"Error compiling for board Teensy 4.1." after install TD 1.60.5 after TD 1.59 on IDE 1.8.19
charnjit
i installed TD 1.60.5 after 1.59 on Arduino 1.8.19 @ suggestion for MTP_Teensy
after installation completed PC restarted i got error
C++:
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\Program Files\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766/simple_t4_audio_sd.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\sketch\\simple_t4_audio_sd.ino.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SD\\SD.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FreeStack.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\MinimumSerial.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\ExFatDbg.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\ExFatFile.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\ExFatFilePrint.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\ExFatFileWrite.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\ExFatFormatter.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\ExFatName.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\ExFatPartition.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\ExFatVolume.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\ExFatLib\\upcase.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatDbg.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatFile.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatFileLFN.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatFilePrint.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatFileSFN.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatFormatter.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatName.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatPartition.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FatLib\\FatVolume.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FsLib\\FsFile.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FsLib\\FsNew.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\FsLib\\FsVolume.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SdCard\\SdCardInfo.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SdCard\\SdSpiCard.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SdCard\\SdioTeensy.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SpiDriver\\SdSpiArtemis.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SpiDriver\\SdSpiChipSelect.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SpiDriver\\SdSpiDue.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SpiDriver\\SdSpiESP.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SpiDriver\\SdSpiParticle.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SpiDriver\\SdSpiSTM32.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SpiDriver\\SdSpiSTM32Core.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\SpiDriver\\SdSpiTeensy3.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\common\\FmtNumber.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\common\\FsCache.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\common\\FsDateTime.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\common\\FsName.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\common\\FsStructs.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\common\\FsUtf.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\common\\PrintBasic.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\common\\upcase.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\iostream\\StdioStream.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\iostream\\StreamBaseClass.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\iostream\\istream.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SdFat\\iostream\\ostream.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\LittleFS\\LittleFS.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\LittleFS\\LittleFS_NAND.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\LittleFS\\littlefs\\lfs.c.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766\\libraries\\LittleFS\\littlefs\\lfs_util.c.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766/core\\core.a" "-LC:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766" -larm_cortexM7lfsp_math -lm -lstdc++
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766/simple_t4_audio_sd.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766/simple_t4_audio_sd.ino.eep"
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766/simple_t4_audio_sd.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766/simple_t4_audio_sd.ino.hex"
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/teensy_secure" encrypthex TEENSY41 "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766/simple_t4_audio_sd.ino.hex"
No key .pem file found, skipping .ehex encryption
"C:\\Program Files\\Arduino\\hardware\\teensy/../tools/teensy_post_compile" -file=simple_t4_audio_sd.ino "-path=C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_779766" "-tools=C:\\Program Files\\Arduino\\hardware\\teensy/../tools/" -board=TEENSY41
Opening Teensy Loader...
Could not start Teensy Loader application! (r=1)
  attempted: C:\Program Files\Arduino\hardware\teensy/../tools/\teensy.exe
Using library SD at version 2.0.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD
Using library SdFat at version 2.1.2 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat
Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI
Using library LittleFS at version 1.0.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\LittleFS
quitexit status 1
On every Sketch compile.
i am also seeing.. Teensy.exe not exist in
C:\Program Files\Arduino\hardware\tools
Please reply ..... How to recover it??
And what to Next???
Thank you
As I said on the other post Teensy.exe is in "C:\Program Files (x86)\Arduino\hardware\tools\"
Thank you i got it solved ..
i reinstalled teensuino 1.60.5 after removed all anti-virus and sequirity.
now it is working with all my tested sketches..
sketches are being compiled &uploaded to board.
thank you
