf\AppData\Local\Temp\1808388578\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\1.59.0/precompile_helper" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.59.0/cores/teensy4" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\4739DF835A871025A8B047954D80B250" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.59.0/cores/teensy4" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\4739DF835A871025A8B047954D80B250/pch/Arduino.h" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\4739DF835A871025A8B047954D80B250/pch/Arduino.h.gch"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=159 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\4739DF835A871025A8B047954D80B250/pch" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.59.0\\cores\\teensy4" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.59.0\\libraries\\SPI" "-Ic:\\Users\\rrf\\Documents\\Arduino\\libraries\\ILI9341_t3" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\4739DF835A871025A8B047954D80B250\\sketch\\graphicstest.ino.cpp" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\4739DF835A871025A8B047954D80B250\\sketch\\graphicstest.ino.cpp.o"
In file included from C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-7224-10otzlt.2ur0l\graphicstest\graphicstest.ino:18:
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoNotFull()':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:178:30: error: 'KINETISK_SPI0' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitFifoEmpty()':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:187:30: error: 'KINETISK_SPI0' was not declared in this scope
  187 |                         sr = KINETISK_SPI0.SR;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::waitTransmitComplete()':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:193:26: error: 'KINETISK_SPI0' was not declared in this scope
  193 |                 while (!(KINETISK_SPI0.SR & SPI_SR_TCF)) ; // wait until final output done
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:193:45: error: 'SPI_SR_TCF' was not declared in this scope; did you mean 'LPSPI_SR_TCF'?
      |                                             LPSPI_SR_TCF
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:194:23: error: 'KINETISK_SPI0' was not declared in this scope
  194 |                 tmp = KINETISK_SPI0.POPR;                  // drain the final RX FIFO word
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writecommand_cont(uint8_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:197:17: error: 'KINETISK_SPI0' was not declared in this scope
  197 |                 KINETISK_SPI0.PUSHR = c | (pcs_command << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_CONT;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:197:65: error: 'SPI_PUSHR_CTAS' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:197:85: error: 'SPI_PUSHR_CONT' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata8_cont(uint8_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:201:17: error: 'KINETISK_SPI0' was not declared in this scope
  201 |                 KINETISK_SPI0.PUSHR = c | (pcs_data << 16) | SPI_PUSHR_CTAS(0) | SPI_PUSHR_CONT;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:201:62: error: 'SPI_PUSHR_CTAS' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:201:82: error: 'SPI_PUSHR_CONT' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata16_cont(uint16_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:205:17: error: 'KINETISK_SPI0' was not declared in this scope
  205 |                 KINETISK_SPI0.PUSHR = d | (pcs_data << 16) | SPI_PUSHR_CTAS(1) | SPI_PUSHR_CONT;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:205:62: error: 'SPI_PUSHR_CTAS' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:205:82: error: 'SPI_PUSHR_CONT' was not declared in this scope
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writecommand_last(uint8_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:210:17: error: 'KINETISK_SPI0' was not declared in this scope
  210 |                 KINETISK_SPI0.SR = SPI_SR_TCF;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:210:36: error: 'SPI_SR_TCF' was not declared in this scope; did you mean 'LPSPI_SR_TCF'?
      |                                    LPSPI_SR_TCF
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:211:65: error: 'SPI_PUSHR_CTAS' was not declared in this scope
  211 |                 KINETISK_SPI0.PUSHR = c | (pcs_command << 16) | SPI_PUSHR_CTAS(0);
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata8_last(uint8_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:216:17: error: 'KINETISK_SPI0' was not declared in this scope
  216 |                 KINETISK_SPI0.SR = SPI_SR_TCF;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:216:36: error: 'SPI_SR_TCF' was not declared in this scope; did you mean 'LPSPI_SR_TCF'?
      |                                    LPSPI_SR_TCF
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:217:62: error: 'SPI_PUSHR_CTAS' was not declared in this scope
  217 |                 KINETISK_SPI0.PUSHR = c | (pcs_data << 16) | SPI_PUSHR_CTAS(0);
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h: In member function 'void ILI9341_t3::writedata16_last(uint16_t)':
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:222:17: error: 'KINETISK_SPI0' was not declared in this scope
  222 |                 KINETISK_SPI0.SR = SPI_SR_TCF;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:222:36: error: 'SPI_SR_TCF' was not declared in this scope; did you mean 'LPSPI_SR_TCF'?
