Stewieman01
After getting help with Serial communication issues from this great forum I finally got my Custom Teensy 4.1 board working! I'm able to Program it finally and was eager to test my Ethernet connectivity with the DP83825L Ethernet PHY IC (U5 on my layout) and the J1B1211CCD RJ45 Connecter (P1 on my layout), however it doesn't want to cooperate.
While i can get a perceived link as proven by code tests and the activity LED blinking, the board isn't visible in the devices list in my gateway, nor can i ping it from my PC. i have tried both static and dynamic IP address assignment but neither have worked. I intend to use it to host a webserver for remote control of the GPIOs for reference. the following below is the debugging i've done over the past week to root out the problem source:
Hardware debugging:
Software debugging:
Considering the router switch detects activity but the DHCP doesn't and probing has mostly ruled out physical issues, i believe my problems lie with the software potentially, however i don't want to rule out signal integrity as the problem as being custom designed its very likely. below is the screenshot of my board layout and my github is linked here. below is also different sketches i've used for testing for reference as well if anyone is able to point me in the right direction. I have also provided the PHY IC datasheet and the TI design check list that i followed when designing my traces incase that's the issue. I only use this forum as a last resort (as to not clog up the forum) but after a week of various tests, research and troubleshooting, I am running out of potential leads to investigate and I would appreciate any possible help greatly.
Thanks,
Alex
DP83825L datasheet
Texas Instruments PHY Design checklist
Link Test Code
Wire Shark Test Code:
Webserver Test Code (from: https://protosupplies.com/learn/prototyping-system-for-teensy-4-1-working-with-ethernet-2/)
Hardware debugging:
- Checked multiple times the TX and RX differential pairs are appropriately designed with 100 ohm impedance as per the DP83825l datasheet and aren’t too close to noisy traces to create interference.
- Confirmed with DP83825l data sheet and TI PHY design guidelines to confirm the trace layout between the MCU and PHY is correctly done
- Confirmed the PCB footprint for the jack is proper, I’m using the J1B1211CCD connector and the the 0.1uF capacitor per the ethernet kit from teensy.
- When plugged into the switch which is connected to the gateway, the activity LED on the switch port flickered to the tune of the RJ45 jacks LED, signifying that the teensy LED wasn’t a facade. This also indicated that there is some level of traffic between the PHY IC and the Ethernet switch. However The '1000mbps Active' LED on the Ethernet switch wasn't On.
- I attempted to probe the RJ45 transmit pins with my oscilloscope, although I struggled to get a good connection between the RJ45 pins and the probe, However I was able to individually test the TX+ and TX- pins with a passive probe individually and saw common mode noise ranging from ~12-18mHz with a Peak to Peak Voltage of ~1.6V (for both and the RX pins as well). from my research I've seen that a differential probe is required to actually examine signal integrity. However what I've seen on the pins is apparently expected when using a passive probe on Ethernet as its roughly half the differential pair. This test at least verifies signals are being transmitted roughly to the correct tune, but i cant rule out signal integrity issues just yet.
Software debugging:
- Tested ethernet connection with QNEthernet library, can get a LINK status when CAT6 cable is inserted but can’t communicate with DHCP. Cannot be seen on gateway or be pinged.
- The MAC address is retrievable from bootloader and is known
- Created a test program to send the same test packet every second, and the activity LED flickers consistently when sending the packet and is a solid green when not sending.
- When using Wireshark I can’t find any evidence of Activity when filtering for the MAC address or UDP port assigned in the code (I used 9999 for testing)
- Tried both static IP assignment and dynamic to no success, ensuring my gateway and subnet mask are correctly set
Thanks,
Alex
DP83825L datasheet
Link Test Code
C:
// SPDX-FileCopyrightText: (c) 2023 Shawn Silverman <shawn@pobox.com>
// SPDX-License-Identifier: AGPL-3.0-or-later
// LinkWatcher is a simple application that watches the link state
// using a listener. It doesn't try to set an address.
// This file is part of the QNEthernet library.
