DIY (Lockable) Teensy 4.1 Board Questions
syvo
Hello Everyone,
I have been using Teensy 4.1 for some of my hobby projects for some time. As I started using it more extensively, I decided to design my own customized PCB. I found that I could order the essential components from PJRC: https://www.pjrc.com/store/ic_mkl02_t4.html
I am also interested in learning the secure (lockable) version of Teensy 4.1 to dive deeper in the topic of ehex and encryption.
The https://www.pjrc.com/store/teensy41.html#codesecurity vaguely says "While Standard and Lockable Teensy are identical hardware, the permanent fuse configuation differs." Then, Sparkfun URLs (standard / lockable) both mention the same MCU: NXP MIMXRT1062DVJ6B.
So, my understanding is that the difference is the permanent fuse state of the same i.MX RT1062 MCU.
I just wanted to confirm that my understanding of https://www.pjrc.com/store/ic_mkl02_t4.html was correct: if I use a blank RT1062 and PJRC’s current pre-programmed Teensy 4.x bootloader chip, will my DIY board be lockable?
Thank you!
Only the fuse settings change between LOCKABLE and UNLOCKABLE, not the 1062 part.
Lower on the last linked PJRC page are the steps required to have the SAME DIY bootloader chip present as LOCKABLE or UNLOCKABLE.
It is the sketches presented for the LOCKING process, or the following sketch that runs and sets the fuses needed to fix them in an UNLOCKABLE state.
Another somewhat related question (given the overall chip shortage): you post only the overall status (In-Stock) and the date of the last IC count, but there is not breakdown per component, neither any count itself.
Question: Is it something possible to inquire in private messages, or are you planning on adding this information to the page I cited (like DigiKey, Mouser, and some other component suppliers do)?
I think it would be helpful to those who work on DIY projects to plan their stock and maybe pre-order some chips from you. Thank you!
