extending the framework available USB interfaces with a vendor (bulk endpoints) interface
rodv92
Hi, I started recently to port an Arduino Due based bulk USB interface to TeensyDuino for Teensy 4.1
The main difference seems that Arduino supported the PluggableUSB class that allows to extend the USB device with interfaces and endpoints and its associated required functions for enumerations as such :
class DataBulk_: public PluggableUSBModule {
  public:
    DataBulk_();
    //uint32_t available();
    uint32_t write(void *buf, size_t len);
  protected:
    virtual bool setup(USBSetup &setup) override;
    virtual int getInterface(uint8_t *interfaceCount) override;
    virtual int getDescriptor(USBSetup &setup) override;
    virtual uint8_t getShortName(char *name) override;
  private:
    uint32_t epType[2];
While for teensyduino, it's all inside the framework cores source. (at least for now?)
So I tried to extend it with a "vendor bulk" interface on top of Serial, and it seems ok from the enumeration standpoint, I still will need to benchmark it and troubleshoot using a tester and host based libusb code.
I think it could be nice to extend the framework for a CDC ACM serial (status EP and IN/OUT endpoint) + Vendor Bulk (EP IN/OUT endpoints, 512 MxPacketSize, High speed USB).
That would provide a reasonable general use case for a large number of data transfer oriented projects, where the CDC ACM is then repurposed for telemetry, control, and connection control (such as linestate etc), and the vendor interface and its endpoints for fast data transfer (as it allows to get rid of all host serial associated clutter such as line discipline, special character management, cdc_acm driver binding, internal buffering "black box" management, which can be cumbersome, at least on linux)
The extension was done like this :
In usb.c :
37d36
< #include "usb_vendor.h"
489,491d487
<         #endif
<         #if defined(VENDOR_INTERFACE)
<         usb_vendor_configure();
In usb_desc.c :
87,100d86
< // OPTIONAL: uncommenting the following comment block makes the device entirely transparent to cdc_acm
< // driver on linux, and would require manual binding of the kernel driver.
< #ifdef VENDOR_DESCRIPTOR
< #ifndef DEVICE_CLASS
< #define DEVICE_CLASS 0xFF
< #endif
< #ifndef DEVICE_SUBCLASS
< #define DEVICE_SUBCLASS 0x00
< #endif
< #ifndef DEVICE_PROTOCOL
< #define DEVICE_PROTOCOL 0x00
< #endif
< #endif
<// END OPTIONAL.
601,608c587
< #define VENDOR_INTERFACE_DESC_POS    MIDI_INTERFACE_DESC_POS+MIDI_INTERFACE_DESC_SIZE
< #ifdef  VENDOR_INTERFACE
< #define VENDOR_INTERFACE_DESC_SIZE    9+7+7
< #else
< #define VENDOR_INTERFACE_DESC_SIZE    0
< #endif
< #define KEYBOARD_INTERFACE_DESC_POS    VENDOR_INTERFACE_DESC_POS+VENDOR_INTERFACE_DESC_SIZE
> #define KEYBOARD_INTERFACE_DESC_POS    MIDI_INTERFACE_DESC_POS+MIDI_INTERFACE_DESC_SIZE
1172,1199d1150
<         // configuration for 480 Mbit/sec speed
<         // interface descriptor, USB spec 9.6.5, page 267-269, Table 9-12
<         9,                                      // bLength
<         4,                                      // bDescriptorType
<         VENDOR_INTERFACE,                       // bInterfaceNumber
<         0,                                      // bAlternateSetting
<         2,                                      // bNumEndpoints
<         0xFF,                                   // bInterfaceClass (0xFF = vendor)
<         0x00,                                   // bInterfaceSubClass
<         0x00,                                   // bInterfaceProtocol
<         0,                                      // iInterface
<         // endpoint descriptor, USB spec 9.6.6, page 269-271, Table 9-13
<         7,                                      // bLength
<         5,                                      // bDescriptorType
<         VENDOR_RX_ENDPOINT | 0x80,              // bEndpointAddress
<         0x02,  //USB_ENDPOINT_TYPE_BULK                                 // bmAttributes (0x02=bulk)
