Lavanya rajan
Hello All,
I'm trying to send data from a Teensy 4.0 controller to a MySQL database. The board I'm using for testing is the Teensy 4.0 Expansion Board, which has an inbuilt ESP chip for data transmission over Wi-Fi.
While I can successfully post data, the interval between postings is currently 10-12 seconds, which is too long. We need the data to be updated every 2 seconds at least. When I attempt to reduce the interval, the connection to the database sometimes fails entirely. Can anyone help me resolve this issue?
attaching the code
attaching the code
String SSID = "xxx";
String PASSWORD = "xxx";
bool prntln = false;
String HOST_NAME = "xxxx";
unsigned long previousMillis = 0;
const long interval = 1000; // Send data every 1 seconds
float c = 25;
float h = 50;
void sendCommand(String command, unsigned long timeout);
Serial1.begin(115200); // Use Serial1 for communication with the ESP8266
delay(2000);
flushSerial();
delay(200);
Serial.println(F("Started"));
// Check communications with the ESP8266
Serial.println("Checking ESP8266 Version...");
sendCommand("AT+GMR", 5000);
Serial.println("Checking AT...");
sendCommand("AT", 5000);
Serial.println("Checking CWMODE...");
sendCommand("AT+CWMODE?", 5000);
Serial.println("Set to Station Mode...");
sendCommand("AT+CWMODE=1", 5000);
Serial.println("List Access points...");
sendCommand("AT+CWLAP", 5000);
Serial.println("Join WiFi....");
String joinstring = "AT+CWJAP=\"";
joinstring += SSID + "\",\"";
joinstring += PASSWORD + "\"";
sendCommand(joinstring, 7000);
Serial.println("Get IP Address...");
sendCommand("AT+CIFSR", 7000);
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
// Time to send data
previousMillis = currentMillis;
// Now, you can establish a connection to the server "cmti-edge.online" on port 80.
Serial.println("Connecting to database...");
sendCommand("AT+CIPSTART=\"TCP\",\"xxxx\",80", 10000);
// Send data to the server using the provided JSON payload and PHP details
String jsonPayload = "{\"hum\":" + String(c) + ",\"temp\":" + String(h) + "}";
String data = "POST /xxx/xxx.php HTTP/1.1\r\n";
data += "Host: " + HOST_NAME + "\r\n";
data += "Content-Type: application/json\r\n";
data += "Content-Length: " + String(jsonPayload.length()) + "\r\n\r\n";
data += jsonPayload;
// Send the HTTP request
String sendRequest = "AT+CIPSEND=" + String(data.length());
sendCommand(sendRequest, 5000);
sendCommand(data, 5000);
if (recFind("CLOSED", 5000, true)) {
Serial.println("CLOSED");
else {
// Your other code or delay can go here to perform other tasks
void sendCommand(String command, unsigned long timeout) {
Serial1.println(command); // Use Serial1 for communication with the ESP8266
if (recFind("OK", timeout, true)) {
Serial.println("Success");
Serial.println("Failed");
void flushSerial() {
while (Serial1.available() >= 1) {
Serial1.read();
bool recFind(String target, uint32_t timeout, bool prntln) {
char rdChar = "";
String rdBuff = "";
unsigned long startMillis = millis();
while (millis() - startMillis < timeout) {
while (Serial1.available() > 0) {
rdChar = Serial1.read();
rdBuff += rdChar;
if (prntln) {
Serial.write(rdChar);
if (rdBuff.indexOf(target) != -1) {
return true;
return false;
