Doing Arduino Builds - within editor
KurtE
Senior Member+
It has been a while since I have done Arduino builds within sublime text.
Been doing sort of what I have suggested to others to "Eat their own dogfood", which was a saying from the management of a project I was on decades ago.
That is we should use the same hardware/software setup that we expect our customers to use... So been mostly using IDE 2.x...
But I am curious to maybe try out a version of the Arduino CLI, that @PerT posted about on the Arduino forum.
So, was curious if someone like @defragster might have adapted their builds to use the CLI?
just wondering?
Same here. Been using IDE 1.x and 2.x - with 1.x used more often it seems.
Looking at linked thread - I found my account wiped after login with saved creds?
Not seeing overt usage - the TSET just used the IDE CMDLINE text and options.
Yep - I have gotten messages that your credentials are about to expire, and I have to regenerate a new one...
Found doc on the use of the arduino-cli.exe ... https://arduino.github.io/arduino-cli/1.0/getting-started/
In the end it resolved to the standard FQBN ... not sure about all the steps up to there? Creating a config and environment? Just a scan - wondering if it doesn't just use an IDE install but a parallel file set.
gotten messages
Saw something the other week and went and logged in? Back today and same credentials worked - but seems to have opened to an empty account - I had a post or two - not so much as you ... but nothing ...
Yep...
Earlier I found someone had done an Intergration 7 or 8 years ago:
I have it installed, but now trying to remember how to actually set the command options
Been a long while.
Mine did as well... I think there latest update, checks the date... Their license back then probably said, it will allow you to get updates for 3 years... or some such thing.
Upgrade Policy​
Personal licenses come with 3 years of updates. After 3 years, you'll be able to continue to use the last version released within 3 years of purchase (in other words, licenses do not expire). Any versions released 3 years or more after the purchase date will require a paid upgrade to use.
Expiration Date​
Individual licenses are valid for 3 years of updates, but do not expire after 3 years. Only if you wish to use newer versions will an upgrade fee be required.
Just checked and got a notice today that an upgrade license is required in order to upgrade to latest version. But as was said - still can use no issue just cant get any further updates after the 3 year window - which looks like I just hit :)
I see my licenses are noted: 11:38 PM 5/26/2021 and before that 4:52 PM 3/16/2017
Yes, just to limit access to Updates - though trying the access to the above build settings is when I saw it and the github notes didn't seem to work the same with current version