<         LSB(VENDOR_RX_SIZE),MSB(VENDOR_RX_SIZE),// wMaxPacketSize
<         0,                                      // bInterval
<         7,                                      // bLength
<         VENDOR_TX_ENDPOINT,                     // bEndpointAddress
<         LSB(VENDOR_TX_SIZE),MSB(VENDOR_TX_SIZE),// wMaxPacketSize
<         0,                                      // bInterval
< #endif // VENDOR INTERFACE
in usb_desc.h
587,622d586
<   #elif defined(USB_VENDOR)
<   #define VENDOR_ID        0x16C0
<   #define PRODUCT_ID        0x0486
<   #define MANUFACTURER_NAME    {'V','E','N','D','O','R'}
<   #define MANUFACTURER_NAME_LEN    6
<   #define PRODUCT_NAME        {'D','E','V','I','C','E'}
<   #define PRODUCT_NAME_LEN    6
<   #define EP0_SIZE        64
<   #define NUM_ENDPOINTS         4
<   #define NUM_INTERFACE        3
<   #define VENDOR_INTERFACE      2
<   #define VENDOR_TX_ENDPOINT    6
<   #define VENDOR_TX_SIZE        512
<   #define VENDOR_TX_INTERVAL    1     // TODO: is this ok for 480 Mbit speed
<   #define VENDOR_RX_ENDPOINT    5
<   #define VENDOR_RX_SIZE        512
<   #define VENDOR_RX_INTERVAL    1     // TODO: is this ok for 480 Mbit speed
<   #define VENDOR_DESCRIPTOR    1       // Vendor-specific device descriptor
<   #define CDC_STATUS_INTERFACE    0
<   #define CDC_DATA_INTERFACE    1
<   #define CDC_ACM_ENDPOINT    2
<   #define CDC_RX_ENDPOINT       3
<   #define CDC_TX_ENDPOINT       4
<   #define CDC_ACM_SIZE          16
<   #define CDC_RX_SIZE_480       512
<   #define CDC_TX_SIZE_480       512
<   #define CDC_RX_SIZE_12        64
<   #define CDC_TX_SIZE_12        64
<   #define ENDPOINT2_CONFIG    ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT // EP0?
<   #define ENDPOINT3_CONFIG    ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_UNUSED // CDC ACM RX EP
<   #define ENDPOINT4_CONFIG      ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_BULK // CDC ACM TX EP
<   #define ENDPOINT5_CONFIG    ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_UNUSED // VENDOR RX EP
<   #define ENDPOINT6_CONFIG      ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_BULK // VENDOR TX EP
//new file usb_vendor.c, based entirely on usb_rawhid.c
#include "usb_dev.h"
#include "avr/pgmspace.h" // for PROGMEM, DMAMEM, FASTRUN
#include "core_pins.h" // for yield(), millis()
#include <string.h>    // for memcpy()
//#include "HardwareSerial.h"
#include "debug/printf.h"
#ifdef VENDOR_INTERFACE // defined by usb_dev.h -> usb_desc.h
#define TX_NUM   4
static transfer_t tx_transfer[TX_NUM] __attribute__ ((used, aligned(32)));
DMAMEM static uint8_t txbuffer[VENDOR_TX_SIZE * TX_NUM];
static uint8_t tx_head=0;
#define RX_NUM  4
static transfer_t rx_transfer[RX_NUM] __attribute__ ((used, aligned(32)));
DMAMEM static uint8_t rx_buffer[VENDOR_RX_SIZE * RX_NUM] __attribute__ ((aligned(32)));
static volatile uint8_t rx_head;
static volatile uint8_t rx_tail;
static uint8_t rx_list[RX_NUM + 1];
static volatile uint32_t rx_available;
static void rx_queue_transfer(int i);
static void rx_event(transfer_t *t);
extern volatile uint8_t usb_configuration;
void usb_vendor_configure(void)
    printf("usb_vendor_configure\n");
    memset(tx_transfer, 0, sizeof(tx_transfer));
    memset(rx_transfer, 0, sizeof(rx_transfer));
    tx_head = 0;
    rx_head = 0;
    rx_tail = 0;
    usb_config_tx(VENDOR_TX_ENDPOINT, VENDOR_TX_SIZE, 0, NULL);
    usb_config_rx(VENDOR_RX_ENDPOINT, VENDOR_RX_SIZE, 0, rx_event);
    int i;
    for (i=0; i < RX_NUM; i++) rx_queue_transfer(i);
/**                               Receive                               **/
    void *buffer = rx_buffer + i * VENDOR_RX_SIZE;
    arm_dcache_delete(buffer, VENDOR_RX_SIZE);
    //memset(buffer, )
    NVIC_DISABLE_IRQ(IRQ_USB1);
    usb_prepare_transfer(rx_transfer + i, buffer, VENDOR_RX_SIZE, i);
    usb_receive(VENDOR_RX_ENDPOINT, rx_transfer + i);
    NVIC_ENABLE_IRQ(IRQ_USB1);
    int i = t->callback_param;
    //printf("rx event i=%d\n", i);
    // received a packet with data
    uint32_t head = rx_head;