      |                                    LPSPI_SR_TCF
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3/ILI9341_t3.h:223:62: error: 'SPI_PUSHR_CTAS' was not declared in this scope
  223 |                 KINETISK_SPI0.PUSHR = d | (pcs_data << 16) | SPI_PUSHR_CTAS(1);
Using library SPI at version 1.0 in folder: C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.59.0\libraries\SPI
Using library ILI9341_t3 at version 1.0 in folder: C:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3
exit status 1
This is telling me you are using the ILI9341_t3 library in your local arduino libraries folder.
when I compile graphicstest in verbose mode I am seeing:
Using library SPI at version 1.0 in folder: C:\Users\Merli\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI
Using library ILI9341_t3 at version 1.0 in folder: C:\Users\Merli\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3
Note its using the library in the teensy install directory with teensy version 0.60.4 :
If you want to update: https://forum.pjrc.com/index.php?threads/teensyduino-1-60-beta-4.76907/
I updated Teensyduino, and I deleted any ILI9341_t3 files still in Documents. (Why does the IDE Library Manager put them there?) ILI9341_t3.graphicstest now compiles,
Using board 'teensy41' from platform in folder: C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4
Using core 'teensy4' from platform in folder: C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 C:\Users\rrf\AppData\Local\arduino\sketches\87B91B6D7BE2EFCD619CCF1364BDF70F\sketch\graphicstest.ino.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI C:\Users\rrf\AppData\Local\arduino\sketches\87B91B6D7BE2EFCD619CCF1364BDF70F\sketch\graphicstest.ino.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\arduino\sketches\87B91B6D7BE2EFCD619CCF1364BDF70F\sketch\graphicstest.ino.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI\SPI.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3\ILI9341_t3.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3\font_Arial.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3\font_ArialBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3\glcdfont.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\arduino\sketches\87B91B6D7BE2EFCD619CCF1364BDF70F\sketch\graphicstest.ino.cpp -o C:\Users\rrf\AppData\Local\Temp\247638776\sketch_merged.cpp
C:\Users\rrf\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\rrf\AppData\Local\Temp\247638776\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\0.60.4/precompile_helper" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4/cores/teensy4" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4/cores/teensy4" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/pch/Arduino.h" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/pch/Arduino.h.gch"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/pch" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\cores\\teensy4" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\SPI" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\sketch\\graphicstest.ino.cpp" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\sketch\\graphicstest.ino.cpp.o"
Compiling libraries...
Compiling library "SPI"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/pch" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\cores\\teensy4" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\SPI" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\SPI\\SPI.cpp" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\SPI\\SPI.cpp.o"
Compiling library "ILI9341_t3"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\cores\\teensy4" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\SPI" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3\\glcdfont.c" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\ILI9341_t3\\glcdfont.c.o"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\cores\\teensy4" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\SPI" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3\\font_ArialBold.c" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\ILI9341_t3\\font_ArialBold.c.o"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/pch" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\cores\\teensy4" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\SPI" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3\\ILI9341_t3.cpp" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\ILI9341_t3\\ILI9341_t3.cpp.o"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\cores\\teensy4" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\SPI" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3\\font_Arial.c" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\ILI9341_t3\\font_Arial.c.o"
Compiling core...
Using precompiled core: C:\Users\rrf\AppData\Local\arduino\cores\teensy_avr_teensy41_usb_serial,speed_600,opt_o2std,keys_en-us_9638674983834e9012786818a930d318\core.a
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\cores\\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.elf" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\sketch\\graphicstest.ino.cpp.o" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\ILI9341_t3\\ILI9341_t3.cpp.o" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\ILI9341_t3\\font_Arial.c.o" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\ILI9341_t3\\font_ArialBold.c.o" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F\\libraries\\ILI9341_t3\\glcdfont.c.o" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/..\\..\\cores\\teensy_avr_teensy41_usb_serial,speed_600,opt_o2std,keys_en-us_9638674983834e9012786818a930d318\\core.a" "-LC:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F" -larm_cortexM7lfsp_math -lm -lstdc++
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.elf" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.eep"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.elf" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.hex"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\0.60.4/teensy_secure" encrypthex TEENSY41 "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.hex"
No key .pem file found, skipping .ehex encryption
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\0.60.4/teensy_post_compile" -file=graphicstest.ino "-path=C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F" "-tools=C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\0.60.4/" -board=TEENSY41
Memory Usage on Teensy 4.1:
  FLASH: code:38776, data:19400, headers:8380   free for files:8059908
   RAM1: variables:20256, code:36080, padding:29456   free for local variables:438496
   RAM2: variables:12416  free for malloc/new:511872
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\0.60.4/stdout_redirect" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.sym" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.elf"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\0.60.4/teensy_size" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.elf"
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\0.60.4/stdout_redirect" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.lst" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\87B91B6D7BE2EFCD619CCF1364BDF70F/graphicstest.ino.elf"
Using library SPI at version 1.0 in folder: C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI
Using library ILI9341_t3 at version 1.0 in folder: C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3
and it uploads and runs, with the serial monitor showing the various demo routines finishing in order. The screen is active, but only in the sense of flashing to all-black a few times.
