Admin Edit:
If your Teensy 3.2 is bricked after cutting too deep, info & a solution can be found here:
https://forum.pjrc.com/threads/65611?p=264557&viewfull=1#post264557
I was about to switch from using my breadboard prototype to a full blown manufactured PCB, and I needed to route the USB power out from Teensy and then back into Vin. So as instructed, I cut the trace on the back of the board, and I soldered an extra pin to the Vusb hole.
And my Teensy is bricked
Is anyone able tell me how this trace actually goes and when during the process I might have damaged it during the process? I dont seem to have connection between Vin and the input of the regulator nor the decoupling capacitor there, but i'm not quite sure what I might have done wrong (and I want to do it on another Teensy ;-)
