Hi!
I have just got an 2'' 240x320 TFT display(EA TFT020-23AINN) working on a Teensy 3.5 using the T3/4 optimised library.
My goal is to be able to drive 5 of these ST7789 displays from the same Teensy 3.5 on the same SPI bus. Because the remaining pins are already used for other purposes, I have to limit myself to an SPI bus.
At the moment I have the test programme below for 5 LCDs. A very simple program that controls 5 LCDs and outputs the "position" of the encoder.
Problem:
The library says you can only attach to one LCD framebuffer, is there a way around this and do I have enough RAM with the Teensy 3.5 to do this. I could switch to teensy 4.1.
Or are there other ways to control multiple LCDs without flickering?
Thanks in advance for your thoughts!
-Jonas
Problem:
-Jonas
#include <Adafruit_GFX.h> // Core graphics library
//#include <ST7735_t3.h> // Hardware-specific library
#include <ST7789_t3.h> // Hardware-specific library
//Fonts
#include <st7735_t3_font_ComicSansMS.h>
#include <FreeSans24pt7b.h>
#include "Encoder_JB.h"
#define inputA 16
#define inputB 15
// For the breakout board, you can use any 2 or 3 pins.
// These pins will also work for the 1.8" TFT shield.
#define NUM_LCDS 5
#define TFT_DC 8
#define TFT_RST 10
#define TFT_RST_DUMMY 0xff
#define DIM_LCD 14
#define TFT_CS0 2
#define TFT_CS1 3
#define TFT_CS2 4
#define TFT_CS3 5
#define TFT_CS4 6
// For 1.14", 1.3", 1.54", 1.69", and 2.0" TFT with ST7789:
ST7789_t3 tft0 = ST7789_t3(TFT_CS0, TFT_DC, TFT_RST_DUMMY);
ST7789_t3 tft1 = ST7789_t3(TFT_CS1, TFT_DC, TFT_RST_DUMMY);
ST7789_t3 tft2 = ST7789_t3(TFT_CS2, TFT_DC, TFT_RST_DUMMY);
ST7789_t3 tft3 = ST7789_t3(TFT_CS3, TFT_DC, TFT_RST_DUMMY);
ST7789_t3 tft4 = ST7789_t3(TFT_CS4, TFT_DC, TFT_RST_DUMMY);
const ST7789_t3 *Tfts[NUM_LCDS] = { &tft0, &tft1, &tft2, &tft3, &tft4 };
Serial.print("hello!");
// // Set Dim for LCDs
// pinMode(DIM_LCD, OUTPUT);
// analogWrite(DIM_LCD, 255);
/* reset the displays manually */
pinMode(TFT_RST, OUTPUT);
digitalWriteFast(TFT_RST, HIGH);
digitalWriteFast(TFT_RST, LOW);
delay(200);
/* initializer using a 2.0" 320x240 tft */
Serial.println("init");
ST7789_t3 *tft;
for (int i = NUM_LCDS - 1; i >= 0; i--)
tft = (ST7789_t3*)Tfts[i];
tft->init(240, 320, SPI_MODE3);
if(!(tft->useFrameBuffer(true)))
Serial.print("FrameBuffer failed on LCD: ");
Serial.println(i);
uint16_t time = millis();
tft0.fillScreen(ST77XX_YELLOW);
tft1.fillScreen(ST77XX_BLUE);
time = millis() - time;
Serial.println(time, DEC);
tft->setTextSize(1);
tft->setFont(&FreeSans24pt7b);
//init Encoder
ENCODER_JB(inputA, inputB, false); //init Encoder
setBoundaries(-99, 999); //minBoundarie: -21, maxBoundarie: 999
Serial.println("done");
unsigned int oldmillis = millis();
ST7789_t3 *tft;
while(1)
tft->fillRect(25,25,200,50,ST77XX_BLACK);
tft->setCursor(30, 30);
tft->print(getPosition());
if((millis() - oldmillis) > 16 ) //update every 16ms
updateTFT();
void updateTFT()
ST7789_t3 *tft;
for (int i = NUM_LCDS - 1; i >= 0; i--) //update each LCD
tft->updateScreen();