    if (++head > RX_NUM) head = 0;
    rx_list[head] = i;
    rx_head = head;
int usb_vendor_recv(void *buffer, uint32_t timeout)
    uint32_t wait_begin_at = systick_millis_count;
    uint32_t tail = rx_tail;
    while (1) {
        if (!usb_configuration) return -1; // usb not enumerated by host
        if (tail != rx_head) break;
        if ((systick_millis_count - wait_begin_at > timeout) || !timeout) {
            return 0;
        yield();
//    digitalWriteFast(0, LOW);
    if (++tail > RX_NUM) tail = 0;
    uint32_t i = rx_list[tail];
    rx_tail = tail;
    memcpy(buffer,  rx_buffer + i * VENDOR_RX_SIZE, VENDOR_RX_SIZE);
    //memset(rx_transfer, 0, sizeof(rx_transfer));
    //usb_prepare_transfer(rx_transfer + 0, rx_buffer, VENDOR_RX_SIZE, 0);
    //usb_receive(VENDOR_RX_ENDPOINT, rx_transfer + 0);
    return VENDOR_RX_SIZE;
int usb_vendor_send(const void *buffer, uint32_t timeout)
    transfer_t *xfer = tx_transfer + tx_head;
    while (1) {
        uint32_t status = usb_transfer_status(xfer);
        if (!(status & 0x80)) break; // transfer descriptor ready
        if (systick_millis_count - wait_begin_at > timeout) return 0;
        yield();
    uint8_t *txdata = txbuffer + (tx_head * VENDOR_TX_SIZE);
    memcpy(txdata, buffer, VENDOR_TX_SIZE);
    arm_dcache_flush_delete(txdata, VENDOR_TX_SIZE );
    usb_prepare_transfer(xfer, txdata, VENDOR_TX_SIZE, 0);
    usb_transmit(VENDOR_TX_ENDPOINT, xfer);
    if (++tx_head >= TX_NUM) tx_head = 0;
    return VENDOR_TX_SIZE;
int usb_vendor_available(void)
    if (!usb_configuration) return 0;
    if (rx_head != rx_tail) return VENDOR_RX_SIZE;
    //if (!(usb_transfer_status(rx_transfer) & 0x80)) return VENDOR_RX_SIZE;
    return 0;
#endif // VENDOR_INTERFACE
//And finally, usb_vendor.h, also based entirely on usb_rawhid.h
#pragma once
#include "usb_desc.h"
#include <inttypes.h>
// C language implementation
#ifdef __cplusplus
extern "C" {
void usb_vendor_configure(void);
int usb_vendor_recv(void *buffer, uint32_t timeout);
int usb_vendor_available(void);
int usb_vendor_send(const void *buffer, uint32_t timeout);
#ifdef __cplusplus
// C++ interface
#ifdef __cplusplus
class usb_vendor_class
public:
    int available(void) {return usb_vendor_available(); }
    int recv(void *buffer, uint16_t timeout) { return usb_vendor_recv(buffer, timeout); }
    int send(const void *buffer, uint16_t timeout) { return usb_vendor_send(buffer, timeout); }
extern usb_vendor_class Vendor;
#endif // __cplusplus
The only trouble i am having is making a c++ usb_vendor_class object available for sketches as a Vendor instance, as usb_inst.cpp refuses to compile, so i commented it out :
//usb_vendor_class Vendor;
I get :
/home/rd/.platformio/packages/framework-arduinoteensy/cores/teensy4/usb_inst.cpp:59:1: error: 'usb_vendor_class' does not name a type; did you mean 'usb_serial_class'?
   59 | usb_vendor_class Vendor;
      | usb_serial_class
*** [.pio/build/teensy41/FrameworkArduino/usb_inst.cpp.o] Error 1
I probably forgot some code patching somewhere ?
And finally some little issue in enumeration :
When building with the vanilla USB_SERIAL compile flag this gives this enumeration on linux (see file usb_serial.png)
When building with the USB_VENDOR compile flag this gives this enumeration on linux (see file usb_vendor.png)
There is a mysterious interface that gets overwritten with the vendor interface i just added.
Sub=6a, Prot=c7.
What is that interface for ?
I will probably have to figure the interface ID and interface num defines and endpoint defines so as not overwrite it, unless someone knowledgeable as an idea.
ps : i am using 96 bytes tx maxkpacket sizes and 64 bytes rx maxpacketsize in the screenshots for my use case instead of the more general 512 byte size I provided in the code sample of this post.[/CODE]
Not sure if you care about compliance to the USB spec, but if that's a concern you should probably be aware 512 byte max packet size is required for bulk endpoints when using 480 Mbit/sec speed.
