DMXSerial2 on Teensy
Indi
I'm about to start working out using DMXSerial2 on Teensy(s) for a generic, field configurable DMX fixture controller with RDM. I don't find much chatter about DMXSerial or DMXSerial2 on Teensy. I have Teensy2, Teensy++ & Teensy3.0 to play with. Anyone have experience with DMXSerial on Teensy? Other than configuring pin assignments, any issues I can expect? Can it (or something similar) be added as a library for Teensy?
Hi Paul. Thanks for the reply. I think Teensy is "elegant" and your help is much appreciated.
I'm looking to receive DMX and control a stand-alone collection of LEDs, switches, servos, etc as one "Fixture"...with RDM thrown into the mix. On forums, I see excellent solutions for DMX receivers, pixel controllers, servo controllers, etc...something like a robotic light (scanner, moving head) combines them all...and it seems like Teensy + DMXSerial2 + various libraries & interfaces all working together is a good path to DIY intelligent lighting.
I blocked out some time this month to FINALLY get moving on this. It seems like DMXSerial2 overcomes some serial transceiver issue in Arduino and creates the framework for RDM & mapping channels->functions->pins. I'm just wondering what issues might be anticipated with DMXSerial2, or something like it, on Teensy.
Indi,
I notice that you are working on an RDM responder (slave) project. We are too! We made some hardware (Arduino R3 Shield) which can act as RDM/DMX master or slave. Not sure if you need help on the hardware side of things, but you can easily hook this shield up to the Teensy2 or Teensy3 with a couple of wires. I am working on a tutorial for this now. Check out the shield and let me know if you would like to be one of the first Beta testers. Thanks and talk soon!
http://www.voltvision.com/products_page/led-controllers/dmx_rdm_arduino_shield/
PS- According to the DMX spec, all receivers are supposed to be isolated. We allowed for Isolated assemblies (which cost a little more), or you can get a non-Isolated assembly (costs a little less) and just use an isolated DC power supply (which most are anyway).
Let me know if you have any questions. Thx!
Respectfully,
Steve French
800.664.7256.office
President, Volt Vision
www.voltvision.com
