Error between SparkFunBME280.h and i2c_t3
rhr531
I recently received a project that uses teensy 3.2 and I receive the following error when trying to compile using platform.io ide, any help would be appreciated
In file included from C:\Users\rafa\.platformio\packages\framework-arduinoteensy\libraries\Wire/Wire.h:29,
from .pio\libdeps\teensy31\SparkFun BME280\src/SparkFunBME280.h:39,
from src\main.cpp:36:
C:\Users\rafae\.platformio\packages\framework-arduinoteensy\libraries\Wire/WireKinetis.h:229:16: error: conflicting declaration 'TwoWire Wire'
229 | extern TwoWire Wire;
In file included from src\main.cpp:30:
C:\Users\rafa\.platformio\packages\framework-arduinoteensy\libraries\i2c_t3/i2c_t3.h:1000:15: note: previous declaration as 'i2c_t3 Wire'
1000 | extern i2c_t3 Wire;
C:\Users\rafa\.platformio\packages\framework-arduinoteensy\libraries\Wire/WireKinetis.h:232:16: error: conflicting declaration 'TwoWire Wire1'
232 | extern TwoWire Wire1;
C:\Users\rafa\.platformio\packages\framework-arduinoteensy\libraries\i2c_t3/i2c_t3.h:1002:19: note: previous declaration as 'i2c_t3 Wire1'
1002 | extern i2c_t3 Wire1;
In file included from src\main.cpp:36:
.pio\libdeps\teensy31\SparkFun BME280\src/SparkFunBME280.h:194:39: error: could not convert 'Wire' from 'i2c_t3' to 'TwoWire&'
194 | bool beginI2C(TwoWire &wirePort = Wire); //Called when user provides Wire port
| i2c_t3
src\main.cpp: In function 'void setup()':
src\main.cpp:738:23: error: invalid initialization of reference of type 'TwoWire&' from expression of type 'i2c_t3'
738 | if (!sensor.beginI2C())
.pio\libdeps\teensy31\SparkFun BME280\src/SparkFunBME280.h:194:28: note: in passing argument 1 of 'bool BME280::beginI2C(TwoWire&)'
*** [.pio\build\teensy31\src\main.cpp.o] Error 1
Is there any specific library that works with bme280 and i2c_t3? the library that is indicated on github has apparently been converted to wire.h
Just use default i2c driver with the BME28, i.e., Wire, instead of the i2c_t3 library. Use the Example 1 directly. Cant help more since you didn't post your sketch.
  Get basic environmental readings from the BME280
  By: Nathan Seidle
  SparkFun Electronics
  Date: March 9th, 2018
  License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
  Feel like supporting our work? Buy a board from SparkFun!
  https://www.sparkfun.com/products/14348 - Qwiic Combo Board
  https://www.sparkfun.com/products/13676 - BME280 Breakout Board
  This example shows how to read humidity, pressure, and current temperature from the BME280 over I2C.
  Hardware connections:
  BME280 -> Arduino
  GND -> GND
  3.3 -> 3.3
  SDA -> A4
  SCL -> A5
#include "SparkFunBME280.h"
BME280 mySensor;
  Serial.println("Reading basic values from BME280");
  Wire.begin();
  if (mySensor.beginI2C() == false) //Begin communication over I2C
    Serial.println("The sensor did not respond. Please check wiring.");
    while(1); //Freeze
  Serial.print("Humidity: ");
  Serial.print(mySensor.readFloatHumidity(), 0);
  Serial.print(" Pressure: ");
  Serial.print(mySensor.readFloatPressure(), 0);
  Serial.print(" Alt: ");
  //Serial.print(mySensor.readFloatAltitudeMeters(), 1);
  Serial.print(mySensor.readFloatAltitudeFeet(), 1);
  Serial.print(" Temp: ");
  //Serial.print(mySensor.readTempC(), 2);
  Serial.print(mySensor.readTempF(), 2);
  delay(50);
The problem is that another library in the project uses i2c_t3.h, and using the sensor library (which uses wire.h) creates the conflicts that I pasted in the first post
My guess is that since most libs use standard wire library you are going to see things like
So anywhere in the BME280 library you will probably have to change TwoWire to i2c_t3
bool beginI2C(i2c_t3 &wirePort = Wire);
other thing is to replace Wire.h with i2c_t3.h.
NOTE: you will probably have to do this in both the .h and the .cpp files.
NOTE2: your wire.begin in your sketch (which not posted) will have to change as well:
  Wire.begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_EXT, 400000);
Note: Its been a while since playing this lib.
i'm attaching the code here,
some of the libraries included were changed by the last person who touched this project to use i2c_t3 instead of wire
  • code.txt
Thank you very much, I made the changes you suggested and the errors disappeared, however now I have a lot of warnings and the project does not compile, can you help me?
c:/users/rafae/.platformio/packages/toolchain-gccarmnoneeabi-teensy/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: .pio\build\teensy31\libc58\libWire.a(WireKinetis.cpp.o): in function `i2c0_isr':
WireKinetis.cpp:(.text.i2c0_isr+0x0): multiple definition of `i2c0_isr'; .pio\build\teensy31\lib4e6\libi2c_t3-11.0.a(i2c_t3.cpp.o):i2c_t3.cpp:(.text.i2c0_isr+0x0): first defined here
c:/users/rafae/.platformio/packages/toolchain-gccarmnoneeabi-teensy/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: .pio\build\teensy31\libc58\libWire.a(WireKinetis.cpp.o): in function `i2c1_isr':
WireKinetis.cpp:(.text.i2c1_isr+0x0): multiple definition of `i2c1_isr'; .pio\build\teensy31\lib4e6\libi2c_t3-11.0.a(i2c_t3.cpp.o):i2c_t3.cpp:(.text.i2c1_isr+0x0): first defined here
c:/users/rafae/.platformio/packages/toolchain-gccarmnoneeabi-teensy/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: .pio\build\teensy31\libc58\libWire.a(WireKinetis.cpp.o):(.data.Wire1+0x0): multiple definition of `Wire1'; .pio\build\teensy31\lib4e6\libi2c_t3-11.0.a(i2c_t3.cpp.o):(.bss.Wire1+0x0): first defined here
c:/users/rafae/.platformio/packages/toolchain-gccarmnoneeabi-teensy/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: .pio\build\teensy31\libc58\libWire.a(WireKinetis.cpp.o):(.data.Wire+0x0): multiple definition of `Wire'; .pio\build\teensy31\lib4e6\libi2c_t3-11.0.a(i2c_t3.cpp.o):(.bss.Wire+0x0): first defined here
*** [.pio\build\teensy31\firmware.elf] Error 1
