I know this is not exactly Teensy related, but I hope you can indulge me since this is just a basic tool that others might be interested in.
My son is joining Hacker Scouts, which will entail lots of kids soldering together in a room. I had some concern about the fumes for the kids, and was thinking that a DIY Fume Extractor could be a project that the kids could assemble.
I was thinking a 120mm computer fan with a carbon filter & hepa filter should do the trick. It seems to me, most fumes are breathed in cause they rise up directly to the person soldering. So this benchtop would just suck it out horizontally outward, and likely capture most of it in the filters. I guess making them easily replaceable would be a plus.
I found this instructable, which doesn't seem bad.
http://www.instructables.com/id/DIY-Fume-Extractor/
But I was thinking that a DC-12V 120mm computer fan might be better for more CFM, but I'm not sure the easiest method for supplying the power from 120V AC.
Any ideas, either for good/inexpensive fan, PS, or case?
Since this would be their first project, I'm thinking the adults can machine the case if need be, but everything else could be assembled by the kids.
Down the road, I think adapting a computer Power Supply would be a good thing for providing bench power to various projects, but that's a little more complicated and requires more caution.
http://www.instructables.com/id/ATX-->-Lab-Bench-Power-Supply-Conversion/
Thanks.
Thanks.
