Hi, I am working on a project using the Teensy 4.1 to play back spatial audio via the CS42448 codec.
I'd like the project to be able to play back recorded spatial files from the SD reader, and I wrote a modified version of the SD file player object for this purpose.
However, I'm hitting a roadblock where it seems like the SD file read speed is insufficient for 8-channels. Is there any way to get around this? I'm already ignoring the header information when looping, so there's not much more I can optimize code wise. Any suggestions?
Here is my multichannel file reader object for reference:
//modified from play_sd_wav.cpp by Emmett Palaima
#include <Arduino.h>
#include "play_sd_wav_xch.h"
#include "spi_interrupt.h"
#define STATE_DIRECT_16BIT_XCH 1 //16bit wave file, 44100kHz SR, any number of channels
#define STATE_UNSUPPORTED_FORMAT 2 //if the file is not 16bit, or sample rate is not 44100kHz
#define STATE_PARSE1 8 // looking for 20 byte ID header
#define STATE_PARSE2 9 // looking for 16 byte format header
#define STATE_PARSE3 10 // looking for 8 byte data header
#define STATE_PARSE4 11 // ignoring unknown chunk after "fmt "
#define STATE_PARSE5 12 // ignoring unknown chunk before "fmt "
#define STATE_STOP 13
#define IS_REPEATING 1
void AudioPlaySdWavXCH::begin(void)
state = STATE_STOP;
state_play = STATE_STOP;
data_length = 0;
isRepeating = false;
for(int chan = 0; chan < WAV_MAX_CHANNELS; ++chan){
if(block[chan]){
release(block[chan]);
block[chan] = NULL;
bool AudioPlaySdWavXCH::play(const char *filename)
stop();
#if defined(HAS_KINETIS_SDHC)
if (!(SIM_SCGC3 & SIM_SCGC3_SDHC)) AudioStartUsingSPI();
#else
__disable_irq();
wavfile = SD.open(filename);
Serial.println(wavfile.available());
if(!wavfile) Serial.println("File not found!");
__enable_irq();
if (!wavfile) {
if (!(SIM_SCGC3 & SIM_SCGC3_SDHC)) AudioStopUsingSPI();
#else
return false;
buffer_length = 0;
buffer_offset = 0;
data_length = 20;
header_offset = 0;
state = STATE_PARSE1;
return true;
void AudioPlaySdWavXCH::stop(void)
__disable_irq();
if (state != STATE_STOP) {
//weird memory release method:
audio_block_t* b[WAV_MAX_CHANNELS];
b[chan] = block[chan];
block[chan] = NULL;
state = STATE_STOP;
__enable_irq();
if(b[chan]){ release(b[chan]); }
wavfile.close();
#else
__enable_irq();
void AudioPlaySdWavXCH::update(void)
int32_t n;
// only update if we're playing
if (state == STATE_STOP) return;
//allocate more than enough channels, since we don't know how many we'll need yet
block[chan] = allocate();
if(block[chan] == NULL){
--chan;
while(chan >= 0){
--chan;
return;
block_offset = 0;
// is there buffered data?
n = buffer_length - buffer_offset;
if (n > 0) {
// we have buffered data
if (consume(n)) return; // it was enough to transmit audio
// we only get to this point when buffer[512] is empty
if (state != STATE_STOP && wavfile.available()) {
// we can read more data from the file...
readagain:
buffer_length = wavfile.read(buffer, MULTI_BUFFERSIZE);
// Serial.println(buffer_length);
if (buffer_length == 0) goto end;
buffer_offset = 0;
bool parsing = (state >= 8);
bool txok = consume(buffer_length);
// Serial.println(txok);
// Serial.println(state);
if (txok) {
if (state != STATE_STOP) return;
if (parsing && state < 8) goto readagain;
else goto cleanup;
end: // end of file reached or other reason to stop
if(state != STATE_STOP && isRepeating){
// Serial.println("Trying Repeat:");
// Serial.println(wavfile.available());
// Serial.println(wavfile.seek(44));
wavfile.seek(44);
goto readagain;
wavfile.close();
#else
state = STATE_STOP;
cleanup:
if (block[chan]) {
if (block_offset > 0) {
for (uint32_t i=block_offset; i < AUDIO_BLOCK_SAMPLES; i++) {
block[chan]->data[i] = 0;
transmit(block[chan], chan);
if(numChannels == 1){
transmit(block[chan], 1);
block[chan] = NULL;
// https://ccrma.stanford.edu/courses/422/projects/WaveFormat/
// Consume already buffered data. Returns true if audio transmitted.
