After a long hiatus away from Teensy (and microcontrollers in general) I am again tinkering with DSP ideas using the Teensy 4.x and Audio Shield. Now with Claude AI assistance I am finally realizing some satisfying audio effects designs that can sound really good, and I want to extract the best (lowest noise / full bandwidth) audio from this system.
My question is, does the current Audio Shield have the potential to allow for what could be considered pro or studio-grade audio quality (or, maybe I'm using it "wrong"), or do I need to look to other codecs? What is the best way to extract the highest performance from the existing hardware?
To explain my specific setup - I am buffering the line inputs with a clean low gain / high impedance input amp for guitar (an old Alesis NanoComp with no compression or gain), and on the output side I am using the Audio Shield headphone jack out through an isolation transformer into a separate Class-D amp driving a pair of small monitor speakers.
Sometimes I get some light high-frequency whistles or "birdies" especially with a lot of gain and high-end boost. I have tried various methods to clean up the sound but it never completely goes away. The Class D amp board on its own usually makes no noise but I wasn't sure if there was some conflict or mixing going on with it's clock and the output of the headphone jack. Also there is occasional buzz or hum but this could just be normal guitar type of stuff.
In any case, are there better codecs at this point than the SGTL5000, or is it my setup that needs fixing first to realize its true potential? Or a bit of both?
Regards,
Dave
Regards,
Dave