Indeed, Paul.
I successfully used 512 bytes RX maxPacketSize on the Arduino Due, although my transfers are fixed size 96 bytes, and i would prefer 96 bytes packets only on the bus. That seems to be a "short packet" in USB parlance.
Looking at the usb_vendor_send transfer mechanism, it seems that it would send a 96 byte packet if VENDOR_TX_SIZE was set at 96, and i could define a VENDOR_TX_MAXPACKETSIZE to the standard 512 bytes in the endpoint definition.
It seems that the txbuffer is larger than VENDOR_TX_SIZE (product of VENDOR_TX_SIZE and TX_NUM), but usb_vendor_send would still send a short packet of VENDOR_TX_SIZE at each call ? i can't see any tx_tail so i assume that txbuffer just holds 'stale' data.
I am not familliar with USB Teensy 4.1 usb buffering internals however, and I hope the fact that 512 Bytes is not a multiple of 96 bytes will not create issues, although i could pad to 128 bytes if that were the case.
Thanks Paul,
Please disregard my latest post, i figured why the need for txdata and tx_head buffering, as the transfers are scheduled, and not guaranteed to happen synchronously.
I am now testing with 512 byte max packet size and a TX_SIZE of the same size or less. I figured out that ZLP packets are configurable in usb_config_tx too if needed.
Seems however that there is no data sent on the bus with my setup as wireshark doesn't catch any traffic from the device to host on the new interface and endpoints. (serial works ok)
I made a mistake on the NUM_ENDPOINTS in the original post that was set too low.
I tried a lone interface and two endpoints (no Serial / CDC ACM whatsoever to rule out any conflict but to no avail. I'll keep digging the usb_serial.c code as a work basis and post again if i am really stuck or if I find the issue in the meantime.
It works now, basically my original post had some errors.
The interface is now as follows, I had swapped VENDOR_TX_ENDPOINT and VENDOR_RX_ENDPOINT
        9,                                      // bLength
        2,                                      // bNumEndpoints
        0,                                      // iInterface
        7,                                      // bLength
        VENDOR_RX_ENDPOINT,                     // bEndpointAddress
        0,                                      // bInterval
        7,                                      // bLength
        VENDOR_TX_ENDPOINT | 0x80,              // bEndpointAddress
        0,                                      // bInterval
and the accurate defines are :
  #define PRODUCT_NAME        {'P','R','O','D','U','C','T'}
  #define PRODUCT_NAME_LEN    7
  #define EP0_SIZE        64
  #define NUM_ENDPOINTS         6 // NUM_ENDPOINTS should be equal to the highest endpoint id
  #define VENDOR_INTERFACE      2    // Vendor Bulk
in usb_vendor.c, I enabled ZLP, third parameter of usb_config_tx, in the case if the data message size is a multiple of maxpacketsize.
    tx_head = 0;
    rx_head = 0;
    rx_tail = 0;
    usb_config_tx(VENDOR_TX_ENDPOINT, VENDOR_TX_SIZE, 1, NULL);
    int i;
    for (i=0; i < RX_NUM_VENDOR; i++) rx_queue_transfer(i);
Also, added in usb_vendor.c, to reflect that i use short packets and to decouple from VENDOR_TX_SIZE and VENDOR_RX_SIZE (that represent the MaxPacketSize set at 512 bytes for USB High speed)
I added VENDOR_TX_PACKETSIZE and VENDOR_RX_PACKETSIZE
Note that I did not bother to check the device bus speed to adjust dynamically the max packet size between 64 and 512
#define VENDOR_TX_PACKETSIZE 96 // represents the fixed length short packet i use
#define VENDOR_RX_PACKETSIZE 64
/**                               Receive                               **/
    void *buffer = rx_buffer + i * VENDOR_RX_PACKETSIZE;
    arm_dcache_delete(buffer, VENDOR_RX_PACKETSIZE);
    //memset(buffer, )
    usb_prepare_transfer(rx_transfer + i, buffer, VENDOR_RX_PACKETSIZE, i);
    if (++head > RX_NUM_VENDOR) head = 0;
    rx_list[head] = i;
    rx_head = head;
    while (1) {
            return 0;
        yield();
    if (++tail > RX_NUM_VENDOR) tail = 0;
    rx_tail = tail;
    memcpy(buffer,  rx_buffer + i * VENDOR_RX_PACKETSIZE, VENDOR_RX_PACKETSIZE);
    //usb_prepare_transfer(rx_transfer + 0, rx_buffer, RAWHID_RX_SIZE, 0);
    //usb_receive(RAWHID_RX_ENDPOINT, rx_transfer + 0);
    return VENDOR_RX_PACKETSIZE;
    //usb_start_sof_interrupts(VENDOR_INTERFACE);
    uint32_t status;
    while (1) {
        yield();
    uint8_t *txdata = txbuffer + (tx_head * VENDOR_TX_PACKETSIZE);
    memcpy(txdata, buffer, VENDOR_TX_PACKETSIZE);
    usb_prepare_transfer(xfer, txdata, VENDOR_TX_PACKETSIZE, 0);
    arm_dcache_flush_delete(txdata, VENDOR_TX_PACKETSIZE );
    if (++tx_head >= TX_NUM_VENDOR) tx_head = 0;
    //usb_stop_sof_interrupts(VENDOR_INTERFACE);
    return VENDOR_TX_PACKETSIZE;
    if (rx_head != rx_tail) return VENDOR_RX_PACKETSIZE;
    //if (!(usb_transfer_status(rx_transfer) & 0x80)) return VENDOR_RX_PACKETSIZE;
    return 0;
Now it also seems that wireshark does not show traffic until the packets are acknowledged, so a working libusb client needs to talk to the device.
