VashJuan
I'm assembling the purple test board to hook up a new Teensy 4.1, Audio Board, and the recommended 3.2 TFT SPI display.
I'm uncertain which way the diode B130 goes. The diode has a bar on the cathode (-) side but I don't find this symbol
in my web search for standard ways to mark diodes on a breadboard. I'm guessing the extra space behind the B13 part of the label is sort of like a negative sign, albeit sideways. So then I'd put - on the left, and + on the right in this orientation. Right?!
The purple boards I just received from OSH Park (https://oshpark.com/shared_projects/TG395I75) do NOT have room for the two 10K resistors, nor room for all 14 pins of the display, the boards only have room for 9 pins.
The 0.1µF capacitor is not marked on the PCB either, but I presume that's what the pads on the back are for. But they are pads, not a through whole connection which is what the specified part (https://www.digikey.com/en/products...draloric-bc-components/K104K15X7RF5TL2/286538) is. Hmmm...
Did I order the right purple boards?! (I followed the link under the photo at https://www.pjrc.com/store/display_ili9341_touch.html.
THANKS!
THANKS!
