honey_the_codewitch
Edit: Never mind. I solved it. My transfer buffers were too large
I'm trying to do DMA to an LCD using 8-bit instead of 16-bit transfers for a couple of reasons. Firstly, the color depth for IoT screens can usually be set to 18-bit "packed" into a 24-bit pixel. That's 3 bytes per pixel, not 2. Secondly, it can be desirable to avoid the byte swapping during transfer of color data.
The issue is this: I'm getting some weird behavior from sourceBuffer(). The pixel data is currently 2 bytes wide (16-bit) but when I set the sourceBuffer to the total number of bytes it fails with a hard freeze. If I halve the number of bytes it doesn't halt, but the updates aren't quite right.
I'd really like to know what I'm doing incorrectly here.
C++:
bool lcd_spi_driver_t4::flush8_async(int x1, int y1, int x2, int y2, const void* bitmap, bool flush_cache) {
// Don't start one if already active.
if (_dma_state & LCD_SPI_DMA_ACTIVE) {
Serial.println("DMA IN PROGRESS");
return false;
_buffer = (uint16_t*)bitmap;
int w = x2-x1+1;
int h = y2-y1+1;
_count_words = w*h;
_dma_pixel_index = 0;
// count pixels * 2 at 16-bit color
size_t bytes = _count_words * _color_width;
if(flush_cache) {
arm_dcache_flush((void*)_buffer,bytes);
init_dma_settings();
// if I don't do /2 it will crash
_dma_data[_spi_num]._dmasettings[0].sourceBuffer((const uint8_t*)_buffer, bytes/2);
// Start off remove disable on completion from both...
// it will be the ISR that disables it...
_dma_data[_spi_num]._dmasettings[0].TCD->CSR &= ~(DMA_TCD_CSR_DREQ);
_dma_data[_spi_num]._dmasettings[1].TCD->CSR &= ~(DMA_TCD_CSR_DREQ);
begin_transaction();
write_address_window(x1,y1,x2,y2);
_spi_fcr_save = _pimxrt_spi->FCR; // remember the FCR
_pimxrt_spi->FCR = 0; // clear water marks...
// Update TCR to 8 bit mode. .
maybe_update_tcr(LPSPI_TCR_PCS(1) | LPSPI_TCR_FRAMESZ(7) | LPSPI_TCR_RXMSK /*| LPSPI_TCR_CONT*/);
_pimxrt_spi->DER = LPSPI_DER_TDDE;
_pimxrt_spi->SR = 0x3f00; // clear out all of the other status...
_dma_data[_spi_num]._dmatx.triggerAtHardwareEvent(_spi_hardware->tx_dma_channel);
_dma_data[_spi_num]._dmatx = _dma_data[_spi_num]._dmasettings[0];
_dma_data[_spi_num]._dmatx.begin(false);
_dma_data[_spi_num]._dmatx.enable();
_dma_frame_count = 0; // Set frame count back to zero.
_dmaActiveDisplay[_spi_num] = this;
_dma_state &= ~LCD_SPI_DMA_CONT;
_dma_state |= LCD_SPI_DMA_ACTIVE;
return true;
