Controlling 25 air valves with a teensy 4.0
colorado_hick
I have been working on a pipe organ, takes midi messages and opens one or more air valves so a compressor can blow air into the pipe.
Is there a board that already does this? Otherwise I am looking at buying a bunch of individual solenoids and relays.
Ideally, you’d want an air manifold that spoke one of the older automation standards called MODBUS RTU. There are libraries already written for this standard. If you can’t find that, I’d locate a manifold with a simple integrated wiring harness. Several companies use a simple D-Shell for attaching the raw manifold signals to a PLC. You can then attach that to a MODBUS RTU solid state relay output module to drive the manifold valves. This is the simplest method, and likely the least amount of headache, when making something controlled by a microcontroller. MODBUS RTU can easily support 25 octal output modules across RS-485. MIDI is 31.25 kbps and, depending on the modules used, MODBUS can be 9.6 kbps to 115.2 kbps, maybe faster.