Finally a libusb client that i am using for benchmarking :
// BULK USB VENDOR MODE
#include <libusb.h>
// THREADING
#include <pthread.h>
#include <shared_mutex>
#include <mutex>
//STDIO
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <string>
#include <iostream>
#include <iomanip>
#include <atomic>
#include <chrono>
#include <sys/mman.h>
#include <unistd.h>
#include <bits/stdc++.h>
#include <unordered_map>
using namespace std;
#ifndef DEBUGLEVEL
#define DEBUGLEVEL 0
//defines for bulk interface
#define USB_BUFFER_SIZE 96
#define URB_SIZE USB_BUFFER_SIZE
#define N_URBS 32
#define VID 0x16C0
#define PID 0x0486
#define USB_BULK_IFACE 0x2
#define EP_IN 0x86
#define EP_OUT 0x5
#define USE_BULK 1
#define NCURSES false
#define dbgstr(x) __func__ , std::to_string(__LINE__) , x
struct  libusb_transfer *usbxfer[N_URBS];
uint8_t  *usbbuf[N_URBS];
libusb_context *ctx;
libusb_device_handle *h;
std::atomic<int> usb_pending_transfers{N_URBS};
std::atomic<bool> USB_transfer_active{true};
std::atomic_bool readUSB_exit(false);
std::mutex mtx3;
FILE  *fid_perf;
typedef float SAMPLE;
typedef double SAMPLE2;
template <typename T>
inline void DebugPrint(std::string func, std::string line, std::string str, T const &value, uint8_t level)
     using namespace std::chrono_literals;
    #if (!NCURSES)
    std::lock_guard<std::mutex> lock(mtx3); // prevent stream interleaving (no different thread may write a line at the same time)
    if(level == 0)
        std::cerr << func << "\t";
        std::cerr << line << "\t";
        std::cerr << std::hash<std::thread::id>{}(std::this_thread::get_id()) << "\t";
        std::cerr << str << "\t";
        if (std::is_same<T, SAMPLE2>::value)
            std::cerr << fixed;
            std::cerr << setprecision(6) << value << std::endl;
            std::cerr << value << std::endl;
    else if (level <= DEBUGLEVEL)
        std::cout << func << "\t";
        std::cout << line << "\t";
        std::cout << std::hash<std::thread::id>{}(std::this_thread::get_id()) << "\t";
        std::cout << str << "\t";
        //if (std::is_same<T, SAMPLE2>::value)
            std::cout << fixed;
            std::cout << setprecision(6) << value << std::endl;
        //else
        //    std::cout << value << "\n";
inline void DebugPrint(std::string func, std::string line, std::string str, int level)
    #if (!NCURSES)
    if(level == 0)
        std::cerr << str << std::endl;
        std::cout << str << std::endl;
static void rx_usb_bulk(struct libusb_transfer *t)
    //DebugPrint(dbgstr("rx_usb_bulk"),0);
    switch (t->status) {
        case LIBUSB_TRANSFER_COMPLETED:
        if(t->actual_length > 0)
           // DebugPrint(dbgstr("Incoming transfer bytes:"),t->actual_length,0);
            fwrite(t->buffer,sizeof(char),t->actual_length,fid_perf); // raw sample buffer (w/o timestamp)
            fflush(fid_perf);
            if(t->actual_length != USB_BUFFER_SIZE)
                DebugPrint(dbgstr("Processing of USB buffer,t->actual_length != USB_BUFFER_SIZE"),t->actual_length,0);
            if (USB_transfer_active.load())
                libusb_submit_transfer(t);
                return;
        //case LIBUSB_TRANSFER_CANCELLED:
        case LIBUSB_TRANSFER_ERROR:
        DebugPrint(dbgstr("transfer signalling LIBUSB_TRANSFER_ERROR"),0);
        case LIBUSB_TRANSFER_TIMED_OUT:
        DebugPrint(dbgstr("transfer signalling LIBUSB_TRANSFER_TIMED_OUT"),0);
        case LIBUSB_TRANSFER_STALL:
        DebugPrint(dbgstr("transfer signalling LIBUSB_TRANSFER_STALL"),0);
        case LIBUSB_TRANSFER_NO_DEVICE:
        DebugPrint(dbgstr("transfer signalling LIBUSB_TRANSFER_NO_DEVICE"),0);