bool AudioPlaySdWavXCH::consume(uint32_t size)
uint32_t len;
uint8_t lsb, msb;
const uint8_t *p;
p = buffer + buffer_offset;
start:
if (size == 0) return false;
#if 0
Serial.print("AudioPlaySdWav consume, ");
Serial.print("size = ");
Serial.print(size);
Serial.print(", buffer_offset = ");
Serial.print(buffer_offset);
Serial.print(", data_length = ");
Serial.print(data_length);
Serial.print(", space = ");
Serial.print((AUDIO_BLOCK_SAMPLES - block_offset) * 2);
Serial.print(", state = ");
switch (state) {
// parse wav file header, is this really a .wav file?
case STATE_PARSE1:
len = data_length;
if (size < len) len = size;
memcpy((uint8_t *)header + header_offset, p, len);
header_offset += len;
buffer_offset += len;
data_length -= len;
if (data_length > 0) return false;
// parse the header...
if (header[0] == 0x46464952 && header[2] == 0x45564157) {
//Serial.println("is wav file");
if (header[3] == 0x20746D66) {
// "fmt " header
if (header[4] < 16) {
// WAV "fmt " info must be at least 16 bytes
if (header[4] > sizeof(header)) {
// if such .wav files exist, increasing the
// size of header[] should accomodate them...
//Serial.println("WAVEFORMATEXTENSIBLE too long");
// Serial.println("header ok");
header_offset = 0;
state = STATE_PARSE2;
// first chuck is something other than "fmt "
//Serial.print("skipping \"");
//Serial.printf("\" (%08X), ", __builtin_bswap32(header[3]));
//Serial.print(header[4]);
//Serial.println(" bytes");
header_offset = 12;
state = STATE_PARSE5;
p += len;
size -= len;
data_length = header[4];
goto start;
//Serial.println("unknown WAV header");
// check & extract key audio parameters
case STATE_PARSE2:
len = data_length;
data_length -= len;
if (parse_format()) {
// Serial.println("audio format ok");
p += len;
size -= len;
data_length = 8;
header_offset = 0;
state = STATE_PARSE3;
goto start;
Serial.println("unknown audio format");
// find the data chunk
case STATE_PARSE3: // 10
len = data_length;
data_length -= len;
//Serial.print("chunk id = ");
//Serial.print(header[0], HEX);
//Serial.print(", length = ");
//Serial.println(header[1]);
p += len;
size -= len;
data_length = header[1];
if (header[0] == 0x61746164) {
leftover_bytes = 0;
state = state_play;
total_length = data_length;
state = STATE_PARSE4;
goto start;
// ignore any extra unknown chunks (title & artist info)
case STATE_PARSE4: // 11
if (size < data_length) {
data_length -= size;
buffer_offset += size;
return false;
p += data_length;
size -= data_length;
buffer_offset += data_length;
data_length = 8;
header_offset = 0;
// Serial.println("consumed unknown chunk");
goto start;
// skip past "junk" data before "fmt " header
case STATE_PARSE5:
len = data_length;
data_length -= len;
p += len;
size -= len;
data_length = 8;
goto start;
// playing stereo at native sample rate
case STATE_DIRECT_16BIT_XCH:
// Serial.println("Attempting to play audio");
if (size > data_length) size = data_length;
if (leftover_bytes && numChannels > 1) {
Serial.println("Leftover bytes!");
block[0]->data[block_offset] = header[0];
//PAH fix problem with left+right channels being swapped
leftover_bytes = 0;
goto right16;
while (1) {
lsb = *p++;
msb = *p++;
size -= 2;
if (size == 0) {
if (data_length == 0) break;
header[0] = (msb << 8) | lsb;
leftover_bytes = 2;
return false;
//assign data being read to output channels:
block[0]->data[block_offset] = (msb << 8) | lsb;
right16:
for(int chan = 1; chan < numChannels; ++chan){
lsb = *p++;
msb = *p++;
size -= 2;
block[chan]->data[block_offset] = (msb << 8) | lsb;
block_offset++;
if (block_offset >= AUDIO_BLOCK_SAMPLES) {
for(int chan = 0; chan < numChannels; ++chan){
block[chan] = NULL;
for(int chan = numChannels; chan < WAV_MAX_CHANNELS; ++chan){
block[chan] = NULL;
data_length += size;
buffer_offset = p - buffer;
if (data_length == 0 && !isRepeating) state = STATE_STOP; //check on this, added repeating code
return true;
if (size == 0) {
leftover_bytes = 0;
return false;
// TODO: fill remainder of last block with zero and transmit
if(!isRepeating){ state = STATE_STOP; } //check on this, added code for repeat
return false;
// ignore any extra data after playing
// or anything following any error
case STATE_STOP:
return false;
// this is not supposed to happen!
default:
Serial.print("AudioPlaySdWav, unknown state: ");
state = STATE_STOP;
return false;
00000000 52494646 66EA6903 57415645 666D7420 RIFFf.i.WAVEfmt
00000010 10000000 01000200 44AC0000 10B10200 ........D.......