The diagnostic values Display Power Mode ... Self Diagnostic are all 0x10. The Adafruit version of graphicstest shows each of these values as 0. Is there an available guide to the interpretation of these variables?
Note: I updated the DemoSauce example. (cast them to integer...)
The library manager thinks that the available version is 1.1.1. Is that your latest? Using that one, the compiler looks at demosauce and says
loading library from c:\Users\rrf\Documents\Arduino\libraries\bb_scd41: invalid library: no header files found
FQBN: teensy:avr:teensy41
Detecting libraries used...
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 C:\Users\rrf\AppData\Local\arduino\sketches\609951EA3C0348EB32EED37DE17B75BA\sketch\DemoSauce.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI C:\Users\rrf\AppData\Local\arduino\sketches\609951EA3C0348EB32EED37DE17B75BA\sketch\DemoSauce.ino.cpp -o nul
Alternatives for ILI9341_t3n.h: [ILI9341_t3n@1.1.1]
ResolveLibrary(ILI9341_t3n.h)
  -> candidates: [ILI9341_t3n@1.1.1]
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src C:\Users\rrf\AppData\Local\arduino\sketches\609951EA3C0348EB32EED37DE17B75BA\sketch\DemoSauce.ino.cpp -o nul
Alternatives for font_Arial.h: [ILI9341_t3@1.0]
ResolveLibrary(font_Arial.h)
  -> candidates: [ILI9341_t3@1.0]
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\arduino\sketches\609951EA3C0348EB32EED37DE17B75BA\sketch\DemoSauce.ino.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI\SPI.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src\ILI9341_t3n.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src\glcdfont.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src\ili9341_t3n_font_Arial.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src\ili9341_t3n_font_ArialBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src\ili9341_t3n_font_ComicSansMS.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src\ili9341_t3n_font_OpenSans.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3\ILI9341_t3.cpp -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3\font_Arial.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3\font_ArialBold.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3\glcdfont.c -o nul
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\11.3.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4 -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\SPI -Ic:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src -IC:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3 C:\Users\rrf\AppData\Local\arduino\sketches\609951EA3C0348EB32EED37DE17B75BA\sketch\DemoSauce.ino.cpp -o C:\Users\rrf\AppData\Local\Temp\1597116402\sketch_merged.cpp
C:\Users\rrf\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\rrf\AppData\Local\Temp\1597116402\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-tools\\0.60.4/precompile_helper" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4/cores/teensy4" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\609951EA3C0348EB32EED37DE17B75BA" "C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4/cores/teensy4" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\609951EA3C0348EB32EED37DE17B75BA/pch/Arduino.h" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\609951EA3C0348EB32EED37DE17B75BA/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\rrf\AppData\Local\arduino\sketches\609951EA3C0348EB32EED37DE17B75BA\pch\Arduino.h.gch
"C:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\tools\\teensy-compile\\11.3.1/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10607 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\609951EA3C0348EB32EED37DE17B75BA/pch" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\cores\\teensy4" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\SPI" "-Ic:\\Users\\rrf\\Documents\\Arduino\\libraries\\ILI9341_t3n\\src" "-IC:\\Users\\rrf\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\0.60.4\\libraries\\ILI9341_t3" "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\609951EA3C0348EB32EED37DE17B75BA\\sketch\\DemoSauce.ino.cpp" -o "C:\\Users\\rrf\\AppData\\Local\\arduino\\sketches\\609951EA3C0348EB32EED37DE17B75BA\\sketch\\DemoSauce.ino.cpp.o"
In file included from C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3/font_Arial.h:4,
                 from C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-5048-1glnb3r.4389\DemoSauce\DemoSauce.ino:20:
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3/ILI9341_t3.h:176: warning: "ILI9341_SPICLOCK" redefined
  176 | #define ILI9341_SPICLOCK 30000000
In file included from C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-5048-1glnb3r.4389\DemoSauce\DemoSauce.ino:19:
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src/ILI9341_t3n.h:253: note: this is the location of the previous definition
  253 | #define ILI9341_SPICLOCK 30000000u
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3/ILI9341_t3.h:177: warning: "ILI9341_SPICLOCK_READ" redefined
  177 | #define ILI9341_SPICLOCK_READ 6500000
