error: reference to 'byte' is ambiguous
charnjit
I was trying mixing codes ( Oled Display ssd_1306 + Keypad + Audio) into one sketch .
first i mixed (Oled Display SSD_1306 + Keypad) ....Display is connected SDA,SCL to Teensy 4.1 pins (18,19).
it is working , i checked. code is below
#include <Keypad.h>              //   working   4x7 keypad and oled Display
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET     -1
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
const byte ROWS = 7; // 7 rows
const byte COLS = 4; //4 columns    //   Analog pin_22 ,  Enc (2,3)  ,
char keys[ROWS][COLS] = {
{1,2,3,4},
{5,6,7,8},
{9,10,11,12},
{13,14,15,16},
{17,18,19,20},
{21,22,23,24},
{25,26,27,28}
byte rowPins[ROWS] = {33,34,35,36,37,38,39}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {40,41,14,16}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
String msg;
    Serial.begin(57600);
      if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
    display.display();
    delay(2000);
    display.clearDisplay();
    msg = "";
    if (kpd.getKeys())
        for (int i=0; i<LIST_MAX; i++)   // Scan the whole key list.
        {   int mykey = (kpd.key[i].kchar);
                      if ( kpd.key[i].stateChanged ) //  ---------------------------------------------------------
            {    switch (kpd.key[i].kstate) {
                    case PRESSED:
                  msg = "  is presed";   SCN_MAIN (mykey);  Serial.println(mykey);  Serial.println("pressed");
                    case RELEASED:
                    msg = "  is Released";   SCN_MAIN (mykey);   Serial.println(mykey);  Serial.println("releassed");
}  // End loop
void SCN_MAIN (int number) {
    display.setTextSize(1);      // Normal 1:1 pixel scale
  display.setTextColor(SSD1306_WHITE); // Draw white text
  display.setCursor(0, 0);     // Start at top-left corner
  display.print(number);  display.print(msg);
   display.display();
Next i made simple (Audio) code from "TeensyVariablePlayback"
i use Serial monitor to input for play .wav file, faster and slower.
it is also working . code is below
// Plays a Wav (16-bit signed) PCM audio file at slower or faster rate
// this example requires an uSD-card inserted to teensy 3.6 with a file called DEMO.WAV
#include <Bounce.h>
#include <Arduino.h>
#include <TeensyVariablePlayback.h>
AudioPlaySdResmp         playSdWav1;     //xy=324,457
AudioOutputI2S           i2s2;           //xy=840.8571472167969,445.5714416503906
AudioConnection          patchCord1(playSdWav1, 0, i2s2, 0);
AudioConnection          patchCord2(playSdWav1, 0, i2s2, 1);
AudioControlSGTL5000     audioShield;
  float Speed = 1.00;
    if (!(SD.begin(BUILTIN_SDCARD))) {
        while (1) {
    AudioMemory(24);
    audioShield.enable();
    audioShield.volume(0.5);
    playSdWav1.enableInterpolation(true);
   if (Serial.available() > 0) {
    int incomingByte = Serial.read();
    if (incomingByte == 49) {                           // key 1
                                   Speed = Speed + 0.01;
                                   playSdWav1.setPlaybackRate(Speed);
                                   Serial.println(Speed);
     if (incomingByte == 50) {                               //  key 2
                                  Speed = Speed - 0.01;
      if (incomingByte == 51) {                                // key 3
                                  playSdWav1.playWav("13.WAV");
                                   playSdWav1.setLoopType(looptype_repeat);
                                  Serial.println("Playing 13.wav in loop mode");
       if (incomingByte == 52) {                                         // key 4
                                 Serial.println("stopped");
                                 playSdWav1.stop();
     if (incomingByte == 53) {                                        // key5
                             Serial.println("speed 1.00");
namespace std {
    void __throw_bad_function_call() {}
    void __throw_length_error(char const*) {}
Next i Tried mixing above two code into one . and made code
#include <Bounce.h>
{1,2,3,4},
{5,6,7,8},
{9,10,11,12},
{13,14,15,16},
{17,18,19,20},
{21,22,23,24},
{25,26,27,28}
String msg;
  float Speed = 1.00;
    display.display();
    delay(2000);
    msg = "";
        while (1) {
    AudioMemory(24);
    if (kpd.getKeys())
                    case PRESSED:
                    case RELEASED:
                                 playSdWav1.stop();
namespace std {
       display.display();
but here i am getting below error in compiling,,,,,,
Multiple libraries were found for "SD.h"
 Used: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD
 Not used: C:\Program Files\Arduino\libraries\SD
Multiple libraries were found for "Keypad.h"
 Used: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Keypad
 Not used: C:\Users\acer\Documents\Arduino\libraries\Keypad-3.1.1
Using library Bounce in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Bounce (legacy)
Using library Audio at version 1.3 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 2.0.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD
Using library SdFat at version 2.1.2 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat
Using library SerialFlash at version 0.5 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash
Using library TeensyVariablePlayback at version 1.0.16 in folder: C:\Users\acer\Documents\Arduino\libraries\TeensyVariablePlayback
Using library LittleFS at version 1.0.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\LittleFS
Using library Keypad at version 3.1.1 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Keypad
Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire
Using library Adafruit_GFX_Library at version 1.7.5 in folder: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 2.5.7 in folder: C:\Users\acer\Documents\Arduino\libraries\Adafruit_SSD1306
Detailed error is in text Attachment [error001.cpp] you can see.
i seemed pin 18,19 are used by Audio board rev d.
please check how to solve it ......
Thank you,,,,
  • error 001.cpp
This is a problem with the TeensyVariablePlayback code, it has "using namespace std;" in a header which causes type collisions.
Thank you jmarsh,,,
I need some function from this library ( Seamlessly Loop, quick play, playback Speed control etc, ) is there any substitute audio library with above functions, which is able to be mix code ( keypad+oled display+rotary encoder ) with no error..???
