CS42448 board update for T4 pinouts and improved performance
I should also mention, if you were to use I2S instead of TDM, you'd be limited to only 10 channels total (eg, 2 input & 8 output, or 6 input & 4 output, or 8 input & 2 output, etc) due to the way the I2S pins are assigned on Teensy 4.
On Teensy 3.x, the limit for I2S is 4 inputs & 4 outputs.
TDM allows all the inputs and outputs to work simultaneously, and it does this with fewer pins. That's why we always use TDM for CS42448.
Paul,
Thanks.
I forgot that there's a separate TDM driver after a 12 month break from the project. Basics are working again now I'm using TDM ins and outs.
Richard
I am using a CS42448 in one of my projects. I am having a problem with the VQ not initializing to 2.5v consistently. Sometimes it initializes to random values around a volt.
I tried the "magic bit" fix refenced in this post // https://forum.pjrc.com/threads/41371?p=215881&viewfull=1#post215881 But it didn't help. BTW, I am using the Audio library control_cs42448.h and .cpp to init the CS42448.
Have you experienced any VQ=2.5v initialization issues?
I have (finally) published full details of this project - including Gerbers, BoM, schematics and design notes, on my github: https://github.com/palmerr23/AudioToy
Cross posting in the Projects section of the forum includes some photos: https://forum.pjrc.com/threads/68166-AudioToy-modular-8x8-channel-Teensy-4-0-pro-grade-audio-mixer-hardware
palmerr, Congratulations on your achievement. Thank you for sharing this with the community. You've done a really remarkable job at creating this.
Neal,
I haven't had any issues with VQ and haven't needed to tweak the 'magic bit'. I always buffer it before using VQ.
I use the standard Teensy Audio Library CS42448 control, and the only change I make is to turn differential inputs on.
// change ADCs 1-3 (channels 0..5) to differential mode (CS5343 is single ended)
writeRegCS(CS42448I2C, 0x05, 0x00); // (I2C address, register, setting) Paul's setting = 0x1C
Sorry I can't be more help.
Richard
I am just measuring the VQ voltage and not using it to drive anything. Do you have any delays() in your code that enables the CODEC?
Below is my simple test sketch. It simply outputs a sine wave to the CS42448 AOUT1 DAC. When I upload from Arduino it starts fine and VQ=2.5v. If I unplug then replug the USB connecting the Teensy 4.1 to the PC, VQ goes to some random value. Here is the sketch:
AudioSynthWaveformSine sine1; //xy=306,190
AudioOutputTDM tdm1; //xy=573,258
AudioConnection patchCord1(sine1, 0, tdm1, 0); //AOUT1
AudioControlCS42448 cs42448_1; //xy=784,280
AudioMemory(40);
cs42448_1.setAddress(3); // my CS42448 address is 0x03
cs42448_1.enable();
cs42448_1.volume(1.0);
sine1.amplitude(1.0);
sine1.frequency(1000);
Neal,
Your sketch looks fine. I haven't used the setAddress() function, but can't see why that would contribute. I guess you mean the I2C address is 0x48 + 3.
No delays in my startup code:
cs42448_1.enable(); // mutes all outputs
cs42448_1.volume(0.1); // low volumes to start
cs42448_1.inputLevel(0.1);
writeRegCS(CS42448I2C, 0x05, 0x00); // Paul's = 0x1C
Looks like you're not alone with this problem - I read the "magic bit" posts and Paul's mention of it after power up sequence notes in the code.
There's a possibility that it's something to do with the difference between a soft and hard reset.
I haven't asked which hardware you're using - Paul's or custom? Both Paul and I use a CAT811/MAX811 (or similar voltage monitor) to provide the appropriate RST! pulse (I ignore the pin 3 MR! input, a quick look at Paul's Hackaday post indicates that he does also). The alternative is to use a GPIO pin, or a simple RC to do the job.
I'll keep an eye out for the problem on my boards - as I haven't checked VQ since early prototypes. It's always possible that my chips are doing it and I haven't noticed.
