James_Hicks
Hello, I'm working on a project right now where I have a single teensy 4.0 board generating different audio signals. This device is the I2s master, it's then transferring audio over I2s to another teensy 4.0 in I2s slave mode. This slave teensy is then transferring audio over I2s to a DAC and then to a speaker.
The issue is this: I want the slave Teensy to be able to read in ADC values and change an audio delay time based on those values. When I attempt to do this the audio is garbage. When I just pass the audio without reading ADC values from the slider, the audio is fine.
My idea on how to solve the issue is this: utilize a DMA to transfer ADC values directly to the variable controlling the delay time.
Is this feasible? How might I go about this? What's causing the audio issues?
My setup works generating audio and passing it through the I2s slave all the way to the DAC. However, when I try to read ADC values on the slave device the audio becomes garbage.
For your information the goal is to have modular blocks that take in audio over I2S and manipulate the audio and pass it along to the next modular block.
Source device is shown on the right and slave block is shown on the left.
Below is the code for the source teensy and the slave teensy.
## SOURCE TEENSY (I2S MASTER)
## SLAVE TEENSY (I2S SLAVE)
C++:
#include <SerialFlash.h>
#include <Bounce.h>
#include <stdint.h>
AudioSynthWaveform waveform;
AudioOutputI2S i2s;
AudioConnection patchcable1(waveform, 0, i2s, 0);
// buttons to control signal type
Bounce sine_button = Bounce(0, 5);
Bounce triangle_button = Bounce(1, 5);
Bounce saw_button = Bounce(2, 5);
uint32_t frequency = 500;
AudioMemory(100);
waveform.amplitude(1.0);
waveform.frequency(frequency);
waveform.begin(WAVEFORM_SINE);
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
Serial.printf("Source Block Initialized...\n");
//update button states
sine_button.update();
triangle_button.update();
saw_button.update();
// pot to control the frequency
float adc_off_A0 = (float)analogRead(A0) / 1023.0;
waveform.frequency(100.0 + adc_off_A0 * 900.0);
AudioInterrupts();
if(sine_button.fallingEdge())
// play the sine wave
else if(triangle_button.fallingEdge())
// play the triangle wave
waveform.begin(WAVEFORM_TRIANGLE);
else if(saw_button.fallingEdge())
// play the saw wave
waveform.begin(WAVEFORM_SAWTOOTH);
AudioNoInterrupts();
C++:
#include <Bounce.h>
#include <stdint.h>
#include <imxrt.h>
#include <DMAChannel.h> // maybe we'll just try to transfer ADC using dma
AudioOutputI2Sslave i2s_out;
AudioInputI2Sslave i2s_in;
AudioEffectDelay delay_1;
AudioConnection patchcable1(i2s_in, 0, delay_1, 0);
AudioConnection patchcable6(delay_1, 0, i2s_out, 0);
// I want a dma to transfer ADC data to a variable
AudioMemory(400);
Serial.printf("Delay Block Initialized...\n");
// slider to control the delay time
float delay_time = (float)analogRead(A0) / 1023.0;
delay_1.delay(0, delay_time * 500);
AudioInterrupts();
