I want to design a Teensy 3.2 clone board with a JTAG header for debugging use, and would like to ask some advice.
To support the normal bootloader, I will add this chip:
https://www.pjrc.com/store/ic_mkl02.html
I will use this board as a base:
https://github.com/thewknd/teensy-boards/tree/master/Teensy 3.2 reference board clone
And add a JTAG header to the board with PTA3 to SWDIO and PTA0 to SWDCLK
(as described here: https://mcuoneclipse.com/2014/08/09/hacking-the-teensy-v3-1-for-swd-debugging/)
* How to disable the MKL04Z32 bootloader chip while debugging over JTAG?
In the Teensy 3.2 reference schematic (https://www.pjrc.com/teensy/schematic32.gif) I see that PTA4 and PTA5 on the MKL04Z32 bootloader chip are tied together with RESET_B on the main chip. I will connect all these to the JTAG RESET pin. Is that enough to disable the MKL04Z32 bootloader while debugging over JTAG, or do I need something extra to disable the chip?
* Suitable debugger
Can somebody suggest a reasonably priced debugger to get? It needs to work with pyOCD on mac os.
(I have several mbed FRDM boards, but if I understand that they are limited to only program the exact same processor)
I am primarily using the teensy 3.2 board with the mbed core.
* Suitable debugger
