Rory Maguire
Hi there,
I'm presently building a range of MIDI controllers designed specifically for a piece of theatre playback software called Qlab. This consists of a bunch of buttons outputting MIDI via USB using a Teensy as the heart.
One feature do like to add is being able to trigger two computers from the one button. So I thought I'd have two Teensy chips then just wire each button to both, however that will start to get messy, so I thought, what if I wire one Teensy into the other by soldering them together with standard PCB pins...? Then I'd just wire each button to the top chip and the bottom chip would take its identical signal from the top one...
Will this work? Is there a better, neater way I could achieve this? Is there anything I should watch for or avoid in doing this?
Thanks Y'all!
-Rory Maguire
Thanks Y'all!
-Rory Maguire