#include <QNEthernet.h>
using namespace qindesign::network;
// Program setup.
while (!Serial && millis() < 4000) {
// Wait for Serial
printf("Starting...\r\n");
// Listen for link changes
Ethernet.onLinkState([](bool state) {
if (state) {
printf("[Ethernet] Link ON");
// We can use driver capabilities to determine what to print
const auto &dc = Ethernet.driverCapabilities();
if (dc.isLinkSpeedDetectable) {
printf(", %d Mbps", Ethernet.linkSpeed());
if (dc.isLinkFullDuplexDetectable) {
printf(", %s duplex", Ethernet.linkIsFullDuplex() ? "full" : "half");
if (dc.isLinkCrossoverDetectable) {
printf(", %s crossover", Ethernet.linkIsCrossover() ? "is" : "not");
printf("\r\n");
printf("[Ethernet] Link OFF\r\n");
// We just want to watch the link in this example, so don't start DHCP
Ethernet.setDHCPEnabled(false);
if (!Ethernet.begin()) {
printf("ERROR: Failed to start Ethernet\r\n");
// Program loop.
#include <EthernetUdp.h>
////// CONFIGURATION //////
// Pick a static IP that’s valid on your LAN
IPAddress localIp(192, 168, 0, 123);
IPAddress subnetMask(255, 255, 255, 0);
IPAddress gateway(192, 168, 0, 1);
uint8_t mac[6] = { 0x04, 0xE9, 0xE5, 0x1A, 0x56, 0x64 };
// UDP settings
EthernetUDP udp;
const uint16_t UDP_PORT = 9999;
const char* PAYLOAD = "Test packet from Teensy";
while (!Serial && millis() < 2000);
if (!Ethernet.begin(mac, localIp, subnetMask, gateway)) {
Serial.println("Ethernet.begin() failed");
while (1);
Serial.print("IP Address: ");
Serial.println(Ethernet.localIP());
Serial.printf("Link is %s, speed = %uMbps, %s duplex\n",
Ethernet.linkState() ? "UP" : "DOWN",
Ethernet.linkSpeed(),
udp.begin(UDP_PORT);
// send one broadcast packet per second
udp.beginPacket(IPAddress(255, 255, 255, 255), UDP_PORT);
udp.write((const uint8_t*)PAYLOAD, strlen(PAYLOAD));
udp.endPacket();
Serial.println("Packet sent");
Teensy 4.1 WebServer Example
This program reads 6 analog inputs on the Teensy 4.1 and sends the results to
a webpage in a web browser
Modify the IPAddress ip, sn and gw to match your own local network
before downloading the program.
Based on the WebServer example program
This example uses the QNEthernet.h library
// The IP address info will be dependent on your local network
// First 3 numbers must match router, last must be unique
IPAddress ip{10, 0, 0, 12}; // Unique IP
IPAddress sn{255,255,255,0}; // Subnet Mask
IPAddress gw{10,0,0,1}; // Default Gateway
// Initialize the Ethernet server library with the IP address and port
// to use. (port 80 is default for HTTP):
EthernetServer server(80);
// Initialization
// Initialize the library with a static IP so we can point a webpage to it
if (!Ethernet.begin(ip,sn,gw)) {
Serial.println("Failed to start Ethernet\n");
return;
// Just for fun we are going to fetch the MAC address out of the Teensy
// and display it
uint8_t mac[6];
Ethernet.macAddress(mac); // Retrieve the MAC address and print it out
Serial.printf("MAC = %02x:%02x:%02x:%02x:%02x:%02x\n",
mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
// Show whether a cable is plugged in or not.
Serial.printf("[Ethernet] Link %s\n", state ? "ON" : "OFF");
// start the webserver
server.begin();
Serial.print("server is at ");
// Main
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
// Start HTML output to be displayed
client.println("<html>");
client.println("Teensy 4.1 WebServer<br />");
// output the voltage value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
// Convert reading to volts
float volts = sensorReading * 3.3 / 1024.0;
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(volts);
client.println("V<br />");
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
