flok
Couldn't find a kit or ready made eurorack-to-teensy thing, so I'm now developing one myself.
The first attempt only has a DAC and an ADC that accept -5...+5 Volt - the pcb arrived today! I'm writing my efforts down on https://nurdspace.nl/Teensy_4.1_to_eurorack
Now only days after I sent the gerbers to JLCPCB, I realised that digital I/O would be nice as well. Should not be problematic I thought: just connect a jack-socket to an I/O-pin & GND. But it should be protected against shorts (for output): that can be solved with an 1 kOhm resistor. But then I also need to protect against +5 V going into it, or even -5 V - two diodes? And what about digital input? Maybe that's easier: only a diode to protect against negative voltages. But then there's also voltages higher than 5V. Oh and I forgot: the teensy doesn't like 5V, so I should add a voltage divider - for each pin? Isn't there a smarter way?
I'm aiming at a low component count and only through-hole components.
All help is welcome!
