Creating custom waveforms
tejas
Hello!
I am trying to create a waveform that resembles the recorded sound of an organ. I see two options for doing that.
1. Using arbitraryWaveform(): I would open the recorded sound in audacity and export one wavelength as text data. This is between -1 and +1. I have three questions in this approach.
- The wavelength exported by audacity may not be exactly 256 samples. Should I make them 256? If so, how could I do that?
- What scaling should I use to convert the -1 to +1 range to something suitable for this function?
- The function says that for frequencies higher than 172Hz, one should 'bandwidth limit your waveform data'. How could I do that?
2. Using AudioSynthWavetable: This option uses the SoundFont2 files to load waveforms. However, the software mentioned in the help video
uses https://github.com/TeensyAudio/Wavetable-Synthesis which is quite old and doesn't seem to work properly in newer operating systems.
- Do you have a recommendation for a software that can convert audio to SoundFont2?
- Is there some other way to use AudioSynthWavetable?
Other than these two options, are there other ways to recreate the sound of an organ?
Thank you in advance!
It's called rate conversion, but its important to get it accurate to avoid artifacts, which means accurately measuring the sampled frequency.
Hopefully whatever software you use for the rate conversion also has this as an option. Basically you need a brick-wall low-pass filter applied before rate conversion to keep everything below the Nyquist frequency in the output.
https://www.polyphone-soundfonts.com/
Can be used to create soundfont files
Then I have updated/fixed the soundfont decoder
https://github.com/manicken/SoundFontDecoder
If you want runtime loading there is also
https://forum.pjrc.com/index.php?threads/soundfont-sf2-runtime-loader.74749/
note that the runtime loader is currently using the SD.open function and I don't know if that also includes spi connected sd cards
but either way I can make some changes to also include spi sd connected sd cards if you want to use this option.
