Does the RTC get powered when the teensy if switched off?
Hi all,
When the teensy is powered off using the push button input, does the RTC remain powered by the Vin or would you still need to connect VBAT?
You need to explain your circuit I think, there is not on/off input defined to my knowledge.
From the T4 product page:
Real Time Clock/Calendar
The RTC is meant for keeping track of date & time. This timeruses a dedicated 32.768 kHz crystal, and continues to run whilepower is off if a 3V coin cell is connected to VBAT.
Hi Mark.
The On/Off input pin, as marked in the diagram. If you connect a push button to this input you can power the teensy down. I need to know whether the RTC will continue to be powered while plugged in (5v supplied to Vin) but in the powered down state.
Just check the schematic, VBAT is tied (via diodes) to the output of the 3.3V regulator (which is apparently redundant anyway since VDD_HIGH_IN is internally connected to VDD_SNVS_IN).
