Hi jmarsh thanks for the reply.
The data bus will be used in both directions. If it's possible to get all the address lines to Teensy that would be a better option than latching onto a particular address because the card could have several functions. I need some pins left for the VGA out feature, right now I'm using analogue out with 10 pins used but in the end I want it to be digital out and that may use even more.
Below I've attached the image from Scott Baker's Raspberry Pi to ISA design. He latches a dualport memory buffer on the bus side, and puts a FET bus switch on the GPIO side, so 3 ICs.
Am I right to assume Teensy can do without memory buffer? Unlike RPi running Phyton this is realtime on internal memory.
Thanks,
Z
