Ethernet W5500 with Teensy 4.1
gonzales
Hi!
I have working project with Teensy 3.5 and Ethernet shield WIZ850io. I use standart SPI port for connection. Now i try to use Teensy 4.1, but unfortunetly i cant starting Ethernet.
How i can see in pinout diagram Teensy 4.1 has the same SPI pins as Teensy 3.5.
Examples from Standart libraries dont work properly, teensy hang up while Ethernet.begin(mac, ip);
I tryed all libraries (Ethernet, NativeEthernet, QNEthernet) with same result.
I read this https://www.pjrc.com/store/wiz820_sd_adaptor.html#init and make reset, how it recomended, but still dont work.
Is it possible to use Ethernet shield WIZ850io with Teensy 4.1?
I forgot to write, that i dont have any pullup resistors, just direct connection between Tennsy and Ethernet shield using pins 10,11,12,13
Try to use my Ethernet_Generic or EthernetWebServer library
I'm using here OK, without any pull-up resistor, for either Teensy4.0 or Teensy4.1
Starting AdvancedWebServer on TEENSY 4.1 with W5x00 using Ethernet_Generic Library on SPI0/SPI
EthernetWebServer v2.1.3
[EWS] =========== USE_ETHERNET_GENERIC ===========
[EWS] Default SPI pinout:
[EWS] MOSI: 11
[EWS] MISO: 12
[EWS] SCK: 13
[EWS] SS: 10
[EWS] =========================
[EWS] Board : TEENSY 4.1 , setCsPin: 10
[ETG] W5100 init, using SS_PIN_DEFAULT = 10 , new ss_pin =  10 , W5100Class::ss_pin =  10
[ETG] Chip is W5500
[ETG] W5100::init: W5500, SSIZE = 8192
[EWS] Currently Used SPI pinout:
[EWS] MOSI: 11
[EWS] MISO: 12
[EWS] SCK: 13
[EWS] SS: 10
Using mac index = 2
Connected! IP address: 192.168.2.87
HTTP EthernetWebServer is @ IP : 192.168.2.87
..[EWS] String Len = 0, extend to 2048
[ATTACH=CONFIG]28283._xfImport[/ATTACH]
@khoil-prog, thanks for the answer.
But not work for me.
Starting WebServer on TEENSY 4.1 with W5x00 using Ethernet_Generic Library with Large Buffer
Ethernet_Generic v2.3.0
[ETG] Default SPI pinout:
[ETG] MOSI: 11
[ETG] MISO: 12
[ETG] SCK: 13
[ETG] SS: 10
[ETG] =========================
[ETG] Board : TEENSY 4.1 , setCsPin: 10
[ETG] W5100::init: no chip :-(
[ETG] Currently Used SPI pinout:
[ETG] MOSI: 11
[ETG] MISO: 12
[ETG] SCK: 13
[ETG] SS: 10
Using mac index = 0
Connected! IP address: 0.0.0.0
Speed: NO LINK, Duplex: NO LINK, Link status: NO LINK
This is same connection with Teensy 3.5
Starting WebServer on Teensy 3.5 with W5x00 using Ethernet_Generic Library with Large Buffer
[ETG] MOSI: 11
[ETG] MISO: 12
[ETG] SCK: 13
[ETG] SS: 10
[ETG] Board : Teensy 3.5 , setCsPin: 10
[ETG] Chip is W5500
[ETG] MOSI: 11
[ETG] MISO: 12
[ETG] SCK: 13
[ETG] SS: 10
Using mac index = 5
Connected! IP address: 192.168.0.129
Speed: 100 MB, Duplex: FULL DUPLEX, Link status: LINK
This is full Log
[ETG] MOSI: 11
[ETG] MISO: 12
[ETG] SCK: 13
[ETG] SS: 10
[ETG] begin: _pinCS =  0
[ETG] W5x00::softReset
[ETG] W5x00::softReset, mr = 0
[ETG] isW5200: detect W5200 chip
[ETG] isW5500: detect W5500 chip
[ETG] isW5100: detect W5100 chip
[ETG] isW5100S: detect W5100S chip
[ETG] readMR (19) = 0
[ETG] MOSI: 11
[ETG] MISO: 12
[ETG] SCK: 13
[ETG] SS: 10
Using mac index = 0
I try to use more degug information for function isW5500()
uint8_t W5100Class::isW5500()
  chip = w5500;
  ETG_LOGDEBUG("isW5500: detect W5500 chip");
  if (!softReset())
    return 0;
ETG_LOGDEBUG("isW5500 1");
  writeMR(0x08);
  if (readMR() != 0x08)
    return 0;
ETG_LOGDEBUG("isW5500 2");
  writeMR(0x10);
  if (readMR() != 0x10)
    return 0;
  writeMR(0x00);
  if (readMR() != 0x00)
    return 0;
  int ver = readVERSIONR_W5500();
  ETG_LOGDEBUG1("Version =", ver);
  if (ver != 4)
    return 0;
  ETG_LOGWARN("Chip is W5500");
  return 1;
So in monitor i can see [ETG] isW5500 1 and dont see [ETG] isW5500 2