        case LIBUSB_TRANSFER_OVERFLOW:
        DebugPrint(dbgstr("transfer signalling LIBUSB_TRANSFER_OVERFLOW"),0);
    usb_pending_transfers--;
    if (usb_pending_transfers == 0)
            // All transfers have completed or been cancelled, we can exit the drain loop
            DebugPrint(dbgstr("All USB transfers completed or cancelled or in error"),0);
void * ReadUSBThread(void * arg)
    mlockall(MCL_CURRENT | MCL_FUTURE);
    DebugPrint(dbgstr("enter ReadUSBThread"),0);
    for(int i = 0; i < N_URBS; i++)
        libusb_submit_transfer(usbxfer[i]);
    DebugPrint(dbgstr("submit transfers"),0);
    while(!(readUSB_exit.load()))
        //usleep(100);
        libusb_handle_events(ctx);   // or libusb_handle_events_completed()
        //DebugPrint(dbgstr("PutUSBSamples ok"),0);
        sched_yield();
    while (usb_pending_transfers > 0)
        usleep(10);
        DebugPrint(dbgstr("Waiting for USB transfers to complete, pending transfers:"),usb_pending_transfers,0);
        sched_yield();
    return 0;
inline uint16_t initUSBBulk()
    libusb_init(&ctx);
    libusb_set_option(ctx,LIBUSB_OPTION_LOG_LEVEL,LIBUSB_LOG_LEVEL_WARNING);
    h = libusb_open_device_with_vid_pid(ctx,VID,PID);
    if (!h)
        DebugPrint(dbgstr("USB open device failed, is it plugged ?"),0);
        fflush(stdout);
        return 1;
    DebugPrint(dbgstr("USB open device OK"),0);
    if(libusb_kernel_driver_active(h,USB_BULK_IFACE) == 1)
        libusb_detach_kernel_driver(h,USB_BULK_IFACE);
        DebugPrint(dbgstr("kernel driver detach OK (should not happen)."),0);
    if(libusb_claim_interface(h,USB_BULK_IFACE) < 0)
        DebugPrint(dbgstr("USB claim interface failed."),0);
        fflush(stdout);
        return 1;
    DebugPrint(dbgstr("USB claim interface OK."),0);
    for(uint8_t i = 0; i < N_URBS; i++)
        usbbuf[i] = (uint8_t *) aligned_alloc(64,URB_SIZE);
        usbxfer[i] = libusb_alloc_transfer(0);
        libusb_fill_bulk_transfer(
            usbxfer[i],
            h,
            EP_IN,
            usbbuf[i],
            URB_SIZE,
            rx_usb_bulk,
            NULL,
            0
    return 0;
int main()
    if(initUSBBulk())
        DebugPrint(dbgstr("USB bulk init failed."),0);
        return 1;
    #if USE_BULK
    fid_perf = fopen("teensy41_testUSBperf.raw","wb");
    if(fid_perf == NULL)
        perror( "Error opening file" );
        printf( "Error code opening file: %d\n", errno );
        printf( "Error opening file: %s\n", strerror( errno ) );
        exit(-1);
    DebugPrint(dbgstr("fid_perf"),fid_perf,0);
    pthread_t USBThread;
    int result = pthread_create(&USBThread, NULL, ReadUSBThread, NULL);
    if (result != 0) {
        DebugPrint(dbgstr("Error creating USB thread"),result,0);
        exit(-1);
    // Simulate some work in the main thread
    for (int i = 0; i < 60; i++) {
        DebugPrint(dbgstr("Main thread working..."),i,0);
        sleep(1);
    fclose(fid_perf);
    USB_transfer_active.store(false);
    DebugPrint(dbgstr("setting USB_transfer_active to false (won't submit new transfers)"),0);
    // Signal the USB thread to exit
    readUSB_exit.store(true);
    // Wait for the USB thread to finish
    pthread_join(USBThread, NULL);
    // Clean up USB resources
        libusb_cancel_transfer(usbxfer[i]);
        libusb_free_transfer(usbxfer[i]);
        free(usbbuf[i]);
    libusb_release_interface(h, USB_BULK_IFACE);
    libusb_close(h);
    libusb_exit(ctx);
    return 0;
Great Job! Do you also have a simple test file of test.ino, which is used to test the vendor interface. And if yes, could you please to share it. Thank you.
yes.
