Is there a convenient way to set the pullup resistor for an output pin that is to be used with the flexpwm? The goal is that when the outen bit is cleared, the pin should remain high.
(Aside, I could simply move one of the val_n registers past the value stored in the init register so that it stops transitioning, but that takes effect after the next load.)
To be specific, I want to do this with pin 5 on a T4.
The reference manual seems ambiguous or confusing about this. Under output driver, page 952, it lists selectable pull-up/down and output keeper, but then it says these are disabled in output mode.
Thank you
Thank you