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src/ILI9341_t3n.h:254: note: this is the location of the previous definition
  254 | #define ILI9341_SPICLOCK_READ 2000000
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3/ILI9341_t3.h:170:3: error: conflicting declaration 'typedef struct ILI9341_t3_font_t ILI9341_t3_font_t'
  170 | } ILI9341_t3_font_t;
In file included from c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src/ILI9341_t3n.h:108,
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src/ILI9341_fonts.h:25:3: note: previous declaration as 'typedef struct ILI9341_t3_font_t ILI9341_t3_font_t'
   25 | } ILI9341_t3_font_t;
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src/ILI9341_t3n.h:1177:29: error: redefinition of 'class ILI9341_Button'
 1177 | #define Adafruit_GFX_Button ILI9341_Button
C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\libraries\ILI9341_t3/ILI9341_t3.h:560:7: note: in expansion of macro 'Adafruit_GFX_Button'
  560 | class Adafruit_GFX_Button {
c:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n\src/ILI9341_t3n.h:1178:7: note: previous definition of 'class ILI9341_Button'
 1178 | class ILI9341_Button {
In file included from C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-5048-1glnb3r.4389\DemoSauce\DemoSauce.ino:30:
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-5048-1glnb3r.4389\DemoSauce\PlasmaCloud.h: In member function 'virtual void PlasmaCloud::perFrame(ILI9341_t3n, FrameParams)':
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-5048-1glnb3r.4389\DemoSauce\PlasmaCloud.h:96:52: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
   96 |                         PointU8 d0 = (PointU8){ abs(p0.x - x), abs(p0.y - y) };
In file included from c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\cstdlib:75,
                 from c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\stdlib.h:36,
                 from C:\Users\rrf\AppData\Local\Arduino15\packages\teensy\hardware\avr\0.60.4\cores\teensy4/WProgram.h:34,
                 from C:\Users\rrf\AppData\Local\arduino\sketches\609951EA3C0348EB32EED37DE17B75BA\pch\Arduino.h:6:
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\stdlib.h:70:9: note: candidate: 'int abs(int)'
   70 | int     abs (int);
In file included from c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\cstdlib:77,
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:79:3: note: candidate: 'constexpr long double std::abs(long double)'
   79 |   abs(long double __x)
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:75:3: note: candidate: 'constexpr float std::abs(float)'
   75 |   abs(float __x)
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:71:3: note: candidate: 'constexpr double std::abs(double)'
   71 |   abs(double __x)
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:61:3: note: candidate: 'long long int std::abs(long long int)'
   61 |   abs(long long __x) { return __builtin_llabs (__x); }
c:\users\rrf\appdata\local\arduino15\packages\teensy\tools\teensy-compile\11.3.1\arm\arm-none-eabi\include\c++\11.3.1\bits\std_abs.h:56:3: note: candidate: 'long int std::abs(long int)'
   56 |   abs(long __i) { return __builtin_labs(__i); }
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-5048-1glnb3r.4389\DemoSauce\PlasmaCloud.h:96:67: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
   70 | int     abs (int);
   75 |   abs(float __x)
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-5048-1glnb3r.4389\DemoSauce\PlasmaCloud.h:97:52: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
   97 |                         PointU8 d1 = (PointU8){ abs(p1.x - x), abs(p1.y - y) };
   70 | int     abs (int);
   75 |   abs(float __x)
C:\Users\rrf\AppData\Local\Temp\.arduinoIDE-unsaved2025410-5048-1glnb3r.4389\DemoSauce\PlasmaCloud.h:97:67: error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
   70 | int     abs (int);
   75 |   abs(float __x)
Using library ILI9341_t3n at version 1.1.1 in folder: C:\Users\rrf\Documents\Arduino\libraries\ILI9341_t3n
exit status 1
Compilation error: call of overloaded 'abs(uint_fast16_t)' is ambiguous
As for ILI9341_t4, not my library, but quick look, I am running the 99luftballons.ino sketch
Did not do anything at first...
Fournd that DC/CS pins were swapped from what this board expects:
DC=10, CS=9 where board is CS=10, DC=7...
Also this board has the touch controller connected on pin 27,
So I added: pinMode(27, OUTPUT); digitalWrite(27, HIGH);
And now I see round things bouncing around the screen
I tried 99luftballons with DC & CS connected per the #defines (10 & 9) and then swapped. My board doesn't have the touch controller connected. so that's not the issue. When I upload 99luftballons (with either cabling), it claims inability to read the board's registers, trying with various SPI speeds down to 0.06 MHz, and it never gets control. Curiously, what results is that the screen goes into a ~1Hz loop alternating between (1) what it happened to be showing before the attempted upload and (2) all white.