This is a simple sketch that fetches 8 samples from precomputed sin tables (ADC 16 bit emulation), with arbitrary sample offset between channels, wrap ups 7 consecutive chunks of these 8 samples in a buffer and appends a 64 bit timestamp representing teensy 4.1 CPU cycles, with room for two more uint16_t variables labeled debug1 and debug2, set to 0, thus acting as padding.
Giving a fixed USB packet of 124 bytes, sent every 140 us.
that gives a net byte rate of around 885.7 KB/s (over 60 sec runtime)
The output can be examined using hexdump on teensy41_testusbperf.raw generated by the above libusb code.
Note that for the testing sketch i supplied, VENDOR_TX_PACKETSIZE should be set to 124 bytes in usb_vendor.c that i previously mentioned.
the libusb test client can be compiled using the following command : ./make_testusbperf.sh 0
The bash script argument '0' is the debuglevel for stdout/stderr output.
content of the make_testusbperf.sh script :
Bash:
#set -march to your architecture
#RYZEN optimized build:
g++ --verbose -std=c++2a -Wall testUSBperf.cpp -o testUSBperf -I. -I/usr/include/libusb-1.0 -g -O3 -march=znver1 -msse4.2 -fopenmp -lrt -lm -lusb-1.0 -pthread -DDEBUG -DDEBUGLEVEL=$1
date
  • main.ino
  • testUSBperf.cpp
Thank you for share the DEMO. But when I compiled the main.ino in Arduino, I am failed. The error showes that can't find the definition of two constance, which are RX_NUM_VENDOR and TX_NUM_VENDOR. Could you please give me the definition of these two constance.
BTW: I found why the following get a compile error:
Actually you need to add a line in the file WProgram.h
which is :
This two number can be set same as RX_NUM and TX_NUM, or other things. And defined at usb_vendor.c near RX_NUM and TX_NUM. Then it is OK now.
hi zerowind, did you modify the teensyduino framework ?
if not, modify the teensyarduino framework, mainly add usb_vendor.c , usb_vendor.h, and modify usb.c, usb_desc.c and usb_desc.h
make a full backup of the files modified or backup of the full framework. THIS CAN BREAK THINGS in other projects because of compilation problems. So be careful.
Also, a framework update will revert the changes.
I am using PlatformIO, I don't know where the platform framework and toolchains are in Arduino IDE. So you'll have to search the filesystem for usb.c and usb_desc.c and h files, usually there is a folder for each teensy release, ex : teensy4 for teensy 4 and 4.1
Also, platformio has a configuration file platformio.ini that allows to override default build flags, it is necessary to tell the compiler to set the correct #defines and unset others.
Mainly :
build_unflags = -DUSB_SERIAL
build_flags = -DUSB_VENDOR
These modifications are required.
Arduino IDE should have something similar
I will probably make some new post giving more details in the medium term.
Mainly :
Hi rodv92, Thank you for reply. I have already make it work for Arduino, and yes I have modify the same file just as you suggestion. And just add 4 lines to board.txt. which is as follow:
teensy41.menu.usb.vendor=Vendor
teensy41.menu.usb.vendor.build.usbtype=USB_VENDOR
teensy41.menu.usb.vendor.upload_port.usbtype=USB_VENDOR
teensy41.menu.usb.vendor.fake_serial=teensy_gateway
And then I can select the usb type as Vendor, and compile the main.ino
Just a little update about some issues.
First about setting up product id and vendor id
It worked best using :
in usb_desc.c :
#define PRODUCT_ID 0x0483
instead of PRODUCT_ID 0x0486 that is used for raw_hid type devices,
since the USB_VENDOR type combines the usual ttyACM (USB_SERIAL) + VENDOR bulk endpoints, it makes things easier for the IDE to detect the teensy using the USB_SERIAL 0x0483 product_id. When using 0x486, I had to flash manually using the button, at least in platform IDE.