00000020 04001000 4C495354 3A000000 494E464F ....LIST:...INFO
00000030 494E414D 14000000 49205761 6E742054 INAM....I Want T
00000040 6F20436F 6D65204F 76657200 49415254 o Come Over.IART
00000050 12000000 4D656C69 73736120 45746865 ....Melissa Ethe
00000060 72696467 65006461 746100EA 69030100 ridge.data..i...
00000070 FEFF0300 FCFF0400 FDFF0200 0000FEFF ................
00000080 0300FDFF 0200FFFF 00000100 FEFF0300 ................
00000090 FDFF0300 FDFF0200 FFFF0100 0000FFFF ................
// SD library on Teensy3 at 96 MHz
// 256 byte chunks, speed is 443272 bytes/sec
// 512 byte chunks, speed is 468023 bytes/sec
#define B2M_44100 (uint32_t)((double)4294967296000.0 / AUDIO_SAMPLE_RATE_EXACT) // 97352592
#define B2M_22050 (uint32_t)((double)4294967296000.0 / AUDIO_SAMPLE_RATE_EXACT * 2.0)
#define B2M_11025 (uint32_t)((double)4294967296000.0 / AUDIO_SAMPLE_RATE_EXACT * 4.0)
bool AudioPlaySdWavXCH::parse_format(void)
uint8_t num = 0;
uint16_t format;
uint16_t channels;
uint32_t rate, b2m;
uint16_t bits;
//assume the file is correctly formatted, change it if it isn't:
state_play = STATE_DIRECT_16BIT_XCH;
format = header[0];
if (format != 1){
Serial.print("Unsupported Format: ");
Serial.println(format);
state_play = STATE_UNSUPPORTED_FORMAT;
rate = header[1];
if (rate == 44100) {
b2m = B2M_44100;
Serial.print("Unsupported Sample Rate: ");
Serial.println(rate);
channels = header[0] >> 16;
numChannels = channels;
b2m >>= (numChannels - 1);
bits = header[3] >> 16;
if (bits == 16) {
b2m >>= 1;
num |= 2;
}else{
Serial.print("Unsupported Bit Depth: ");
Serial.println(bits);
bytes2millis = b2m;
#if 0
Serial.print(" channels = ");
Serial.println(numChannels);
Serial.print(" bits = ");
Serial.println(
Serial.print(" bytes2millis = ");
Serial.println(b2m);
if(state_play == STATE_UNSUPPORTED_FORMAT){
return false;
// we're not checking the byte rate and block align fields
// if they're not the expected values, all we could do is
// return false. Do any real wav files have unexpected
// values in these other fields?
// state_play = num;
return true;
bool AudioPlaySdWavXCH::isPlaying(void)
uint8_t s = *(volatile uint8_t *)&state;
return (s < 8);
uint32_t AudioPlaySdWavXCH::positionMillis(void)
if (s >= 8) return 0;
uint32_t tlength = *(volatile uint32_t *)&total_length;
uint32_t dlength = *(volatile uint32_t *)&data_length;
uint32_t offset = tlength - dlength;
uint32_t b2m = *(volatile uint32_t *)&bytes2millis;
return ((uint64_t)offset * b2m) >> 32;
uint32_t AudioPlaySdWavXCH::lengthMillis(void)
return ((uint64_t)tlength * b2m) >> 32;
//modified from play_sd_wav.h by Emmett Palaima
#ifndef play_sd_wav_xch_h_
#define play_sd_wav_xch_h_
#define MULTI_BUFFERSIZE 1024
#define WAV_MAX_CHANNELS 10
#include "Arduino.h"
#include "AudioStream.h"
#include "SD.h"
class AudioPlaySdWavXCH : public AudioStream
public:
AudioPlaySdWavXCH(void) : AudioStream(0, NULL) { begin(); }
void begin(void);
bool play(const char *filename);
void stop(void);
bool isPlaying(void);
uint32_t positionMillis(void);
uint32_t lengthMillis(void);
virtual void update(void);
bool setRepeating(bool onOff){ isRepeating = onOff; }
private:
File wavfile;
bool consume(uint32_t size);
bool parse_format(void);
uint8_t numChannels;
uint32_t header[10]; // temporary storage of wav header data
uint32_t data_length; // number of bytes remaining in current section
uint32_t total_length; // number of audio data bytes in file
uint32_t bytes2millis;
audio_block_t* block[WAV_MAX_CHANNELS];
uint16_t block_offset; // how much data is in block_left & block_right
uint8_t buffer[MULTI_BUFFERSIZE]; // buffer one block of data
uint16_t buffer_offset; // where we're at consuming "buffer"
uint16_t buffer_length; // how much data is in "buffer" (512 until last read)
uint8_t header_offset; // number of bytes in header[]
uint8_t state;
uint8_t state_play;
uint8_t leftover_bytes;
bool isRepeating;
