philipTheTech
I have 3 PWM Power controllers and I need to offset the PWN Start times by 30 from each other.
any ideas?
eFlexPwm Simple Example
This example generates 3 pairs of PWM signals on a Teensy 4.1 board
Each signal pair corresponds to the PWMA output and the PWMB (A's complement)
output of an eFlexPWM submodule.
In this example, sub-modules 0, 2 and 3 of PWM2 are used. On the Teensy 4.1 board,
this corresponds to the following pins:
| PWM | SubModule | Pol | Teensy | Native |
| 2 | 0 | A | 4 | EMC_06 |
| 2 | 0 | B | 33 | EMC_07 |
| 2 | 2 | A | 6 | B0_10 |
| 2 | 2 | B | 9 | B0_11 |
| 2 | 3 | A | 36 | B1_02 |
| 2 | 3 | B | 37 | B1_03 |
The frequency is fixed by the constant PwmFreq, here at 18 kHz
On sub-module 0, the duty cycle changes by 5 in 5 from 0 to 100% every 100 PWM periods.
The duty cycle of sub-module 2 is equal to that of sub-module 0 divided by 2.
The duty cycle of sub-module 3 is equal to that of sub-module 0 divided by 4.
This example displays a message on the Serial link (USB CDC), and any error messages:
Submodules successfuly started
#include <Arduino.h>
#include <eFlexPwm.h>
// Definitions
// avoid systematically prefixing objects with the namespace
using namespace eFlex;
// Variables
/* PWM frequence in hz. */
const uint32_t PwmFreq = 30000;
const float DeadTimeNs = 50.0; // deadtime in nanoseconds
// My eFlexPWM submodules (Hardware > PWM2: SM[0], SM[2], SM[3])
SubModule Sm20 (4, 33);
SubModule Sm22 (6, 9);
SubModule Sm23 (36, 37);
all the sub-modules are part of the same timer: PWM2,
Tm2 simplifies access to the functions that concern all the sub-modules
Timer &Tm2 = Sm20.timer();
// the duty cycle in %
uint8_t dutyCyclePercent = 0;
// Code
// initialize LED digital pin as an output.
pinMode (LED_BUILTIN, OUTPUT);
digitalWrite (LED_BUILTIN, HIGH);
Serial.println ("eFlexPwm Simple Example");
// start of PWM configuration -----------------------------------------------
/* Submodule configuration, default values are:
config->debugModeEnabled = false;
config->enableWait = false;
config->reloadSelect = kPWM_LocalReload;
config->clockSource = kPWM_BusClock;
config->prescale = kPWM_Prescale_Divide_1;
config->initializationControl = kPWM_Initialize_LocalSync;
config->forceTrigger = kPWM_Force_Local;
config->reloadFrequency = kPWM_LoadEveryOportunity;
config->reloadLogic = kPWM_ReloadImmediate;
config->pairOperation = kPWM_Independent;
config->pwmFreqHz = 5000;
config->mode = kPWM_CenterAligned;
Config myConfig;
/* Use full cycle reload */
myConfig.setReloadLogic (kPWM_ReloadPwmFullCycle);
/* PWM A & PWM B form a complementary PWM pair */
myConfig.setPairOperation (kPWM_ComplementaryPwmA);
myConfig.setPwmFreqHz (PwmFreq);
/* Initialize submodule 0 */
if (Sm20.configure (myConfig) != true) {
Serial.println ("Submodule 0 initialization failed");
exit (EXIT_FAILURE);
/* Initialize submodule 2, make it use same counter clock as submodule 0. */
myConfig.setClockSource (kPWM_Submodule0Clock);
myConfig.setPrescale (kPWM_Prescale_Divide_1);
myConfig.setInitializationControl (kPWM_Initialize_MasterSync);
if (Sm22.configure (myConfig) != true) {
Serial.println ("Submodule 2 initialization failed");
/* Initialize submodule 3 the same way as submodule 2 */
if (Sm23.configure (myConfig) != true) {
Serial.println ("Submodule 3 initialization failed");
/* Signal and pin configuration, parameters that can be changed :
dutyCyclePercent : Initial PWM pulse width, value should be between 0 to 100
0=inactive signal(0% duty cycle)...
100=always active signal (100% duty cycle)
default value: 50%
level : PWM output active level select, default value: kPWM_HighTrue
deadtimeValue : The deadtime value; only used if channel pair is
operating in complementary mode
default value: 0
faultState : PWM output fault status, default value: kPWM_PwmFaultState0
pwmchannelenable : Enable PWM output, default value: true
Set deadtime count, we set this to about 1000ns for all submodules pins
You can also, modify it for all the pins of a sub-module, eg. :
Sm20.setupDeadtime (deadTimeVal);
or even for a particular pin, eg. :
Sm20.setupDeadtime (deadTimeVal, ChanA);
uint16_t deadTimeVal = ( (uint64_t) Tm2.srcClockHz() * DeadTimeNs) / 1000000000;
Tm2.setupDeadtime (deadTimeVal);
// synchronize registers and start all submodules
if (Tm2.begin() != true) {
Serial.println ("Failed to start submodules");
else {
Serial.println ("Submodules successfuly started");
// end of PWM setup
digitalWrite (LED_BUILTIN, LOW);
// turn the LED on (HIGH is the voltage level)
dutyCyclePercent =30;//+= 5;
/* Update duty cycles for all 3 PWM signals */
Sm20.updateDutyCyclePercent (dutyCyclePercent, ChanA);
Sm22.updateDutyCyclePercent (dutyCyclePercent, ChanA);
Sm23.updateDutyCyclePercent (dutyCyclePercent, ChanA);
Sm22.updateDutyCyclePercent (dutyCyclePercent >> 1, ChanA);
Sm23.updateDutyCyclePercent (dutyCyclePercent >> 2, ChanA);
/* Set the load okay bit for all submodules to load registers from their buffer */
Tm2.setPwmLdok();
if (dutyCyclePercent >= 100) {
dutyCyclePercent = 5;
// turn the LED off by making the voltage LOW
// Delay at least 100 PWM periods
delayMicroseconds ( (1000000U / PwmFreq) * 100);
any ideas?
// Definitions
// Variables
// Code
Config myConfig;
default value: 50%
default value: 0
else {
// end of PWM setup
Tm2.setPwmLdok();