Now the host side, although not Teensy related, It can save a lot of headaches using these guidelines:
1) use a FIFO real time Scheduling thread. beware of the priority. too low can hang the system, i set it to 89 on my system
0 is max priority.
89 is just a notch priority above other FIFO tasks in my system.
I used ps -elc | grep "FF" shell command to inquiry about my existing FIFO sched processes priorities to get an idea of what priority to use.
It does not show individual threads priority i think, there may be threads using FIFO while listed as SCHED_OTHER processes, so this could hide some information., but it gives a general idea.
C++:
    pthread_attr_t USBThread_attr;
    pthread_attr_init(&USBThread_attr);
    pthread_attr_setinheritsched(&USBThread_attr,PTHREAD_EXPLICIT_SCHED);
    pthread_attr_setschedpolicy(&USBThread_attr,SCHED_FIFO);
    sched_param param{};
    param.sched_priority = 89;
    pthread_attr_setschedparam(&USBThread_attr,&param);
    //int result = pthread_create(&USBThread, NULL, ReadUSBThread, NULL);
    int result = pthread_create(&USBThread, &USBThread_attr, ReadUSBThread, NULL);
Also, sched_yield() use is discouraged, "historical garbage" to quote Linus Torvalds,
I uses this loop inside the ReadUSBThread function :
while(!readUSB_exit)
        //libusb_handle_events(ctx);   // or libusb_handle_events_completed()
        libusb_handle_events_completed(ctx, &readUSB_exit);
        usleep(10); // instead of sched_yield()
        DebugPrint(dbgstr("final libusb handle events, flushing transfers"),0);
        usleep(10);
Better use a really small blocking call like usleep() that should preempt it to another real time process of a lower priority if in queue, or another if no lower priority is waiting. This is why priority is important. I would try a notch under all IRQ sched fifo tasks and then a notch above and see if there are changes. I think that usleep() should be less than the usb_vendor_send() call interval on the teensy as a safe measure. worth experimenting with longer periods.
2) Write usb data on the fly in a aligned buffer and dump the content using fwrite at the end of process execution.
C++:
/ Round up to next multiple of align (align must be power of 2)
static inline std::size_t align_up(std::size_t n, std::size_t align) {
    return (n + align - 1) & ~(align - 1);
void* alloc_aligned(std::size_t size) {
    // Round size up to a cache-line multiple — avoids false sharing
    // on the last cache line and satisfies some allocator contracts.
    const std::size_t sz = align_up(size, CACHE_LINE);
    void* p = nullptr;
    // posix_memalign requires alignment >= sizeof(void*) and power of 2.
    // 64 satisfies both. Returns 0 on success, errno value on failure.
    const int rc = posix_memalign(&p, CACHE_LINE, sz);
    if (rc != 0)
        throw std::bad_alloc{};
    return p;
void free_aligned(void* p) {
    // Memory from posix_memalign is released with plain free()
    free(p);
If not doing this, there may be dropped USB packets due to fwrite operation interference, (With or without fflush() at each write.)
I did not try changing the fwrite IO buffer size however, just stopped using fflush() at each write, which was dumb, but it did not improve much.
I think the default buffer size for fwrite is 8KB, worth checking.
But since the goal of the tool is to test performance, file operations should not interfere in the benchmarking, thus this optimization write at the end.
Writing to the buffer inside rx_usb_bulk uses standard memcpy.
            // DO NOT USE FWRITE HERE, FLUSH buffer into file at thread termination.
            //fwrite(t->buffer,sizeof(char),t->actual_length,fid_perf); // raw sample buffer (w/o timestamp)
            //fflush(fid_perf);
            memcpy(outBuftmp,t->buffer,112);
etc...
3) There may still be issues with the cleanup at the end (flushing transfers) because i use libusb_handle_events()
The recent lbusb documentation says it should be discouraged since there may be a race condition at cleanup when flushing last transfers, and it should be provided a completion variable using libusb_handle_events_completed(ctx, &complete); instead.
The example above drops the atomic boolean state variable and instead uses a plain int that is passed to libusb_handle_events_completed
Did not found any improvements or negative effects for now.
I will try to provide a clean code of the tool when i have time.
4) on Teensy side, I started experimenting with TX_NUM_VENDOR as it seems to be the number USB URBs managed at a time, matching them to N_URBS on the host code side.
When making the changes in that post, I could scale back to 4 for both. Using higher values may improve things in a non realtime thread, but weirds things start to happen at higher values (16 or 32) when looking at USBmon captures on wireshark (huge amount of data transfered on the bus compared at what it should be). Also, For USB debugging , wireshark and usbmon are your friends.
Have a nice day.
