Nominal Animal
For a 8-bit wide bus using GPIO6 bits 16-19, 24-27, I'd use
For a 10-bit wide bus using GPIO6 bits 16-19, 22-27, I'd use
In both cases, the
If you need an
You can implement the above 10-bit bus using a look-up table in RAM with for example
The
Just remember to initialize the bus state to 0, and set the relevant pins outputs and low.
The useful thing is that with this lookup-based approach, you can use any bits in the same GPIO bank and in any order you want, for a modest runtime cost (in memory and speed).
I'm personally working on a variant approach of this, using 18-bit RGB parallel output using three 6-bit look-up tables, but calculating the actual emitted color at runtime based on a couple of framebuffers on top of each other. The idea is to have a full-color background one can blit to, but also be able to blit antialiased glyphs/sprites/characters on top, independent of each other. The maximum clock rate on ILI9341 etc. display controllers with such an interface is typically about 15 MHz, so technically there are on the order of 40 clock cycles (at 600 MHz) per bus output word to get that done.. Reminds me of the early days of 6502 assembly programming.
temp = val ^ state; GPIO6_DR_TOGGLE = ((temp & 15) << 16) | ((temp & 240) << 20); state = val & 1023;
to update the bus state to val
.For a 10-bit wide bus using GPIO6 bits 16-19, 22-27, I'd use
temp = val ^ state; GPIO6_DR_TOGGLE = ((temp & 15) << 16) | ((temp & 1008) << 18); state = val & 1023;
.In both cases, the
state
variable tracks the value seen on the bus, and allows us to use the GPIOx_DR_TOGGLE
, so we do not modify the states of the other pins in the same GPIO port. All variables above are of uint32_t
type.If you need an
N
-bit wide bus within any single GPIO port, but a different (any) pin order, you can do it with a 1<<N
= 2ⁿ -entry look-up table of uint32_t
's in Flash or RAM. It will not be as fast as using consecutive sets of bits in order, though. If N
is large, you can split it into sub-buses. If they are all in a single GPIO port, they will change states at the same time.You can implement the above 10-bit bus using a look-up table in RAM with for example
constexpr int bus_bits = 10;
constexpr uint8_t bus_bit[bus_bits] = { 16, 17, 18, 19, 22, 23, 24, 25, 26, 27 };
constexpr uint32_t bus_mask = (1 << bus_bits) - 1;
volatile uint32_t bus_state;
uint32_t bus_lookup[1 << bus_bits];
static inline void set_bus(uint32_t value) {
GPIO6_DR_TOGGLE = bus_lookup[(value ^ bus_state) & bus_mask];
bus_state = value & bus_mask;
// Fill bus_lookup
uint32_t i = 1 << bus_bits;
while (i-->0) {
uint32_t value = 0;
uint32_t bits = i;
for (int bit = 0; bit < bus_bits; bit++, bits >>= 1)
if (bit & 1)
value |= 1 << bus_bit[bit];
bus_lookup[i] = value;
// Todo: set pins to outputs
// Initialize bus state to 0
bus_state = 0;
GPIO6_DR_CLEAR = bus_lookup[bus_mask];
// Other setup() stuff you need...
bus_lookup
table will have 1024 entries, and thus consume 4096 bytes of RAM. You can split the look-up table into two or three or more much smaller tables (for example, the 1024-entry table to two 32-entry ones), or even completely do without:
uint32_t changes = (value ^ bus_state) & bus_mask;
uint32_t toggle = 0;
for (int bit = 0; bit < bus_bits; bit++, changes >>= 1)
if (changes & 1)
toggle |= bus_bit[bit];
GPIO6_DR_TOGGLE = toggle;
