I'm thinking about throwing a teensy on my car battery - I have something which appears to be draining the battery, but it's not always on. (Charging, Starter, Battery all check out fine). So I want to monitor battery voltage and charge/discharge current while off in addition to while the car is running.
Aside from the actual process of diagnosing this in a vehicle - it got me thinking. How DO you accurately measure the 0-25A or so range without frying or impeding perfect valid loads of several hundred amps? I could put something scaled to the normal expected loads after the starter taps into the main 12V line, but that won't catch anything which might be pulling current from the starter line at other times. Assuming the starter can pull 600A or so (just going from the battery rating), that pretty much rules out any sort of resistive current sensor. I can't really think of anything that sensitive that could actually withstand (and not impede) the normal operation of the starter.
Right now, my thinking is put my current monitor after the starter tap, and just use the battery voltage as an indication of substantial load on the starter circuit. Given the cabling of the the starter system - I'm having trouble imagining anything unplanned on that circuit only sucking down a couple amps. If it shorts it's gonna smoke.
